This Philips USB monitor is ideal for usage in mobile clinical environment where AC power may not be conveniently accessible. Simply connect it with a single USB cable from your notebook to deliver video and power.
AntiMicrobial housing
Germs have become a growing problem in hospitals and clinical environments worldwide as they can cause life-threatening infections. Philips clinical review displays take care of this challenge by using JIS Z2801 compliant antimicrobial additive in its housing material making it an integral part of the display housing. Your well being along with your patients is now assured by this protective shield that impedes the growth of most common microorganisms such as "Staphylococcus aureus (Gastroenteritis)", "Escherichia coli (E Coli)" and "Klebsiella (Pneumonia)", for example. -
Medical grade power supply
Basic safety, essential performance and reliability are essential requirements in a professional clinical environment. Unlike standard displays, Philips clinical review displays employ special medical grade power supplies in order to meet these requirements. It complies with EN/IEC 60601-1 standard ensuring basic safety and essential performance. Additionally it also complies with EN/IEC 60601-1-2 collateral standard for medical grade electromagnetic tests and compatibility. Many countries, hospitals and clinics mandate compliance to these standards as a requirement. -
LED technology
White LED's are solid state devices which light up to full, consistent brightness faster saving startup time. LED's are free from mercury content which allows for eco-friendly recycling and disposal process. LED's allow for better dimming control of LCD backlight, resulting in super high contrast ratio. It also gives superior color reproduction thanks to consistent brightness across the screen. -
USB Power, Video
Philips USB monitor is capable of displaying images and drawing power directly from your laptop USB ports with a single USB cable. No extra power or video cables are required resulting in a simple, single cable, extra low power connection between your laptop and monitor. -
70mm height adjustment
The Compact Ergo Base is a 'people friendly' Philips monitor base that tilts, swivels and is height adjustable so each user can position the monitor for maximum viewing comfort and efficiency. -
Screen tilt and swivel
Screen tilt and swivel is a mechanism built into the base permits the monitor to swivel and tilt backward or forward.
- Philips C221S3UCW - LED monitor - Full HD (1080p) - 21.5"
- LED-backlit LCD monitor - 21.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.248 mm
- Brightness
- 150 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- USB
- Height, swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Textured white
- 50.7 cm x 20.1 cm x 40.2 cm
- 3.85 kg
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, RoHS, Lead-Free, WEEE, EN 60601-1-2, EN 60601-1
- 3-year warranty
- Display Type
- Diagonal Size
- 21.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.248 mm
- Brightness
- 150 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Response Time
- 5 ms
- Horizontal Viewing Angle
- 160
- Vertical Viewing Angle
- 150
- Backlight Technology
- WLED
- OSD Languages
- Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish
- sRGB colour management, Smart Ergo base
- Textured white
- 50.7 cm x 20.1 cm x 40.2 cm - with stand
- 3.85 kg
- USB 2.0
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 130
- Height Adjustment
- 70 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), antibacterial
- MTBF
- 30,000 hour(s)
- Power Supply
- Internal
- Input Voltage
- Power Consumption (Typical)
- 10.3 Watt
- Power Consumption Stand by
- 0.3 Watt
- OS Required
- Apple MacOS X, Microsoft Windows 7, Microsoft Windows Vista, Windows 8
- Dimensions & Weight Details
- With stand - width: 50.7 cm - depth: 20.1 cm - height: 40.2 cm - weight: 3.85 kg , Without stand - width: 50.7 cm - depth: 5.9 cm - height: 32.3 cm - weight: 3.44 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 20 - 80%
