Philips D-Line 43BDL4050D 43" 1920x1080 12ms DVI HDMI DisplayPort LED Large Format Display
Quicklinx: CSKSWS00 Mfr#: 43BDL4050D/00
TV Tuner Presence: No
Video Interface: HDMI
  • USB
  • 1080p (Full HD)
£594.94 ex VAT
£713.92 inc VAT
Amaze your guests with a smarter, faster, signage display. With integrated Wi-Fi and capable of running Android apps, it's the next evolution in signage solutions
  • Powered by Android
    With Android OS integrated into the display, you can work with the Android OS and save your own app directly into the display. With the built-in scheduler, you can daypart your apps and content based on your customer and time of day and with the auto orientation feature, showing content in portrait or landscape is as simple as turning the display.
  • CMND
    A robust display management platform, CMND puts the power back into your hands. With the display management module, install and maintain all connected displays remotely and from one central location. With the content management module, manage and update your content (in both portrait and landscape), in real time, with the simple yet robust drag and drop interface.
  • FailOver
    Keeping your content up and running is critical for demanding commercial applications. While it is unlikely you will face a content disaster, FailOver provides 24/7 protection with a revolutionary technology that plays back-up content on screen in the event of a media player failure. FailOver automatically kicks in when the primary input fails. Simply select a primary input connection and a FailOver connection and your ready for instant protection.
  • Internal memory
    Save and play content with internal memory. Upload your media into the display and playback content immediately. Working in conjunction with the internal browser, it also serves as a memory cache when streaming online content. If the network ever fails, the internal memory keeps content running by playing a cached version of the content, ensuring that your media stays up even if the network goes down.
  • SmartPower
    The backlight intensity can be controlled and preset by the system to reduce the power consumption, which saves substantially on energy costs.
  • PCI slot
    With an integrated PCI slot, you can connect an extra Wi-Fi / Bluetooth or 4G LTE module, allowing for even greater communication with the display.
Philips 43BDL4050D D-Line - 43" Class (42.5" viewable) LED-backlit LCD display - Full HD
LED-backlit LCD flat panel display
Diagonal Class
43"
Diagonal Size
42.5"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Input Video Formats
1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
Video Interface
HDMI
HDMI Ports Qty
2 ports
LAN
PC Interface
DVI, DisplayPort, USB
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Picture Enhancements
Dynamic contrast enhancement, Pixel Shift, Low Bright
Speaker System
2 speakers
Storage Drive Capacity
16 GB
Storage Capacity
16 GB
Supported Memory Cards
microSD
USB
Remote control, remote control, batteries
Voltage
Energy Class
Class A
59 Watt
Power Consumption (On mode)
56 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
82 kWh
96.52 cm x 4.572 cm x 55.88 cm
10.7 kg
Environmental Standards
ENERGY STAR Qualified
3-year warranty
Energy Class
Class A
59 Watt
56 W
82 kWh
Diagonal Class
43"
Diagonal Size
42.5"
Commercial Use
Series
D-Line
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
Dimensions
Without stand
96.52 cm
4.572 cm
55.88 cm
10.7 kg
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Coating
Anti-glare
Image Contrast Ratio
1100:1
Dynamic Contrast Ratio
500000:1
Brightness
450 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pull-Down Compensation
3:2, 2:2
Response Time
12 ms
Display Menu Language
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese
3D MA deinterlacing, security lock slot (cable lock sold separately), Motion Compensation
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
400 x 400 mm
Video Features
Input Video Formats
Supported Computer Resolutions
1366 x 768, 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1360 x 768, 1920 x 1080, 1440 x 900, 1280 x 800
Media Player
Supported Video Formats
MPEG-4, WMV, MKV, VOB, TS, M2TS, M4V, MPG, MPEG, MTS, MK3D, TTS
Supported Audio Formats
MP3, WMA, WAV, AAC, AIFF, LPCM, M4A, AIF, ASF, M3U, MP4
Supported Pictures Formats
BMP, JPG, GIF, JPEG
microSD
USB Port
Configuration
ARM Cortex-A9 Quad-Core ( 1.8 GHz ) - 2 GB DDR3 - 16 GB - Mali 400
16 GB
Operating System
Android OS
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - 10 Watt
Network & Internet Multimedia
LAN
Connector Type
DisplayPort input , 2 x HDMI input , DVI-D input , USB , DisplayPort output , DVI-I output , Audio line-in , Audio line-in , Audio line-out , Speakers output , Network , Serial input , Remote control input , USB , USB , Serial output , Remote control output
Remote control, batteries
Serial cable
FCC Class B certified, UL, VCCI, C-Tick, BSMI, GOST, cUL, CB, CCC, RoHS, PSE Mark, J-MOSS
ENERGY STAR Certified
ENERGY STAR Version
7.0
Power supply
Input Voltage
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
Smart power
Limited warranty - 3 years
20 - 80%
Brand: Philips
Price Range Ex VAT: £500 - £750
