Philips E-Line 24" Full HD LED Monitor with Speakers VGA DVI HDMI
Quicklinx: CVBRWS00 Mfr#: 246E7QDAB/00
UltraColor technology delivers a wider spectrum of colors for a more brilliant picture. UltraColor wider color gamut produces more natural-looking greens, vivid reds and deeper blues. Bring media entertainment, images and even productivity more alive and vivid colors from UltraColor technology. IPS displays use an advanced technology that gives you extra-wide viewing angles of 178/178 degrees, making it possible to view the display from almost any angle. Unlike standard TN panels, IPS displays give you remarkably crisp images with vivid colors, making them ideal not only for photos, movies and web browsing, but also for professional applications that demand color accuracy and consistent brightness at all times.
Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips Flicker-Free technology applies a perfect solution to regulate brightness and reduce flicker for more comfortable viewing. SmartContrast is a Philips technology that analyzes the contents you are displaying, automatically adjusting colors and controlling backlight intensity to dynamically enhance contrast for perfect digital images and videos or when playing games where dark hues are displayed. When Economy mode is selected, contrast is adjusted and backlighting fine-tuned for just-right display of everyday office applications and lower power consumption.
The discreetly placed EasySelect menu toggle key allows you to make quick and easy adjustments to monitor settings in the on-screen display menu. SmartImage Lite is an exclusive Philips technology that analyzes the content displayed on your screen. Based on a scenario you select, SmartImage Lite dynamically enhances the contrast, color saturation and sharpness of images and videos for ultimate display performance - all in real time with the press of a single button.
Philips E-line 246E7QDAB - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class A
Energy Consumption per Year
31 kWh
Power Consumption (On mode)
21 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.272 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, HDMI (MHL)
Display Position Adjustments
Tilt
Glossy black
53.9 cm x 17.9 cm x 41.9 cm
3.18 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV, VCCI, DDC/CI, RoHS, Lead-Free, ISO 9241-307, WEEE, CECP, TCO Displays, RCM, CU-EAC
Display Type
Energy Class
Class A
31 kWh
21 W
Diagonal Size
24"
Viewable Size
23.6"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.272 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Sync on Green, sRGB colour management, SmartImage Lite, SmartContrast, Flicker Free technology, Mercury free, Wide Viewing Angle, EasySelect Menu Toggle Key, UltraColor technology
Glossy black
53.9 cm x 17.9 cm x 41.9 cm - with stand
3.18 kg
Audio
Speakers - stereo
Output Power / Channel
3 Watt
VGA , DVI-D (HDCP) , MHL / HDMI (HDCP) , Audio line-in , Headphones
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
MTBF
50,000 hour(s)
Security Slot Type
Kensington security slot
14.47 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
On / Off Switch
No
Apple MacOS X, Microsoft Windows 7 / 8 / 8.1
Dimensions & Weight Details
With stand - width: 53.9 cm - depth: 17.9 cm - height: 41.9 cm - weight: 3.18 kg , Without stand - width: 53.9 cm - depth: 4.5 cm - height: 32.4 cm - weight: 2.61 kg
ENERGY STAR Certified
20 - 80%
