Philips E-Line 27" Curved Full HD Monitor
Quicklinx: DCLSWS00 Mfr#: 278E8QJAB/00
Diagonal Size: 27in
Stock Status: Clearance
38 left in stock
£108.33 ex VAT
£129.99 inc VAT
Express delivery Order within the next 11 hours for delivery tomorrow
Colours like you've never seen before. This brilliant wide-view display with Ultra Wide-Color offers the richest and most vivid colours wrapped in an immersive curved design for your best creations yet.
  • HDMI-ready for Full HD entertainment
    An HDMI-ready device has all the required hardware to accept High-Definition Multimedia Interface (HDMI) input. An HDMI cable enables high-quality digital video and audio to be transmitted over a single cable from a PC or any number of AV sources (including set-top boxes, DVD players, A/V receivers and video cameras).
  • Built-in stereo speakers for multimedia
    A pair of high-quality stereo speakers built into a display device. They may be visible front firing, or invisible down firing, top firing, rear firing etc. depending on model and design.
  • DisplayPort connection for maximum visuals
    DisplayPort is a digital link from PC to monitor without any conversion. With higher capabilities than DVI standard, it is fully capable to support up to 15 metre cables and 10.8 Gbps/sec data transfer. With this high performance and zero latency, you get the fastest imaging and refresh rates — making DisplayPort the best choice for not only general office or home use, but also for the more demanding gaming and films, video editing and more. It also keeps interoperability in mind via the use of various adapters.
  • SmartImage Lite for easy optimised image settings
    SmartImage Lite is an exclusive, leading edge Philips technology that analyses the content displayed on your screen. Based on a scenario you select, SmartImage Lite dynamically enhances the contrast, colour saturation and sharpness of images and videos for ultimate display performance - all in real time with the press of a single button.
  • SmartContrast for deep black level details
    SmartContrast is a Philips technology that analyses the contents you are displaying, automatically adjusting colours and controlling backlight intensity to dynamically enhance contrast for the best digital images and videos or when playing games where dark hues are displayed. When Economy mode is selected, contrast is adjusted and backlighting fine-tuned for just-right display of everyday office applications and lower power consumption.
  • Less eye fatigue with Flicker-Free technology
    Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips Flicker-Free technology applies a new solution to regulate brightness and reduce flicker for more comfortable viewing.
  • Curved display design for a more immersive experience
    Desktop monitors offer a personal user experience, which suits a curved design very well. The curved screen provides a pleasant yet subtle immersion effect, which focuses on you at the centre of your desk.
  • 16:9 Full HD display for crisp, detailed images
    Picture quality matters. Regular displays deliver quality, but you expect more. This display features enhanced Full HD 1920 x 1080 resolution. With Full HD for crisp detail paired with high brightness, incredible contrast and realistic colours, expect a true-to-life picture.
  • Ultra Wide-Color wider range of colours for a vivid picture
    Ultra Wide-Color Technology delivers a wider spectrum of colours for a more brilliant picture. The Ultra Wide-Color wider "colour gamut" produces more natural-looking greens, vivid reds and deeper blues. Bring media entertainment, images and even productivity more alive with vivid colours from Ultra Wide-Color Technology.
  • VA display gives awesome images with a wide viewing angle
    Philips' VA LED display uses an advanced multi-domain vertical alignment technology that gives you super-high static contrast ratios for extra-vivid and bright images. While standard office applications are handled with ease, it is especially suitable for photos, web browsing, films, gaming and demanding graphical applications. Its optimised pixel management technology gives you a 178/178-degree extra-wide viewing angle, resulting in crisp images.
Philips E-line 278E8QJAB - LED monitor - curved - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
50 kWh
Power Consumption (On mode)
34 W
Curved Screen
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 20000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Tilt
Black, glossy
62 cm x 18.9 cm x 47 cm
4.8 kg
Plug and Play, FCC Class B certified, TUV, TUV GS, VCCI, BSMI, TUV Ergo, DDC/CI, RoHS, Lead-Free, WEEE, CECP, CEL, cETLus, RCM, ISO9241-307, CU-EAC
Display Type
Energy Class
Class B
50 kWh
34 W
Diagonal Size
27"
Viewable Size
27"
Curved Screen
Yes (1800R)
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms (grey-to-grey)
Vertical Refresh Rate
49 - 75 Hz
Horizontal Refresh Rate
54 - 84 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Sync on Green, sRGB colour management, SmartImage Lite, SmartContrast, 104% NTSC color gamut, FreeSync Technology, 130% sRGB colour gamut
Black, glossy
62 cm x 18.9 cm x 47 cm - with stand
4.8 kg
Audio
Stereo
Output Power / Channel
3 Watt
HDMI (HDCP) , DisplayPort , VGA , Audio line-in , Headphones
Mechanical
Tilt
Tilt Angle
-5/+20
Security lock slot (cable lock sold separately), wall mountable
1 x VGA cable , 1 x HDMI cable , 1 x audio cable
MTBF
50,000 hour(s)
31.8 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
On / Off Switch
No
Apple MacOS X, Microsoft Windows 7
Dimensions & Weight Details
With stand - width: 62 cm - depth: 18.9 cm - height: 47 cm - weight: 4.8 kg , Without stand - width: 62 cm - depth: 6.8 cm - height: 36.5 cm - weight: 4.57 kg
20 - 80%
Philips E-Line 27 Bundle deal on Philips E-Line 27" Curved Full HD Monitor
£208.09
Diagonal Size: 27in
Brand: Philips
Price Range Ex VAT: 100 - 150
