Your basket is empty
Philips E-Line 227E6EDSD/00 22" Full HD 1920x1080 DVI HDMI Monitor
Quicklinx: BYZ5WS00 Mfr#: 227E6EDSD/00
Diagonal Size: 21.5in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: None
Interfaces: VGA (HD-15)
More than 50 in stock
£94.86 ex VAT
£113.83 inc VAT
Express delivery Order within the next 3 hours for delivery tomorrow
Designed for you: the elegant Philips E-line monitor features SoftBlue technology to protect your eyes and deliver brilliant colorful images.
SoftBlue Technology
SoftBlue LED technology uses a smart technology to reduce harmful shortwave blue light without affecting the color or image of the display. SoftBlue LED technology is certified by international testing organizations TUV Rheinland to reduce harmful blue light.
IPS-ADS technology
IPS-ADS displays use an advanced technology which gives you extra wide viewing angles of 178/178 degree, making it possible to view the display from almost any angle. Unlike standard TN panels, IPS-ADS displays give you remarkably crisp images with vivid colors, making it ideal not only for Photos, movies and web browsing, but also for professional applications which demand color accuracy and consistent brightness at all times.
16:9 Full HD display
The Full HD screen has the widescreen resolution of 1920 x 1080p. This is the highest resolution of HD sources for the best possible picture quality. It is fully future proof as it supports 1080p signals from all sources, including the most recent like Blu-ray and advanced HD game consoles. The signal processing is extensively upgraded to support this much higher signal quality and resolution. It produces brilliant flicker-free progressive scan pictures with superb brightness and colors.
SmartImage Lite
SmartImage Lite is an exclusive, leading edge Philips technology that analyzes the content displayed on your screen. Based on a scenario you select, SmartImage Lite dynamically enhances the contrast, color saturation and sharpness of images and videos for ultimate display performance - all in real time with the press on a single button.
SmartControl Lite
SmartControl Lite is the next generation 3D icon based GUI monitor control software. This allows user to fine-tune most parameters of the monitor like Color, Brightness, screen calibration, Multi-media, ID management, etc with the mouse.
SmartContrast
SmartContrast is a Philips technology that analyzes the contents you are displaying, automatically adjusting colors and controlling backlight intensity to dynamically enhance contrast for the best digital images and videos or when playing games where dark hues are displayed. When Economy mode is selected, contrast is adjusted and backlighting fine-tuned for just-right display of everyday office applications and lower power consumption.
Modern Touch controls
Touch controls are intelligent, touch sensitive icons that replace protruding buttons that lets the user adjust the monitor to their requirement. Responding to your lightest touch,Touch control gives the monitor a modern feel.
Philips E-line 227E6EDSD - LED monitor - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Class
Class A
Energy Consumption per Year
31 kWh
Power Consumption (On mode)
21 W
Panel Type
ADS-IPS
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
14 ms (typical); 5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA, MHL
Display Position Adjustments
Tilt
Glossy cherry black
51.1 cm x 21.2 cm x 40 cm
2.95 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, BSMI, GOST, SASO, SEMKO, DDC/CI, ISO 9241-307, WEEE, TCO Displays 6.0, SGS, cETLus
Display Type
Energy Class
Class A
31 kWh
21 W
Diagonal Size
21.5"
Panel Type
ADS-IPS
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Sync on Green, power off timer, sRGB colour management, HDCP, SmartImage Lite, SmartResponse, SmartContrast, power on timer, 4:3 in Wide, Touch Control, SoftBlue Technology
Glossy cherry black
51.1 cm x 21.2 cm x 40 cm - with stand
2.95 kg
VGA , DVI-D (HDCP) , MHL / HDMI (HDCP)
Mechanical
Tilt
Tilt Angle
-5/+20
MTBF
30,000 hour(s)
Power Supply
External
15.52 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.3 Watt
On / Off Switch
No
Apple MacOS X, Microsoft Windows 7 / Windows 8
Dimensions & Weight Details
With stand - width: 51.1 cm - depth: 21.2 cm - height: 40 cm - weight: 2.95 kg , Without stand - width: 51.1 cm - depth: 3.6 cm - height: 31.8 cm - weight: 2.58 kg
ENERGY STAR Certified
20 - 80%
BYZ5 C2G 1m DVI-D™ M/M Dual Link Digital Video Cable In Stock £6.77
BYZ5 C2G 2m DVI-D™ M/M Dual Link Digital Video Cable In Stock £7.57
BYZ5 C2G 5m DVI-D™ M/M Dual Link Digital Video Cable In Stock £12.65
BYZ5 C2G 2M DVI D M/F DIGITAL VIDEO EXT CBL In Stock £8.17
BYZ5 C2G Velocity™ DVI-D™ Male to HDMI® Female Inline Adapter In Stock £7.90
BYZ5 C2G USB to DVI Adapter Up To 2048 x 1152 In Stock £35.94
BYZ5 C2G 2m HDMI to DVI-D Digital Video Cable In Stock £7.18
BYZ5 C2G Pro DVI-D to VGA Converter - Video converter - Black In Stock £48.42
Response Time: 5ms
Speakers: None
Brand: Philips
Price Range Ex VAT: 50 - 100
