Philips E-Line 27" IPS Monitor HDMI and DisplayPort
Quicklinx: DCN8WS00 Mfr#: 276E9QJAB/00
None in stock
The Philips E line monitor features stylish design with extraordinary picture performance. A narrow border Full HD display with Ultra Wide-Color brings you to real true-to-life visuals. Enjoy superior viewing in a stylish design.
  • Built-in stereo speakers
    A pair of high-quality stereo speakers built into a display device. They may be visible front firing, or invisible down firing, top firing, rear firing etc. depending on model and design.
  • HDMI Ready
    An HDMI-ready device has all the required hardware to accept High-Definition Multimedia Interface (HDMI) input. An HDMI cable enables high-quality digital video and audio to be transmitted over a single cable from a PC or any number of AV sources (including set-top boxes, DVD players, A/V receivers and video cameras).
  • Flicker-Free technology
    Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips Flicker-Free technology applies a new solution to regulate brightness and reduce flicker for more comfortable viewing.
  • 16:9 Full HD display
    Picture quality matters. Regular displays deliver quality, but you expect more. This display features enhanced Full HD 1920 x 1080 resolution. With Full HD for crisp detail paired with high brightness, incredible contrast and realistic colours, expect a true-to-life picture.
  • LowBlue Mode
    Studies have shown that just as ultra-violet rays can cause eye damage, shortwave-length blue light rays from LED displays can cause eye damage and affect vision over time. Developed for wellbeing, the Philips LowBlue Mode setting uses a smart software technology to reduce harmful shortwave blue light.
  • IPS technology
    IPS displays use an advanced technology that gives you extra-wide viewing angles of 178/178 degrees, making it possible to view the display from almost any angle. Unlike standard TN panels, IPS displays give you remarkably crisp images with vivid colours, making them ideal not only for Photos, movies and web browsing, but also for professional applications that demand colour accuracy and consistent brightness at all times.
  • Ultra-smooth gaming
    Gaming shouldn't be a choice between choppy gameplay or broken frames. With the new Philips monitor it doesn't have to be. Get fluid, artefact-free performance at virtually any frame rate with AMD FreeSync technology, smooth, quick refresh and ultra-fast response time.
  • Ultra-narrow Border
    The new Philips displays feature ultra-narrow borders which allow for minimal distractions and maximum viewing size. Especially suited for multi-display or tiling setups like gaming, graphic design and professional applications, the ultra-narrow border display gives you the feeling of using one large display.
  • Ultra Wide-Color Technology
    Ultra Wide-Color Technology delivers a wider spectrum of colours for a more brilliant picture. The Ultra Wide-Color wider"colour gamut" produces more natural-looking greens, vivid reds and deeper blues. Bring media entertainment, images and even productivity more alive with vivid colours from Ultra Wide-Color Technology.
  • DisplayPort connection
    DisplayPort is a digital link from PC to monitor without any conversion. With higher capabilities than DVI standard, it is fully capable to support up to 15 metre cables and 10.8 Gbps/sec data transfer. With this high performance and zero latency, you get the fastest imaging and refresh rates- making DisplayPort the best choice for not only general office or home use, but also for the more demanding gaming and films, video editing and more. It also keeps interoperability in mind via the use of various adapters.
Philips E-line 276E9QJAB - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A
Energy Consumption per Year
44 kWh
Power Consumption (On mode)
30 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 75 Hz
Pixel Pitch
0.311 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
Black/silver
61.4 cm x 22 cm x 46.5 cm
3.99 kg
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, TUV, BSMI, DDC/CI, RoHS, Lead-Free, WEEE, CECP, EPA, cETLus, RCM, ISO9241-307, CU
Display Type
Energy Class
Class A
44 kWh
30 W
Diagonal Size
27"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Pixel Per Inch
82
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
38 - 89 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
SmartImage Game, Flicker Free technology, Mercury free, sRGB Color Space, Adaptive Display, Ultra Wide-Color Technology, Narrow Border Display, 124% sRGB colour gamut, 93% NTSC colour gamut
Black/silver
61.4 cm x 22 cm x 46.5 cm - with stand
3.99 kg
Audio
Speakers - stereo
Output Power / Channel
3 Watt
VGA , DisplayPort , HDMI (HDCP) , Audio line-in , Headphones
Mechanical
Tilt
Tilt Angle
- 5/+20
VESA Mounting Interface
100 x 100 mm
HDMI cable
MTBF
50000 hour(s)
Security Slot Type
Kensington security slot
AC 120/230 V (50 - 60 Hz)
15.72 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
Apple MacOS X, Microsoft Windows 7 / 8 / 8.1 / 10
Dimensions & Weight Details
Without stand - width: 61.4 cm - depth: 4 cm - height: 36.7 cm - weight: 3.33 kg
Shipping Width
66 cm
Shipping Depth
15.5 cm
Shipping Height
51.4 cm
Shipping Weight
6.04 kg
ENERGY STAR Certified
20 - 80%
