Philips Hue Colour 6.5W A60 B22 Bulbs 3-Pack
Quicklinx: H50VWS00 Mfr#: 929002489703
Hurry, only 2 left in stock!
£108.33 ex VAT
£129.99 inc VAT
With these Philips Hue smart lights, your home will work harder, so you don’t have to. They can be controlled from your phone, so there’ll be no need to climb the stairs if that pesky landing light is still on. And since you can schedule a timer, the lights can turn on or off automatically whenever you need them to. Plus, with 16 million shades to choose from, there’s a colour for every occasion from red hues on Valentine’s to fun greens on St Patricks Day. The brightness can be dimmed as well, which will come in handy for date night. It’s got a 25,000-hour lifespan too, meaning it’ll carry you through the year and long after before you even have to think about replacing it.
Please note, to use the Philips Hue light bulb you’ll need a Philips Bridge (sold separately). You’ll also need to download the free Philips Hue app, which is compatible with all iOS and Android devices.
  • Smart lighting – control from your phone or tablet
  • White and coloured bulb – choose from 16 million shades
  • Bayonet fitting with 25,000 hour lifespan
  • Schedule a timer to turn lights on automatically
  • Dim the brightness to match your mood
  • Versatile color options
    Experience flexibility with 16 million color choices and warm to cool white light, enhancing any room's atmosphere.
  • Easy integration
    Compatible with Zigbee and Bluetooth technologies, offering seamless connectivity with smart home devices.
  • Energy-efficient design
    Low power consumption of 6.5 W and an Energy Class rating contribute to reduced energy bills while providing bright light.
  • Long-lasting performance
    Designed to last up to 25,000 hours, ensuring reliable performance and reducing the frequency of replacements.
  • Control options
    Easily managed through the Philips Hue App or voice commands, providing intuitive access to your lighting preferences.
Philips Hue White and Color Ambiance 800 - LED light bulb - shape: A60 - B22 - 6.5 W - 16 million colours/warm to cool white light - 2000-6500 K (pack of 3)
Light Source Type
LED light bulb
Packaged Quantity
3 (specifications are for single item)
Shape
A60
Socket Type
B22
Wattage
6.5 W
Energy Efficiency Class
F
Colour of Illumination
Colour Temperature
2000-6500 K
Luminous Power
570 - 806 lumens
Dimmable
Intelligent Assistant
Alexa, Apple HomeKit, Cortana, Google Assistant
Communications Technology
Bluetooth, Zigbee
220 - 240 V
Packaged Quantity
Voice control, app-controlled, dimmable with compatible dimmers
Light Source
LED light bulb
Shape
A60
Socket Type
B22
Wattage
6.5 W
F
Energy Consumption per 1000h
9 kWh
Power Factor
0.8
Colour Temperature
2000-6500 K
Colour Rendering Index
80
Luminous Power
570 - 806 lumens
Dimmable
Lifetime
25000 hours
Switch Cycles
50000
Instant full light
Power Requirements
220 - 240 V
Power Consumption Stand by
0.5 Watt
Internet of Things (IoT)
Compatible Application
Philips Hue App
Bluetooth, Zigbee
Package
Box
Warranty
2 years
Diameter
60 mm
Length
109 mm
Dimensions & Weight Details
- width: 6 cm x depth: 6 cm x height: 10.9 cm
14.6 cm x 14 cm x 17.4 cm / 320 g
-20 °C
45 °C
Type: Light bulb
Compatible With: Apple HomeKit
Compatible With: Cortana
Compatible With: Alexa
Brand: Philips
