See more and do more with the Philips Brilliance 34" curved ultra-wide display. A crystal-clear wide Quad HD curved display puts you at the centre of the desktop. All-in-one USB-C and a height-adjustable stand make for the ultimate set-up.
LowBlue Mode
Studies have shown that just as ultra-violet rays can cause eye damage, shortwave-length blue light rays from LED displays can cause eye damage and affect vision over time. Developed for wellbeing, the Philips LowBlue Mode setting uses a smart software technology to reduce harmful shortwave blue light. -
Ultra-narrow Border
The new Philips displays feature ultra-narrow borders which allow for minimal distractions and maximum viewing size. Especially suited for multi-display or tiling setups like gaming, graphic design and professional applications, the ultra-narrow border display gives you the feeling of using one large display. -
Ultra Wide-Color Technology
Ultra Wide-Color Technology delivers a wider spectrum of colours for a more brilliant picture. The Ultra Wide-Color wider"colour gamut" produces more natural-looking greens, vivid reds and deeper blues. Bring media entertainment, images and even productivity more alive with vivid colours from Ultra Wide-Color Technology. -
Curved display design
Desktop monitors offer a personal user experience, which suits a curved design very well. The curved screen provides a pleasant yet subtle immersion effect, which focuses on you at the centre of your desk. -
MultiView technology
With the ultra-high resolution Philips MultiView display, you can now experience a world of connectivity. MultiView enables active dual connect and view so that you can work with multiple devices like a PC and notebook simultaneously, for complex multitasking. -
UltraWide CrystalClear images
These Philips screens deliver Crystal Clear, UltraWide Quad HD 3440 x 1440 pixel images. Utilising high-performance panels with high-density pixel count and 178/178 wide viewing angles, these new displays will make your images and graphics come alive. The UltraWide 21:9 format enables more productivity with more room for side-by-side comparisons and more viewable spreadsheet columns. Whether you are a demanding professional requiring extremely detailed information for CAD-CAM solutions or a financial wizard working on huge spreadsheets, Philips displays deliver Crystal Clear images. -
USB-C Docking
The new USB 3.1 Type-C cable with features a slim and reversible connector and offers easy one-cable docking. With USB 3.1 you get the fastest data speeds, 20 times as fast as USB 2.0, allowing you to transfer data from a HDD to your PC faster than ever. Simplify by connecting all your peripherals to your monitor as a dock with one cable to the notebook, including high resolution video output from your PC to monitor. Additionally, USB-C with power delivery even allows you to power and charge your notebook from the monitor, eliminating the need for extra power cables. -
Compact Ergo Base
The Compact Ergo Base is a people-friendly Philips monitor base that tilts, swivels and height-adjusts so each user can position the monitor for maximum viewing comfort and efficiency. -
100 Hz fast refresh
For gaming and video performance, you demand display with lag-free, ultra-smooth images. This Philips display redraws the screen image up to 100 times per second, much faster than a standard display. A lower frame rate can make enemies appear to jump from spot to spot on the screen, making them difficult targets to hit. With a 100-Hz frame rate, you get those critical missing images on the screen, showing enemy movement in ultra-smooth motion so you can easily target them.
- Philips Brilliance P-line 349P7FUBEB - LED monitor - curved - 34"
- LED-backlit LCD monitor - 34"
- Energy Class
- Class C
- Energy Consumption per Year
- 113 kWh
- Power Consumption (On mode)
- 77 W
- Curved Screen
- USB 3.0 hub
- Panel Type
- MVA
- Aspect Ratio
- 21:9
- Native Resolution
- Ultra WQHD 3440 x 1440 at 100 Hz
- Pixel Pitch
- 0.232 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 3000:1 / 100000000:1 (dynamic)
- Response Time
- 4 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DisplayPort, USB-C
- Height, swivel, tilt
- Screen Coating
- Anti-glare, Haze 25%
- Silver, textured black
- 81 cm x 31.1 cm x 62.1 cm
- 9.6 kg
- Plug and Play, TUV, GS, SEMKO, CB, DDC/CI, RoHS, Lead-Free, ISO 9241-307, WEEE, MEPS, RCM, CU-EAC
- 3-year warranty
- Display Type
- Energy Class
- Class C
- 113 kWh
- 77 W
- Diagonal Size
- 34"
- Curved Screen
- Yes (1800R)
- Built-in Devices
- USB 3.0 hub
- Panel Type
- MVA
- Aspect Ratio
- 21:9
- Native Resolution
- Pixel Pitch
- 0.232 mm
- Pixel Per Inch
- 109.68
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 23 - 102 Hz
- Horizontal Refresh Rate
- 30 - 160 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- WLED
- OSD Languages
- Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
- Sync on Green, Compact Ergo Base, MultiView, Crystal Clear, SmartImage, Low Blue Light Mode, Flicker Free technology, Mercury free, Adaptive-Sync technology, USB-C Docking, Narrow Border Display, Picture-in-Picture, Picture-by-Picture, 99.8% NTSC colour gamut, 117.3% sRGB colour gamut
- 81 cm x 31.1 cm x 62.1 cm - with stand
- 9.6 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 5 Watt
- DisplayPort , USB-C (power up to 60W) , HDMI , 2 x USB 3.0 (Type A) , Audio line-in , Headphones , USB 3.0 (fast charging)
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 340
- Height Adjustment
- 180 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x USB-C cable , 1 x USB-C to USB-A cable , 1 x HDMI cable , 1 x DisplayPort cable , 1 x audio cable
- MTBF
- 50,000 hour(s)
- Security Slot Type
- Kensington security slot
- Voltage Required
- AC 120/230 V (50/60 Hz)
- 67.09 Watt
- Power Consumption Stand by
- 0.5 Watt
- 0.3 Watt
- Dimensions & Weight Details
- With stand - width: 81 cm - depth: 31.1 cm - height: 62.1 cm - weight: 9.6 kg , Without stand - width: 81 cm - depth: 9.8 cm - height: 36.9 cm - weight: 6.6 kg
- Shipping Width
- 94.4 cm
- Shipping Depth
- 22.4 cm
- Shipping Height
- 57.8 cm
- Shipping Weight
- 14.88 kg
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 20 - 80%
Bundle includes:
Microsoft Office 365 Business Premium ‘in a box’ 1 year subscription/license worth £99.17 | in stock |
£640.01
