This Philips 27" display will amaze you with its Crystalclear Quad HD 2560 x 1440 images and brilliant colors. MultiView allows active dual connect and view. Its 2-magepixel webcam enables you to socialize.
PLS Quad HD
This professional Philips display uses the latest PLS Quad HD panel giving you ultra high-res brilliant wide angle images with 2560 x 1440 pixel resolution. With excellent 8-bit color depth combined with 109 ppi density, you can now enjoy professional true color sRGB images compared to limited 6-bit color depth displays with 82 ppi density. Its higher brightness and lower power consumption compared to conventional wide view angle displays ensure you always have brilliant performance, while saving energy too. -
Crystalclear images
These latest Philips screens deliver Crystalcl ear, Quad HD 2560 x 1440 or 2560 x 1080 pixel images. Whether you are demanding professional requiring extremely detailed information for CAD-CAM solutions, using 3D graphic applications or a financial wizard working on huge spreadsheets, Philips displays will give you Crystalclear images. -
PowerSensor
PowerSensor is a built-in 'people sensor' that transmits and receives harmless infrared signals to determine if the user is present and then automatically reduces monitor brightness when then user steps away from the desk, cutting energy costs by up to 80 percent and prolonging monitor life. -
Socialize with webcam
Embedded 2-megapixel webcam with superb, bright and crisp images enables you to socialize with your family and friends. Its sensitive microphone ensures that your voice carries through clearly. You can hear clear audio either from its built-in stereo speakers, or attach your own headphones for private conversations. This simple built-in solution ensures you don't have to get in a tangle anymore with installing a camera and positioning microphones. -
MultiView technology
With the ultra high resolution Philips MultiView display you can now experience a world of connectivity in comfort whether at the office or at home. MultiView enables active dual connect and view so that you can work with multiple devices like a PC and Notebook side-by-side simultaneously, making complex multi-tasking work a breeze. Watching live football feeds from your set-top box on the right-hand side, while browsing the Internet from your notebook on the left is now easy. You may want to keep an eye on the live news feed with audio in the small window, while working on your latest blog. -
Display port with daisy chain
This Philips display employs Display port 1.2a Multi Stream Transport (MST) technology with HBR2, which doubles the data throughput to 21.6 Gbps. This enables it to daisy chain multiple monitors, thereby dramatically increasing your efficiency. This daisy chain, multi-monitor capability makes this Philips display especially suitable for use in Finance, Banking, control rooms and other similar environments. To make use of this feature, your PC Graphics Card must be certified to DP1.2 with the MST option. -
SmartConnect
With a plethora of connectivity, these Philips displays come equipped with multi connections like Dual link DVI, Display Port, universal HDMI connector or optional Thunderbolt, enabling you to enjoy high resolution uncompressed video and audio content. USB 3.0 option ensures that you can have super speed data transfers while having global connectivity. Regardless of what source you use, you can rest assured that this Philips display will ensure your investment is not made obsolete any time soon! -
SmartImage
SmartImage is an exclusive leading edge Philips technology that analyzes the content displayed on your screen and optimizes your display performance. This user-friendly interface allows you to select various modes, like office, photo, movie, game, economy etc., to fit the application in use. Based on the selection, SmartImage dynamically optimizes the contrast, color saturation and sharpness of images and videos for ultimate display performance. The Economy mode option offers you major power savings. All in real time at the touch of a single button! -
SmartKolor
SmartKolor is a sophisticated color extension technology that is able to enhance the visual color range of the display. By boosting the RGB gain level of the display, you can achieve rich, vibrant images to experience outstanding photos and videos.
- Philips Brilliance 272C4QPJKAB - LED monitor - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class B
- Energy Consumption per Year
- 62 kWh
- Power Consumption (On mode)
- 42 W
- 2.0 megapixel camera
- Panel Type
- Plane to Line Switching (PLS)
- Aspect Ratio
- 16:9
- Native Resolution
- QHD 2560 x 1440 at 60 Hz
- Pixel Pitch
- 0.233 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1 / 20000000:1 (dynamic)
- Response Time
- 6 ms (grey-to-grey), 12 ms (typical)
- Colour Support
- 16.7 million colours
- Input Connectors
- 2xHDMI, DVI-D, DisplayPort
- Speakers
- Integrated
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Textured black with black stand
- 63.9 cm x 19.7 cm x 49.5 cm
- 6.3 kg
- Environmental Standards
- ENERGY STAR Qualified EPEAT Silver
- Plug and Play, FCC Class B certified, UL, TUV GS, BSMI, GOST, cUL, SASO, SEMKO, TUV Ergo, DDC/CI, RoHS, Lead-Free, WEEE
- 3-year warranty
- Display Type
- Energy Class
- Class B
- 62 kWh
- Diagonal Size
- 27"
- Built-in Devices
- Panel Type
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.233 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 56 - 75 Hz
- Horizontal Refresh Rate
- 30 - 90 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- WLED
- Controls & Adjustments
- Brightness
- OSD Languages
- Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish
- Picture in picture, picture by picture, Sync on Green, sRGB colour management, PowerSensor, SmartResponse, MultiView, Crystal Clear, SmartContrast, SmartImage, SmartKolor, SmartTxt
- 63.9 cm x 19.7 cm x 49.5 cm - with stand
- 6.3 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 2 Watt
- DVI-D (dual link) (HDCP) , Audio line-in , Headphones , DisplayPort , 2 x HDMI
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- VESA Mounting Interface
- 100 x 100 mm
- MTBF
- 30,000 hour(s)
- Power Supply
- Internal
- Input Voltage
- 42 W
- Power Consumption (Typical)
- 38 Watt
- Power Consumption Stand by
- 0.4 Watt
- On / Off Switch
- OS Required
- Apple MacOS X, Microsoft Windows XP, Microsoft Windows 7, Windows 8
- Dimensions & Weight Details
- With stand - width: 63.9 cm - depth: 19.7 cm - height: 49.5 cm - weight: 6.3 kg , Without stand - width: 63.9 cm - depth: 6.4 cm - height: 40.5 cm - weight: 5.6 kg
Sustainability Information
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 20 - 80%
