Philips BDM3270QP/00 32" 2560x1440 VGA DVI HDMI Monitor
Quicklinx: BYMRWS00 Mfr#: BDM3270QP/00
Diagonal Size: 32in
Max Resolution: 2560 x 1440
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: DisplayPort, DVI, HDMI, VGA (HD-15)
£308.43 ex VAT
£370.11 inc VAT
This Philips display will amaze you with its Crystal clear Quad HD images and brilliant colors. MultiView allows active dual connect and view.
  • Built-in stereo speakers for multimedia
    A pair of high-quality stereo speakers built into a display device. They may be visible front firing, or invisible down firing, top firing, rear firing etc. depending on model and design.
  • Low bezel-to-table height for maximum reading comfort
    Thanks to its advanced SmartErgoBase, the Philips monitor can be lowered down almost to desk level for a comfortable viewing angle. Low bezel-to-table height is the perfect solution if you use bifocals, trifocals or progressive lens glasses for your computing work. Additionally, it allows users of different heights to use the monitor at their preferred angle and height settings, helping them to reduce fatigue and strain.
  • AMVA LED for wide-view super-high contrast, vivid images
    Philips AMVA LED display uses an advanced multi-domain vertical alignment technology which gives you super-high static contrast ratios for extra vivid and bright images. While standard office applications are handled with ease, it is especially suitable for photos, web-browsing, films, gaming and demanding graphical applications. Its optimised pixel management technology gives you 178/178 degree extra wide viewing angle, resulting in crisp images even in 90 degree pivot mode
  • SmartErgoBase enables user-friendly ergonomic adjustments
    The SmartErgoBase is a monitor base that delivers ergonomic display comfort and provides cable management. The user-friendly height, swivel, tilt and rotation angle adjustments of the base allow the monitor to be positioned for maximum comfort to help ease the physical strains of a long workday. In addition, cable management reduces cable clutter and keeps the workspace neat and professional.
  • MHL technology for enjoying mobile content on a big screen
    Mobile High-Definition Link (MHL) is a mobile audio/video interface for directly connecting mobile phones and other portable devices to high-definition displays. An optional MHL cable allows you to simply connect your MHL-capable mobile device to this large Philips MHL display and watch your HD videos come to life with full digital sound. Now not only can you enjoy your mobile games, photos, movies or other apps on its big screen, you can simultaneously charge your mobile device so you never run out of power halfway.
  • USB 3.0 enables fast data transfers and smart phone charging
    Super-Speed USB 3.0 deploys a 5.0 gbit/s transfer rate, which is about 10 times faster than the USB 2.0 standard, significantly reducing data transfer time and saving you time and money. With more bandwidth, super-speed transfer rates, better power management and superior overall performance, USB 3.0 sets the latest global standard allowing you to use large-capacity storage devices. Sync-N-Go technology ensures you don't have to wait for bandwidth to be freed up any more. Your investment in USB 2.0 devices is protected as it is backwards-compatible.
  • MultiView enables simultaneous dual connect and view
    With the ultra-high resolution Philips MultiView display, you can now experience a world of connectivity. MultiView enables active dual connect and view so that you can work with multiple devices like a PC and notebook simultaneously, for complex multitasking.
  • Crystal clear images with Quad HD 2560 x 1440 pixels
    These latest Philips screens deliver CrystalClear, Quad HD 2560x1440 or 2560x1080 pixel images. Utilising high-performance panels with a high-density pixel count, enabled by high-bandwidth sources like DisplayPort, HDMI, Dual link DVI, these new displays will make your images and graphics come alive. Whether you are a demanding professional requiring extremely detailed information for CAD-CAM solutions, using 3D graphic applications or a financial wizard working on huge spreadsheets, Philips displays will give you CrystalClear images.
  • DisplayPort connection for maximum visuals
    DisplayPort is a digital link from PC to monitor without any conversion. With higher capabilities than DVI standard, it is fully capable to support up to 15 metre cables and 10.8 Gbps/sec data transfer. With this high performance and zero latency, you get the fastest imaging and refresh rates — making DisplayPort the best choice for not only general office or home use, but also for the more demanding gaming and films, video editing and more. It also keeps interoperability in mind via the use of various adapters.
  • SmartConnect with HDMI, MHL, DisplayPort, DVI and VGA
    With a plethora of connectivity, these Philips displays come equipped with multiple connections like VGA, Display Port, universal HDMI connector and MHL, enabling you to enjoy high-resolution uncompressed video and audio content. USB connections ensure that you can have super-speed data transfers while having global connectivity. Regardless of what source you use, you can rest assured that this Philips display will ensure your investment is not made obsolete any time soon!
  • Less eye fatigue with Flicker-Free technology
    Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips Flicker-Free technology applies a new solution to regulate brightness and reduce flicker for more comfortable viewing.
  • 1.074 billion colours for smooth colour gradations and detail
    The 10-bit display delivers rich colour depth with 1.074 billion colours and 12-bit internal processing for recreating smooth, natural colours without gradations and colour banding.
Philips Brilliance BDM3270QP - LED monitor - 32"
LED-backlit LCD monitor - 32"
Energy Class
Class B
Energy Consumption per Year
82 kWh
Power Consumption (On mode)
56 W
USB 3.0 hub
Panel Type
A-MVA
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 60 Hz
Pixel Pitch
0.277 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1 / 50000000:1 (dynamic)
Response Time
12 ms (typical); 4 ms (grey-to-grey)
Colour Support
1.07 billion colours
Input Connectors
HDMI, DVI, DisplayPort, VGA
Speakers
Internal
Display Position Adjustments
Textured black
74.2 cm x 27 cm x 65.7 cm
10.76 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, VCCI, BSMI, SEMKO, CCC, PSB, DDC/CI, RoHS, Lead-Free, WEEE, PSE Mark, TCO Certified Edge, KC, CECP, EPA, TCO Displays 6.0, cETLus, CU-EAC
Display Type
Energy Class
Class B
82 kWh
56 W
Diagonal Size
32"
Built-in Devices
USB 3.0 hub
Panel Type
A-MVA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.277 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
23 - 76 Hz
Horizontal Refresh Rate
15 - 99 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Picture in picture, picture by picture, Sync on Green, sRGB colour management, HDCP, SmartResponse, MultiView, SmartImage, Mobile High-Definition Link (MHL), Smart Ergo base, SmartControl Premium, Crystal Clear Quad HD, SmartConnect, Flicker Free technology, BFR/PVC-free, side-by-side, Mercury free
Textured black
74.2 cm x 27 cm x 65.7 cm - with stand
10.76 kg
Audio
Speakers - stereo - internal
Output Power / Channel
3 Watt
VGA , HDMI (HDCP) , DisplayPort , 2 x USB 3.0 , Audio line-in , Headphones , 2 x USB 2.0 , DVI (HDCP)
Mechanical
Tilt Angle
-5/+20
Swivel Angle
340
Rotation Angle
90
Height Adjustment
180 mm
VESA Mounting Interface
100 x 100 mm
MTBF
70,000 hour(s)
Power Supply
Internal
Power Consumption Stand by
0.5 Watt
On / Off Switch
Dimensions & Weight Details
With stand - width: 74.2 cm - depth: 27 cm - height: 65.7 cm - weight: 10.76 kg , Without stand - width: 74.2 cm - depth: 6.1 cm - height: 43.8 cm - weight: 7.8 kg
ENERGY STAR Certified
20 - 80%
Philips BDM3270QP/00 32 Bundle deal on Philips BDM3270QP/00 32" 2560x1440 VGA DVI HDMI Monitor
£407.60
BYMR C2G 1m DVI-D™ M/M Dual Link Digital Video Cable In Stock £8.37
BYMR C2G 2m DVI-D™ M/M Dual Link Digital Video Cable In Stock £9.80
BYMR C2G 5m DVI-D™ M/M Dual Link Digital Video Cable In Stock £17.78
BYMR C2G 2m HDMI to DVI-D Digital Video Cable In Stock £9.09
Diagonal Size: 32in
Response Time: 4ms
Interfaces: DVI
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Philips
Price Range Ex VAT: 300 - 500
