Philips BDM4350UC 43" 3840x2160 5ms HDMI DP VGA IPS Monitor
Quicklinx: CPQNWS00 Mfr#: BDM4350UC/00
Diagonal Size: 43in
Max Resolution: 3840 x 2160
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, Mobile High-Definition Link (MHL), VGA (HD-15)
26 in stock
£441.66 ex VAT
£529.99 inc VAT
The expansive 43" class Ultra HD professional Philips display gives you the room to spread out, see the big picture and all the details in 4K Ultra High Definition (four times the resolution of Full HD).
  • Slim bezel design for a stylish look
    A slim bezel design adds a stylish look to a public display to blend in nicely in just about any environment. Furthermore, this design makes the display ideal for tiled matrix video walls.
  • Zero power consumption with 0 watt hard switch
    At the flick of the 0 watt hard switch, which is conveniently located at the back of the monitor, you can completely cut off your monitor from AC power. This results in zero power consumption, reducing your carbon footprint even further
  • SmartImage pre-sets for easy optimised image settings
    SmartImage is an exclusive leading edge Philips technology that analyses the content displayed on your screen and optimises your display performance. This user-friendly interface allows you to select various modes, like Office, Photo, Movie, Game, Economy etc., to fit the application in use. Based on the selection, SmartImage dynamically optimises the contrast, colour saturation and sharpness of images and videos for ultimate display performance. The Economy mode option offers you major power savings. All in real time at the touch of a single button!
  • MHL technology for enjoying mobile content on a big screen
    Mobile High-Definition Link (MHL) is a mobile audio/video interface for directly connecting mobile phones and other portable devices to high-definition displays. An optional MHL cable allows you to simply connect your MHL-capable mobile device to this large Philips MHL display and watch your HD videos come to life with full digital sound. Now not only can you enjoy your mobile games, photos, movies or other apps on its big screen, you can simultaneously charge your mobile device so you never run out of power halfway.
  • IPS LED wide view technology for image and colour accuracy
    IPS displays use an advanced technology that gives you extra-wide viewing angles of 178/178 degrees, making it possible to view the display from almost any angle. Unlike standard TN panels, IPS displays give you remarkably crisp images with vivid colours, making them ideal not only for Photos, movies and web browsing, but also for professional applications that demand colour accuracy and consistent brightness at all times.
  • UltraClear 4K UHD (3840 x 2160) resolution for precision
    These latest Philips displays utilise high-performance panels to deliver UltraClear, 4K UHD (3840 x 2160) resolution images. Whether you are a professional requiring extremely detailed images for CAD solutions, using 3D graphics applications or are a financial wizard working on huge spreadsheets, Philips displays will make your images and graphics come alive.
  • VESA mount allows for the perfect setup
    VESA pattern guarantees compatibility with hundreds of innovative mounting solutions.
  • Powerful 7-Watt speakers to unleash your content
    A pair of high-quality stereo speakers built into a display device. They may be visible front firing, or invisible down firing, top firing, rear firing etc. depending on model and design.
  • MultiView 4K for 4 systems on one screen
    Philips MultiView feature on this expansive 4K UHD display enables you to have up to four systems each shown in Full HD on one screen. You can use Picture-by-Picture (PbP) to monitor four systems on one screen for control rooms or security. Or for multiple devices like two notebooks side-by-side simultaneously, making collaboration more productive. Or Picture-in-Picture mode (PiP) watching a live football feed from your set-top box, while working on your PC.
  • SmartUniformity for consistent images
    Fluctuations in brightness and colour on LCD screens are a common phenomenon. Philips' SmartUniformity mode delivers accurate images in terms of brightness; which is crucial for photography, design and printing. With a colour metric to assess colour accuracy, this mode is calibrated to meet average luminance uniformity of more than 95%. Selecting this mode will produce uniform and accurate images.
Philips Brilliance BDM4350UC - LED monitor - 4K - 43"
LED-backlit LCD monitor - 43"
Energy Class
Class B
Energy Consumption per Year
146 kWh
Power Consumption (On mode)
100 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 (DisplayPort: 60 Hz, HDMI: 60 Hz)
Pixel Pitch
0.2451 mm
Brightness
300 cd/m²
Contrast Ratio
1200:1 / 50000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
1.07 billion colours
Input Connectors
2xHDMI(MHL), 2xDisplayPort, VGA
Screen Coating
UltraClear
Glossy black with textured back cover, textured silver stand
96.8 cm x 25.9 cm x 63 cm
9.72 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV, VCCI, BSMI, ICES-003, SASO, SEMKO, CB, PSB, DDC/CI, RoHS, Lead-Free, ISO 9241-307, KCC, WEEE, PSE Mark, J-MOSS, E-Standby, KUCAS, CECP, EPA, EAC, cETLus, China RoHS, RCM
Display Type
Energy Class
Class B
146 kWh
100 W
Diagonal Size
43"
Viewable Size
42.51"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2451 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
23 - 80 Hz
Horizontal Refresh Rate
30 - 160 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
UltraClear
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Picture in picture, Sync on Green, sRGB colour management, MultiView, SmartImage, SmartConnect, Flicker Free technology, BFR/PVC-free, slim bezel design, Mercury free, PBP, SmartUniformity, USB 3.0 Fast Charge
96.8 cm x 25.9 cm x 63 cm - with stand
9.72 kg
Audio
Speakers - stereo
Output Power / Channel
7 Watt
VGA , 2 x MHL / HDMI , 2 x DisplayPort , 4 x USB 3.0 , Audio line-in , Headphones
Mechanical
VESA Mounting Interface
200 x 200 mm
MTBF
70,000 hour(s)
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0 Watt
On / Off Switch
Included Software
Philips SmartControl
Apple MacOS X, Microsoft Windows 7 / 8 / 8.1 / 10
Dimensions & Weight Details
With stand - width: 96.8 cm - depth: 25.9 cm - height: 63 cm - weight: 9.72 kg , Without stand - width: 96.8 cm - depth: 8.2 cm - height: 56.2 cm - weight: 9.4 kg
ENERGY STAR Certified
20 - 80%
Philips BDM4350UC 43 Bundle deal on Philips BDM4350UC 43" 3840x2160 5ms HDMI DP VGA IPS Monitor
£533.20
Diagonal Size: 43in
Response Time: 5ms
Interfaces: HDMI
Interfaces: Mobile High-Definition Link (MHL)
Interfaces: VGA (HD-15)
Brand: Philips
Price Range Ex VAT: 300 - 500
