Product
Brand
Philips BDM3275UP/00 32" 3840x2160 VGA DVI HDMI Monitor
Quicklinx: BYN4WS00 Mfr#: BDM3275UP/00
These amazing Philips screens deliver UltraClear, 4K UHD images. Utilizing high performance panels with high density pixel count, enabled by high bandwidth sources like DisplayPort, HDMI, Dual link DVI, these displays will make your images and graphics come alive. AHVA displays use an advanced technology which gives you extra wide viewing angles, making it possible to view the display from almost any angle. The 10-bit display delivers rich color depth for recreating smooth, natural colors without gradations and color banding. Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips Flicker Free technology applies a great solution to regulate brightness and reduce flicker for more comfortable viewing. Enjoy crisp colorful images and audio with simple one-cable connection. An HDMI-ready device has all the required hardware to accept High-Definition Multimedia Interface (HDMI) input. With the ultra-high resolution Philips MultiView display you can now experience a world of connectivity in a comfortable way whether at office or at home. MultiView enables active dual connect and view so that you can work with multiple devices like PC and notebook side-by-side simultaneously, making complex multi-tasking work a breeze. Watching live football feed from your set-top box on right side, while browsing the Internet from your notebook on the left is now easy. You may want to keep an eye on the live news feed with audio in the small window, while working on your blog. The Smart Ergo base is a monitor base that delivers ergonomic display comfort and provides cable management. The base's people-friendly height, swivel, tilt and rotation angle adjustments position the monitor for maximum comfort that can ease the physical strains of a long workday; cable management reduces cable clutter and keeps the workspace neat and professional. The Philips monitor, thanks to its advanced Smart Ergo base, can be lowered down almost to desk level for a comfortable viewing angle. Low bezel-to-table height is the perfect solution if you use bifocals, trifocals or progressive lens glasses for your computing work. Additionally, it allows for users with greatly different heights to use the monitor in their preferred angle and height settings, helping them reduce fatigue and strain.
Philips Brilliance BDM3275UP - LED monitor - 32"
LED-backlit LCD monitor - 32"
Energy Class
Class B
Energy Consumption per Year
83 kWh
Power Consumption (On mode)
57 W
USB 3.0 hub
Panel Type
AHVA
Aspect Ratio
16:9
Native Resolution
4K UHD (2160p) 3840 x 2160 at 60 Hz
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 50000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
1.07 billion colours
Input Connectors
HDMI, DVI-D, VGA, DisplayPort, MHL
Display Position Adjustments
Textured black
74.2 cm x 27 cm x 65.7 cm
10.9 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV GS, BSMI, ICES-003, SASO, SEMKO, TUV Ergo, PSB, DDC/CI, RoHS, Lead-Free, KCC, WEEE, PSE Mark, J-MOSS, TCO Certified Edge, KC, KUCAS, CECP, EPA, TCO Displays 6.0, cETLus, CU-EAC
Display Type
Energy Class
Class B
83 kWh
57 W
Diagonal Size
32"
Built-in Devices
USB 3.0 hub
Panel Type
AHVA
Aspect Ratio
16:9
Native Resolution
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms (grey-to-grey)
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Picture in picture, picture by picture, Sync on Green, sRGB colour management, HDCP, Eco-Mode, SmartResponse, MultiView, SmartContrast, SmartImage, Smart Ergo base, SmartControl Premium, SmartConnect, Flicker Free technology, BFR/PVC-free, side-by-side, Mercury free
Textured black
74.2 cm x 27 cm x 65.7 cm - with stand
10.9 kg
Audio
Speakers - stereo
Output Power / Channel
3 Watt
VGA , MHL / HDMI , DisplayPort , 4 x USB 3.0 , Audio line-in , Headphones , DVI-D (dual link) (HDCP)
Mechanical
Tilt Angle
-5/+20
Swivel Angle
340
Rotation Angle
90
Height Adjustment
180 mm
Flat Panel Mount Interface
100 x 100 mm
MTBF
70,000 hour(s)
41.1 Watt
Power Consumption Stand by
0.5 Watt
On / Off Switch
Apple MacOS X, Microsoft Windows 7 / 8 / 8.1
Dimensions & Weight Details
With stand - width: 74.2 cm - depth: 27 cm - height: 65.7 cm - weight: 10.9 kg , Without stand - width: 74.2 cm - depth: 6.1 cm - height: 43.8 cm - weight: 7.94 kg
ENERGY STAR Certified
20 - 80%
BYN4 C2G 2m DVI-D™ M/M Dual Link Digital Video Cable In Stock £7.72
BYN4 C2G HDMI to DisplayPort Adapter Converter In Stock £35.45
BYN4 C2G 2m DisplayPort Male to HD Male Adapter Cable - Black In Stock £21.80
BYN4 C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £8.17
BYN4 C2G 10m DisplayPort Cable with Latches M/M – Black In Stock £17.95
BYN4 C2G 20cm DisplayPort Male to HDMI Female Adapter Converter Black In Stock £15.96
BYN4 C2G 20cm DisplayPort Male to VGA Female Adapter Converter Black In Stock £12.24
