This Philips display is ideal for an everyday clinical care environment. D-image pre-set gives you consistent DICOM Grayscale medical images. Its medical-grade power supply ensures basic safety. Anti-microbial housing inhibits bacterial growth.
Clinical D-image
Monitors must show medical images consistently with high quality to achieve reliable interpretations. The rendering of medical Grayscale images on standard monitors is mostly inconsistent at best, making them unsuitable for use in a clinical environment. Philips clinical review displays with clinical D-image pre-set are factorycalibrated to give DICOM part 14 compatible Grayscale standard display performance. By using high-quality LCD panels with LED technology, Philips offers you consistent and reliable performance at an affordable price. -
Antimicrobial housing
Germs have become a growing problem in hospitals and clinical environments worldwide as they can cause life-threatening infections. Philips clinical review displays take care of this challenge by using a JIS Z2801-compliant antimicrobial additive in its housing material making it an integral part of the display housing. Your wellbeing, along with your patients, is now assured by this protective shield that impedes the growth of the most common microorganisms, such as "Staphylococcus aureus (Gastroenteritis)", "Escherichia coli (E Coli)" and "Klebsiella (Pneumonia)", for example. -
Medical-grade power supply
Basic safety, essential performance and reliability are essential requirements in a professional clinical environment. Unlike standard displays, Philips clinical review displays employ special medical-grade power supplies in order to meet these requirements. It complies with the EN/IEC 60601-1 standard ensuring basic safety and essential performance. It also complies with the EN/IEC 60601-1-2 collateral standard for medicalgrade electromagnetic tests and compatibility. Many countries, hospitals and clinics mandate compliance to these standards as a requirement. -
IPS technology
IPS displays use an advanced technology that gives you extra wide viewing angles of 178/178 degrees, making it possible to view the display from almost any angle - even in 90 degree Pivot mode! Unlike standard TN panels, IPS displays gives you remarkably crisp images with vivid colors, making it ideal not only for Photos, movies and web browsing, but also for professional applications, which demand color accuracy and consistent brightness at all times. -
PowerSensor
PowerSensor is a built-in 'people sensor' that transmits and receives harmless infrared signals to determine if the user is present and then automatically reduces monitor brightness when then user steps away from the desk, cutting energy costs by up to 80 percent and prolonging monitor life. -
DisplayPort
DisplayPort is a digital link from PC to monitor without any conversion. With higher capabilities than DVI standard, it is fully capable to support up to 15 meter cables and 10.8 Gbps/sec data transfer. With this high performance and zero latency, you get the fastest imaging and refresh rates - making DisplayPort the best choice for not only general office or home use, but also for the more demanding gaming and films, video editing and more. It also keeps interoperability in mind via the use of various adapters. -
SmartErgoBase
The SmartErgoBase is a monitor base that delivers ergonomic display comfort and provides cable management. The user-friendly height, swivel, tilt and rotation angle adjustments of the base allow the monitor to be positioned for maximum comfort to help ease the physical strains of a long workday. In addition, cable management reduces cable clutter and keeps the workspace neat and professional. -
Low bezel-to-table height
Thanks to its advanced SmartErgoBase, the Philips monitor can be lowered down almost to desk level for a comfortable viewing angle. Low bezel-to-table height is the perfect solution if you use bifocals, trifocals or progressive lens glasses for your computing work. Additionally, it allows users of different heights to use the monitor at their preferred angle and height settings, helping them to reduce fatigue and strain.
- Philips Brilliance C240P4QPYEW - LED monitor - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class A+
- Energy Consumption per Year
- 25 kWh
- Power Consumption (On mode)
- 17 W
- Panel Type
- IPS
- Aspect Ratio
- 16:10
- Native Resolution
- Full HD 1920 x 1200 at 60 Hz
- Pixel Pitch
- 0.27 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 14 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- White
- 55.5 cm x 24.4 cm x 55 cm
- 6.97 kg
- Environmental Standards
- ENERGY STAR Qualified
- TUV GS, GOST, TUV Ergo, RoHS, Lead-Free, WEEE, DICOM Part 14, IEC 60601-1
- 3-year warranty
- Display Type
- Energy Class
- Class A+
- 25 kWh
- Diagonal Size
- 24"
- Panel Type
- IPS
- Aspect Ratio
- 16:10
- Native Resolution
- Pixel Pitch
- 0.27 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Response Time
- 14 ms
- Vertical Refresh Rate
- 48 - 85 Hz
- Horizontal Refresh Rate
- 24 - 94 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- WLED
- OSD Languages
- Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish
- PowerSensor, Smart Ergo base, SmartControl Premium, SmartImage Clinic, Clinical D-image
- White
- 55.5 cm x 24.4 cm x 55 cm - with stand
- 6.97 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 4 Watt
- DVI-D , VGA , DisplayPort , 4 x USB 2.0 , Headphones , Audio line-in
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 130
- Rotation Angle
- 90
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), antimicrobial finish
- MTBF
- 30,000 hour(s)
- Power Supply
- External
- Input Voltage
- 17 W
- Power Consumption Stand by
- 0.4 Watt
- On / Off Switch
- OS Required
- Apple MacOS X, Microsoft Windows Vista / 7 / 8
- Dimensions & Weight Details
- With stand - width: 55.5 cm - depth: 24.4 cm - height: 55 cm - weight: 6.97 kg , Without stand - width: 55.5 cm - depth: 6.5 cm - height: 38.8 cm - weight: 4.64 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 20 - 80%
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £12.92 |
