Your basket is empty
Philips Brilliance 27" LED 2560x1440 DVI HDMI Monitor
Quicklinx: 8RDKWS00 Mfr#: 272P4QPJKEB/00
This professional Philips PLS display delivers Crystalclear Quad HD 2560 x 1440 images. MultiView enhances productivity with active dual connect and view. Webcam enables collaboration saving time and money.
Philips Brilliance 272P4QPJKEB - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
59 kWh
Power Consumption (On mode)
40 W
USB Hub, 2.0 megapixel camera
Panel Type
Plane to Line Switching (PLS)
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 60 Hz
Pixel Pitch
0.233 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
12 ms (typical); 6 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
2xHDMI, DVI-D, DisplayPort
Speakers
Integrated
Display Position Adjustments
Textured black with black stand
63.9 cm x 24.2 cm x 58 cm
8.5 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, UL, TUV GS, BSMI, GOST, cUL, SASO, SEMKO, TUV Ergo, DDC/CI, RoHS, Lead-Free, WEEE, TCO Certified Edge, TCO Displays 6.0
3 years warranty
Display Type
Energy Class
Class B
59 kWh
40 W
Diagonal Size
27"
Built-in Devices
Panel Type
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.233 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 90 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
Controls & Adjustments
Volume, brightness
OSD Languages
Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish
Sync on Green, sRGB colour management, PowerSensor, SmartResponse, SmartContrast, SmartImage, Smart Ergo base
63.9 cm x 24.2 cm x 58 cm - with stand
8.5 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
DVI-D (HDCP) , 3 x USB 2.0 , Audio line-in , Headphones , DisplayPort , 2 x HDMI
Mechanical
Tilt Angle
-5/+20
Swivel Angle
130
Rotation Angle
90
Height Adjustment
150 mm
Flat Panel Mount Interface
100 x 100 mm
Power Supply
Internal
39.2 Watt
Power Consumption Stand by
0.3 Watt
On / Off Switch
Included Software
Philips SmartControl Premium
Apple MacOS X, Microsoft Windows XP, Microsoft Windows 7, Windows 8
Dimensions & Weight Details
With stand - width: 63.9 cm - depth: 24.2 cm - height: 58 cm - weight: 8.5 kg , Without stand - width: 63.9 cm - depth: 6.4 cm - height: 40.5 cm - weight: 5.7 kg
ENERGY STAR Certified
Limited warranty - 3 years
20 - 80%
8RDK C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
8RDK C2G 0.5m Select High Speed HDMI with Ethernet In Stock £5.76
8RDK C2G 5m Select High Speed HDMI with Ethernet In Stock £15.70
8RDK C2G 10m Select High Speed HDMI with Ethernet In Stock £30.15
8RDK C2G 15m Select High Speed HDMI with Ethernet In Stock £40.84
8RDK C2G Pro HDMI to VGA Converter In Stock £46.35
