This big 273E3 Full HD display with touch control is ready to engage you in the entertainment world. This display has a resolution that is referred to as Full HD. With state-of-the-art LCD screen technology it has the full high-definition widescreen resolution of 1920 x 1080p. It allows the best possible picture quality from any format of HD input signal. It produces brilliant flicker-free pictures with optimum brightness and superb colors. This vibrant and sharp image will provide you with an enhanced viewing experience.
SmartImage Lite is an exclusive, leading edge Philips technology that analyzes the content displayed on your screen. Based on a scenario you select, SmartImage Lite dynamically enhances the contrast, color saturation and sharpness of images and videos for ultimate display performance - all in real time with the press on a single button.
You want the LCD flat display with the highest contrast and most vibrant images. Philips advanced video processing combined with unique extreme dimming and backlight boosting technology results in vibrant images. SmartContrast will increase the contrast with excellent black level and accurate rendition of dark shades and colors. It gives a bright, lifelike picture with high contrast and vibrant colors.
Touch controls are intelligent, touch sensitive icons that replace protruding buttons that lets the user adjust the monitor to their requirement. Responding to your lightest touch, touch control gives the monitor a modern feel.
Philips easy picture format control on OSD is to switch from the 4:3 aspect ratio to the widescreen mode and back again to match the display's aspect ratio with your content for working with wide documents without scrolling or viewing widescreen media in the widescreen mode and distortion-free, native mode display of 4:3 ratio content.
Full HD LCD display
This display has a resolution that is referred to as Full HD. With state-of-the-art LCD screen technology it has the full high-definition widescreen resolution of 1920 x 1080p. It allows the best possible picture quality from any format of HD input signal. It produces brilliant flicker-free pictures with optimum brightness and superb colors. This vibrant and sharp image will provide you with an enhanced viewing experience. -
SmartImage Lite for an enhanced LCD viewing experience
SmartImage Lite is an exclusive, leading edge Philips technology that analyzes the content displayed on your screen. Based on a scenario you select, SmartImage Lite dynamically enhances the contrast, color saturation and sharpness of images and videos for ultimate display performance - all in real time with the press on a single button. -
SmartContrast 500,000:1 for incredible rich black details
You want the LCD flat display with the highest contrast and most vibrant images. Philips advanced video processing combined with unique extreme dimming and backlight boosting technology results in vibrant images. SmartContrast will increase the contrast with excellent black level and accurate rendition of dark shades and colors. It gives a bright, lifelike picture with high contrast and vibrant colors. -
Modern touch controls
Touch controls are intelligent, touch sensitive icons that replace protruding buttons that lets the user adjust the monitor to their requirement. Responding to your lightest touch, touch control gives the monitor a modern feel. -
Easy picture format control switching in wide and 4:3 format
- Philips E-line 273E3LHSB - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class B
- Energy Consumption per Year
- 57 kWh
- Power Consumption (On mode)
- 39 W
- Stereo speakers
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.311 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1200:1 / 20000000:1 (dynamic)
- Response Time
- 3.5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI-D, VGA
- Speakers
- Integrated
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 64.2 cm x 22.7 cm x 44 cm
- 8.2 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, UL, TUV GS, BSMI, GOST, cUL, SEMKO, TUV Ergo, FCC, DDC/CI, RoHS
- 3-year warranty
- Display Type
- Energy Class
- Class B
- 57 kWh
- Diagonal Size
- 27"
- Built-in Devices
- Stereo speakers
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.311 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 3.5 ms
- Vertical Refresh Rate
- 75 Hz
- Horizontal Refresh Rate
- 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 170
- Backlight Technology
- WLED
- Controls & Adjustments
- Volume, input select
- OSD Languages
- Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish, Turkish
- Sync on Green, sRGB colour management, HDCP, SmartImage Lite, SmartResponse, SmartContrast, Touch Control
- Black
- 64.2 cm x 22.7 cm x 44 cm - with stand
- 8.2 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 2 Watt
- VGA , DVI-D , HDMI , Headphones , Audio line-in
Mechanical
- Tilt
- Tilt Angle
- 25
- VESA Mounting Interface
- 100 x 100 mm
- MTBF
- 30,000 hour(s)
- Power Supply
- Internal
- Input Voltage
- 39 W
- Power Consumption (Typical)
- 20.4 Watt
- Power Consumption Stand by / Sleep
- 0.5 Watt
- On / Off Switch
- No
- Included Software
- Philips SmartControl Lite
- Dimensions & Weight Details
- With stand - width: 64.2 cm - depth: 22.7 cm - height: 44 cm - weight: 8.2 kg , Without stand - width: 64.2 cm - depth: 6.4 cm - height: 39.1 cm - weight: 6.5 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 20 - 80%
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
