Philips E-Line 32" IPS Monitor VGA HDMI DP
Quicklinx: DCLRWS00 Mfr#: 328E8QJAB5/00
Diagonal Size: 32in
Max Resolution: 1920 x 1080
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, VGA (HD-15)
35 in stock
£165.90 ex VAT
£199.08 inc VAT
Colours like you've never seen before. This brilliant wide-view curved Full HD display with an ultra-wide colour range offers fast action with true-to-life colours for a completely immersive experience.
  • HDMI-ready for Full HD entertainment
    An HDMI-ready device has all the required hardware to accept High-Definition Multimedia Interface (HDMI) input. An HDMI cable enables high-quality digital video and audio to be transmitted over a single cable from a PC or any number of AV sources (including set-top boxes, DVD players, A/V receivers and video cameras).
  • Built-in stereo speakers for multimedia
    A pair of high-quality stereo speakers built into a display device. They may be visible front firing, or invisible down firing, top firing, rear firing etc. depending on model and design.
  • SmartImage game mode optimised for gamers
    The new Philips gaming display has quick-access OSD fine-tuned for gamers, offering you multiple options. "FPS" mode (First person shooting) improves dark themes in games, allowing you to see hidden objects in dark areas. "Racing" mode adapts the display with the fastest response time and high colour, along with image adjustments. "RTS" mode (Real-time strategy) has a special SmartFrame mode that enables highlighting of specific area and allows for size and image adjustments. Gamer 1 and Gamer 2 enable you to save personal customised settings based on different games, ensuring best performance.
  • DisplayPort connection for maximum visuals
    DisplayPort is a digital link from PC to monitor without any conversion. With higher capabilities than DVI standard, it is fully capable to support up to 15 metre cables and 10.8 Gbps/sec data transfer. With this high performance and zero latency, you get the fastest imaging and refresh rates — making DisplayPort the best choice for not only general office or home use, but also for the more demanding gaming and films, video editing and more. It also keeps interoperability in mind via the use of various adapters.
  • SmartContrast for deep black level details
    SmartContrast is a Philips technology that analyses the contents you are displaying, automatically adjusting colours and controlling backlight intensity to dynamically enhance contrast for the best digital images and videos or when playing games where dark hues are displayed. When Economy mode is selected, contrast is adjusted and backlighting fine-tuned for just-right display of everyday office applications and lower power consumption.
  • Less eye fatigue with Flicker-Free technology
    Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips Flicker-Free technology applies a new solution to regulate brightness and reduce flicker for more comfortable viewing.
  • Curved display design for a more immersive experience
    Desktop monitors offer a personal user experience, which suits a curved design very well. The curved screen provides a pleasant yet subtle immersion effect, which focuses on you at the centre of your desk.
  • 16:9 Full HD display for crisp, detailed images
    Picture quality matters. Regular displays deliver quality, but you expect more. This display features enhanced Full HD 1920 x 1080 resolution. With Full HD for crisp detail paired with high brightness, incredible contrast and realistic colours, expect a true-to-life picture.
  • Effortlessly smooth gameplay with AMD FreeSync™ technology
    Gaming shouldn't be a choice between choppy gameplay or broken frames. With the new Philips monitor it doesn't have to be. Get fluid, artefact-free performance at virtually any frame rate with AMD FreeSync™ technology, smooth, quick refresh and ultra-fast response time.
  • Ultra Wide-Color wider range of colours for a vivid picture
    Ultra Wide-Color Technology delivers a wider spectrum of colours for a more brilliant picture. The Ultra Wide-Color wider "colour gamut" produces more natural-looking greens, vivid reds and deeper blues. Bring media entertainment, images and even productivity more alive with vivid colours from Ultra Wide-Color Technology.
  • VA display gives awesome images with a wide viewing angle
    Philips' VA LED display uses an advanced multi-domain vertical alignment technology that gives you super-high static contrast ratios for extra-vivid and bright images. While standard office applications are handled with ease, it is especially suitable for photos, web browsing, films, gaming and demanding graphical applications. Its optimised pixel management technology gives you a 178/178-degree extra-wide viewing angle, resulting in crisp images.
Philips E-line 328E8QJAB5 - LED monitor - curved - Full HD (1080p) - 32"
LED-backlit LCD monitor - 32"
Energy Class
Class B
Energy Consumption per Year
77 kWh
Power Consumption (On mode)
46 W
Curved Screen
Adaptive-Sync Technology
AMD FreeSync
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.364 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 20000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Tilt
Black, gun metal
72.1 cm x 22.3 cm x 52.5 cm
7.2 kg
Plug and Play, FCC Class B certified, TUV, VCCI, BSMI, DDC/CI, RoHS, Lead-Free, WEEE, CECP, RCM, ISO9241-307, CU-EAC
Display Type
Energy Class
Class B
77 kWh
46 W
Diagonal Size
32"
Viewable Size
31.5"
Curved Screen
Yes (1800R)
AMD FreeSync
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.364 mm
Pixel Per Inch
70
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms (grey-to-grey)
Vertical Refresh Rate
49 - 72 Hz
Horizontal Refresh Rate
54 - 84 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Sync on Green, SmartContrast, SmartConnect, SmartImage Game, Flicker Free technology, FreeSync Technology, 126% sRGB colour gamut, 103% NTSC colour gamut
Black, gun metal
72.1 cm x 22.3 cm x 52.5 cm - with stand
7.2 kg
Audio
Speakers - stereo
Output Power / Channel
3 Watt
HDMI (HDCP) , DisplayPort , VGA , Audio line-in , Headphones
Mechanical
Tilt
Tilt Angle
-5/+10
1 x VGA cable , 1 x HDMI cable , 1 x audio cable
MTBF
50,000 hour(s)
43.82 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Apple MacOS X, Microsoft Windows 7, Windows 8, Windows 8.1, Windows 10
Dimensions & Weight Details
With stand - width: 72.1 cm - depth: 22.3 cm - height: 52.5 cm - weight: 7.2 kg , Without stand - width: 72.1 cm - depth: 7.6 cm - height: 43.4 cm - weight: 6.9 kg
20 - 80%
Philips E-Line 32 Bundle deal on Philips E-Line 32" IPS Monitor VGA HDMI DP
£265.07
Diagonal Size: 32in
Response Time: 4ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Philips
Price Range Ex VAT: 150 - 300
