Get even closer to your audience than ever before. Fast, precise and extremely durable, its high performance is matched by excellent reliability and functionality.
Full HD LED technology
White LED's are solid state devices which light up to full, consistent brightness faster saving startup time. LED's are free from mercury content which allows for eco-friendly recycling and disposal process. LED's allow for better dimming control of LCD backlight, resulting in super high contrast ratio. It also gives superior color reproduction thanks to consistent brightness across the screen. -
AMVA Display technology
Philips AMVA LED display uses an advanced multi-domain vertical alignment technology which gives you super-high static contrast ratios for extra vivid and bright images. While standard applications are handled with ease, it is especially suitable for graphical demanding applications. It's optimized pixel management technology gives you 178/178 degree extra wide viewing angle, resulting in crisp images even in portrait mode. -
OPS slot
Developed for the digital signage market, the Open Pluggable Specification (OPS) slot is designed to make changing or upgrading your media player mere child's play. Simply plug your media player in to the display - and you're ready. No matter whether you have an entry level, mid-range or high-end media player, OPS is fully compatible bringing you a lower TCO over the longer term. -
Smart insert
Professional PC's are part of most public signage installations. Quite often they increase the overall depth to the display and cause a lot of cable clutter. So Philips has designed this display with smart insert in the back cover which is ideal for the integration of a professional small form factor PC. On top of that, the cable management system offers a great solution to keep your cables neat and professional looking. -
Smart control
Control and manage all of the signage displays on your network with this powerful software tool which allows you to change the settings of your display centrally via an RJ45 or RS232 connection. Smart control allows you to set the video input, modify the color settings, set the display's ID when creating video walls and even diagnose each display's status, giving you all the power you need to manage your displays from one central location. -
SmartPower
The backlight intensity can be controlled and pre-set by the system to reduce the power consumption by up to 50%, which saves substantially on energy costs. -
DisplayPort
Enjoy crystal clear images with the high-bandwidth graphics support of the DisplayPort. As well as transmitting full high-definition video the DisplayPort will also transmit audio, thus eliminating the need for extra cables. -
Freeze operation
Activate the freeze option during your presentation, to switch the content on your computer without having your audience to see it. Simply deactivate the freeze option when ready to play the live video source again. -
USB Plug-and-Play compatible
Simply connect the display via USB to your mediaplayer for automatic touch recognition. The USB connector is HID compliant, providing true Plug-and-Play operation.
- Philips Signage Solutions BDL6524ET 65" LED display - Full HD
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 65"
- Commercial Use
- Resolution
- 1920 x 1080
- Display Format
- 1080p (Full HD)
- Video Interface
- HDMI
- PC Interface
- VGA (HD-15)
- HDCP Compatible
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- Speaker System
- 2 speakers
- Remote Control
- Standard remote
- Voltage
- (50/60 Hz)
- Product Type
- Diagonal Class
- 65"
- Commercial Use
- TV Tuner Presence
- No
- Video Interface
- HDMI
- PC Interface
- VGA (HD-15)
- HDCP Compatible
- Dimensions
- Without stand
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p (Full HD)
- 16:9
- LED backlight
Remote Control
- Standard remote
Audio System
- Speaker System
- 2 speakers
- Power Device
- Power supply
- Nominal Voltage
- (50/60 Hz)
