This advanced Philips gaming display redraws the screen upto 144 times per second for ultra smooth, brilliant images. SmartFrame helps you highlight specific screen area. Special gaming pre-sets and remote smart keypad keeps you in control.
144Hz gaming
You play intense, competitive gaming. You demand display with lag free, ultra smooth images. This Philips display redraws the screen image upto 144 times per second, effectively 2.4x faster than a standard display. A lower frame rate can make enemies appear to jump from spot to spot on the screen, making them difficult targets to hit. With 144 Hz frame rate, you get those critical missing images on the screen which shows enemy movement in ultra smooth motion so you can easily target them. With ultra low input lag and no screen tearing, this Philips display is your perfect gaming partner -
MHL technology
Mobile High Definition Link (MHL) is a mobile audio/video interface for directly connecting mobile phones and other portable devices to high-definition displays. An optional MHL cable allows you to simply connect your MHL capable mobile device to this large Philips MHL display, and watch your HD videos come to life with full digital sound. Now not only you can enjoy your mobile games, photos, movies, or other apps on its big screen, you can simultaneously charge your mobile device so you never run out of power half way. -
SmartImage game mode
The Philips gaming display has quick access OSD fine tuned for gamers, offering you multiple options. "FPS" mode (First person shooting) improves dark themes in games, allowing you to see hidden objects in dark areas. "Racing" mode adapts display with fastest response time, high color, along with image adjustments. "RTS" mode (Real time strategy) has a special SmartFrame mode which enables highlighting of specific area and allows for size and image adjustments. Gamer 1 and Gamer 2 enable you to save personal customized settings based on different games, ensuring best performance. -
SmartFrame
SmartFrame enables you to spot your opponents easily by highlighting a specific area on the screen. By boosting the gain level of RGB in the selected area, it allows you to give more attention to that specific part of the screen where you expect sudden enemy movement. You can also adjust size and image to your preference. It is especially suitable for RTS- Real Time Strategy mode games. -
SmartConnect
With a plethora of connectivity, these Philips displays come equipped with multi connections like Dual link DVI, Display Port, universal HDMI connector, enabling you to enjoy high resolution uncompressed video and audio content. USB 3.0 option ensures that you can have super speed data transfers while having global connectivity. Regardless of what source you use, you can rest assured that this Philips display will ensure your investment is not made obsolete any time soon! -
SmartSize
SmartSize allows you to change the screen view of this Philips gaming display to suit your preference. Using the SmartSize function, you can easily swap between 10 different screen sizes, from 17" (5:4), 19" (5:4), 18.5" (16:9), 19"w (16:10), 19.5" (16:9), 20" (16:9), 21.5"W (16:9), 22"W (16:10), 23"W (16:9) and 24"W (16:9). Now you have the flexibility to simulate and practice gaming in different sizes, while using a single display. -
SmartKeypad
SmartKeypad is a specially designed remote controller that connects to this Philips gaming display. It enables fast and convenient access to your gaming presets with 2 quick key access buttons, allowing you to save and activate two personalized custom settings either for gaming or other purposes. With additional up and down function keys, you can now easily navigate in the OSD menu and settings directly.
- Philips Brilliance 242G5DJEB - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class B
- Energy Consumption per Year
- 48 kWh
- Power Consumption (On mode)
- 33 W
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.277 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1 / 80000000:1 (dynamic)
- Response Time
- 1 ms (grey-to-grey), 5 ms (typical)
- Colour Support
- 16.7 million colours
- Input Connectors
- 2xHDMI, DVI-D, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Textured black
- 56.5 cm x 22 cm x 51.7 cm
- 6.27 kg
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, FCC Class B certified, TUV GS, BSMI, GOST, SASO, SEMKO, TUV Ergo, PSB, DDC/CI, RoHS, Lead-Free, WEEE
- 3-year warranty
- Display Type
- Energy Class
- Class B
- 48 kWh
- Diagonal Size
- 24"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.277 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 56 - 120 Hz
- Horizontal Refresh Rate
- 30 - 140 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- WLED
- OSD Languages
- Hungarian, Czech, Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Russian, Dutch, Greek, Turkish, Japanese, Korean
- Sync on Green, sRGB colour management, HDCP, SmartResponse, SmartContrast, Mobile High-Definition Link (MHL), Smart Frame, SmartConnect, SmartImage Game, SmartLeypad
- Textured black
- 56.5 cm x 22 cm x 51.7 cm - with stand
- 6.27 kg
- DVI-D (dual link) , VGA , DisplayPort , 2 x HDMI (HDCP) , 4 x USB 3.0
Mechanical
- Tilt Angle
- 25
- Swivel Angle
- 130
- Rotation Angle
- 90
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- MTBF
- 30,000 hour(s)
- Power Supply
- Internal
- Input Voltage
- 33 W
- Power Consumption (Typical)
- 18.58 Watt
- Power Consumption Stand by
- 0.5 Watt
- OS Required
- Apple MacOS X, Microsoft Windows 7, Windows 8
- Dimensions & Weight Details
- With stand - width: 56.5 cm - depth: 22 cm - height: 51.7 cm - weight: 6.27 kg , Without stand - width: 56.5 cm - depth: 6.3 cm - height: 35.4 cm - weight: 4.13 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 20 - 80%
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
