Get engaged with Philips SmoothTouch display. Groovy touch gestures like tap, grab, pinch, rotate, zoom, swipe brings your apps to life. Interactive touch games get more exciting. Now you can explore the world with 10 fingertips!
SmoothTouch
This Philips display uses projected capacitive 10 point touch technology, with edge to edge glass for fluid response. Used with touch based OS like Windows 8, it offers you groovy touch gestures like tap, grab, pinch, rotate, zoom, swipe, etc. Now you can fully utilize the capabilities of touch based applications, and bring your older applications to life. Touch-type with 10 fingers, or play exciting interactive games with your friends. Collaborate with colleagues interactively at work or school environment and increase your productivity and efficiency. -
SmartStand
This Philips display uses SmartStand with maximum lean back which enables you to use it in various ergonomic positions, like never before. With just under 60 degree lean back positions, you can now interact with the display naturally to touch and type. Or you can use it in upright position to sit and do some serious work. With built-in auto return mechanism, this SmartStand offers you a high level of flexibility. -
SmartConnect
With a plethora of connectivity, these Philips displays come equipped with multi connections like VGA, DisplayPort, universal HDMI connector, enabling you to enjoy high resolution uncompressed video and audio content. USB 3.0 option ensures that you can have super speed data transfers while having global connectivity. Regardless of what source you use, you can rest assured that this Philips display will ensure your investment is not made obsolete any time soon! -
Socialize with webcam
Embedded webcam with superb, bright and crisp images enables you to socialize with your family and friends. Its sensitive microphone ensures that your voice carries through clearly. You can hear clear audio from its built in stereo speakers, or attach your own headphones for private conversation. This simple built-in solution ensures that you don't have to tangle with installing camera and positioning microphones anymore. -
USB 3.0 Super Speed
Super Speed USB 3.0 deploys 5.0 Gbps transfer rate, which is about 10 times faster than USB 2.0 standard significantly reducing data transfer time saving you time and money. With more bandwidth, super speed transfer rates, better power management and superior overall performance, USB 3.0 sets the latest global standard allowing you to use the large capacity storage devices. Sync-N-Go technology ensures you don't have to wait anymore for bandwidth to be freed up. Your investment in USB 2.0 devices is protected as it is backward compatible. -
IPS technology
IPS displays uses an advanced technology which gives you extra wide viewing angles of 178/178-degree, making it possible to view the display from almost any angle - even in 90-degree pivot mode! Unlike standard TN panels, IPS displays gives you remarkably crisp images with vivid colors, making it ideal not only for Photos, movies and web browsing, but also for professional applications which demand color accuracy and consistent brightness at all times. -
Built-in stereo speakers
Now you can enjoy all your multimedia and social applications with stereo sound. These built in speakers not only sound great, but also helps you to get rid of external wire clutter and save valuable desktop space.
- Philips Brilliance 231C5TJKFU - LED monitor - Full HD (1080p) - 23"
- LED-backlit LCD monitor - 23" - touchscreen
- Energy Class
- Class A
- Energy Consumption per Year
- 31 kWh
- Power Consumption (On mode)
- 22 W
- 1.0 megapixel camera
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.265 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 20000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey), 14 ms (typical)
- Colour Support
- 16.7 million colours
- Input Connectors
- 2xHDMI, VGA, DisplayPort
- Speakers
- Integrated
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Cool grey, high glossy cool grey, textured cool grey
- 56.3 cm x 7.2 cm x 40.6 cm
- 5.16 kg
- Plug and Play, FCC Class B certified, BSMI, GOST, SASO, SEMKO, RoHS, Lead-Free, ISO 9241-307, WEEE
- 3-year warranty
- Display Type
- Energy Class
- Class A
- 31 kWh
- Diagonal Size
- 23"
- Built-in Devices
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.265 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 56 - 75 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- WLED
- OSD Languages
- Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
- Sync on Green, sRGB colour management, SmartResponse, SmartImage, Mobile High-Definition Link (MHL), SmartConnect, smart stand
- 56.3 cm x 7.2 cm x 40.6 cm - with stand
- 5.16 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 2 Watt
Input
- Touchscreen
- 2 x HDMI , DisplayPort , 2 x USB 3.0
Mechanical
- Tilt
- MTBF
- 30,000 hour(s)
- Power Supply
- External
- Input Voltage
- 22 W
- Power Consumption (Typical)
- 26.27 Watt
- Power Consumption Stand by
- 0.5 Watt
- OS Required
- Apple MacOS X, Microsoft Windows 7, Windows 8
- Dimensions & Weight Details
- With stand - width: 56.3 cm - depth: 7.2 cm - height: 40.6 cm - weight: 5.16 kg , Without stand - width: 56.3 cm - depth: 4.5 cm - height: 37 cm - weight: 4.8 kg
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 20 - 80%
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
