The Philips PowerSensor AMVA LED display using 65% post consumer recycled plastics and PVC, BFR free housing is ideal for eco-friendly productivity.
The Philips monitor can be lowered down almost to desk level for a comfortable viewing angle. Low bezel-to-table height is the perfect solution if you use bifocals, trifocals or progressive lens glasses for your computing work. Additionally, it allows for users with greatly different heights to use the monitor in their preferred angle and height settings, helping them reduce fatigue and strain.
PowerSensor
PowerSensor is a built-in 'people sensor' that transmits and receives harmless infrared signals to determine if user is present and automatically reduces monitor brightness when user steps away from the desk, cutting energy costs by up to 80-percent and prolonging monitor life. -
AMVA LED display
Philips AMVA LED display uses an advanced multi-domain vertical alignment technology which gives you super-high static contrast ratios for extra vivid and bright images. While standard office applications are handled with ease, it is especially suitable for photos, web-browsing, movies, gaming, and demanding graphical applications. It's optimized pixel management technology gives you 178/178-degree extra wide viewing angle, resulting in crisp images even in 90-degree pivot mode. -
DisplayPort
DisplayPort is a digital link from PC to Monitor without any conversion. With higher capabilities than DVI standard, it is fully capable to support up to 15-meter cables and 10.8 Gbps/sec data transfer. With this high performance and zero latency, you get the fastest imaging and refresh rates - making DisplayPort the best choice for not only general office or home use, but also for the demanding gaming and movies, video editing and more. It also keeps interoperability in mind via use of various adapters. -
SmartErgoBase
The SmartErgoBase is a monitor base that delivers ergonomic display comfort and provides cable management. The base's people-friendly height, swivel, tilt and rotation angle adjustments position the monitor for maximum comfort that can ease the physical strains of a long workday; cable management reduces cable clutter and keeps the workspace neat and professional. -
4-port USB 2.0 hub
USB hub allows user to conveniently connect their plug and play multimedia devices such as USB memory devices, camera, portable HDD, web camera, PDA, printer and many other devices which has USB connection. The conveniently located USB 2.0 hub on the monitor allows USB 2.0 signals to pass thru to the computer. -
The Philips monitor, thanks to its advanced SmartErgoBase, can be lowered down almost to desk level for a comfortable viewing angle. Low bezel-to-table height is the perfect solution if you use bifocals, trifocals or progressive lens glasses for your computing work. Additionally, it allows for users with greatly different heights to use the monitor in their preferred angle and height settings, helping them reduce fatigue and strain. -
SmartImage
SmartImage is an exclusive leading edge Philips technology that analyzes the content displayed on your screen and gives you optimized display performance. This user friendly interface allows you to select various modes like office, photo, movie, game, economy etc., to fit the application in use. Based on the selection, SmartImage dynamically optimizes the contrast, color saturation and sharpness of images and videos for ultimate display performance. The Economy mode option offers you major power savings. All in real time with the press of a single button! -
TCO Edge
TCO Edge certification is given to products which go beyond existing eco-labeling programs. Over and above standard TCO requirements, it further mandates that the product uses minimum 65% of post consumer recycled plastics, is energy efficient, uses minimal hazardous materials, has 100% recyclable packaging, and is designed for easy recycling amongst other requirements. You can rest assured that this Philips monitor is a cutting edge technology product which is best in class ICT, benefiting you and the planet while helping you make a responsible green IT purchase! -
PVC-BFR free housing
This Philips monitor housing is free from brominated flame retardant and polyvinyl chloride (PVC-BFR free).
- Philips Brilliance P-line 241P4QPYES - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Stereo speakers, USB Hub
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.276 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 5000:1 / 20000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA, DisplayPort
- Speakers
- Integrated
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black, silver
- 56.5 cm x 22 cm x 51.8 cm
- 5.9 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- FCC Class B certified, UL, TUV GS, BSMI, GOST, cUL, SASO, SEMKO, TUV Ergo, DDC/CI, RoHS, Lead-Free, WEEE
- 3-year warranty
- Display Type
- Diagonal Size
- 24"
- Built-in Devices
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.276 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 75 Hz
- Horizontal Refresh Rate
- 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- WLED
- Controls & Adjustments
- Volume, brightness
- OSD Languages
- Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish
- Sync on Green, sRGB colour management, HDCP, Lead-free, Eco-Mode, PowerSensor, SmartContrast, SmartImage
- Black, silver
- 56.5 cm x 22 cm x 51.8 cm - with stand
- 5.9 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 1.5 Watt
- VGA , DVI-D , 4 x USB 2.0 , Audio line-in , Headphones , DisplayPort
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 130
- Rotation Angle
- 90
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- MTBF
- 30,000 hour(s)
- Power Supply
- Internal
- Input Voltage
- Power Consumption (Typical)
- 23.4 Watt
- Power Consumption Stand by / Sleep
- 0.1 Watt
- Included Software
- Philips SmartControl Premium
- OS Required
- Apple MacOS X, Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista
- Dimensions & Weight Details
- With stand - width: 56.5 cm - depth: 22 cm - height: 51.8 cm - weight: 5.9 kg , Without stand - width: 56.5 cm - depth: 5.5 cm - height: 35.2 cm - weight: 3.8 kg
- ENERGY STAR Certified
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 20 - 80%
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £13.17 |
