Product
Philips BDL6520EL 65" 1920x1080 6.5ms VGA DVI HDMI DP USB LED LFD
Quicklinx: BNJHWS00 Mfr#: BDL6520EL/00
  • 1080p (Full HD)
Maximizing your content delivery whilst lowering your TCO has never been so easy, this 65" display offers breathtaking HD picture quality with lower power consumption.
  • Full HD LED technology
    White LED's are solid state devices which light up to full, consistent brightness faster saving startup time. LED's are free from mercury content which allows for eco-friendly recycling and disposal process. LED's allow for better dimming control of LCD backlight, resulting in super high contrast ratio. It also gives superior color reproduction thanks to consistent brightness across the screen.
  • AMVA display technology
    Philips AMVA LED display uses an advanced multi-domain vertical alignment technology which gives you super-high static contrast ratios for extra vivid and bright images. While standard applications are handled with ease, it is especially suitable for graphical demanding applications. Its optimized pixel management technology gives you 178/178-degree extra wide viewing angle, resulting in crisp images even in portrait mode.
  • Smart control
    Control and manage all of the signage displays on your network with this powerful software tool which allows you to change the settings of your display centrally via an RJ45 or RS232 connection. Smart control allows you to set the video input, modify the color settings, set the display's ID when creating video walls and even diagnose each display's status, giving you all the power you need to manage your displays from one central location.
  • SmartPower
    The backlight intensity can be controlled and pre-set by the system to reduce the power consumption by up to 50%, which saves substantially on energy costs.
  • OPS slot
    Developed for the digital signage market, the Open Pluggable Specification (OPS) slot is designed to make changing or upgrading your media player mere child's play. Simply plug your media player in to the display - and you're ready. No matter whether you have an entry level, mid-range or high-end media player, OPS is fully compatible bringing you a lower TCO over the longer term.
  • Smart insert
    Professional PC's are part of most public signage installations. Quite often they increase the overall depth to the display and cause a lot of cable clutter. So this display with Smart insert in the back cover which is ideal for the integration of a professional small form factor PC. On top of that, the cable management system offers a great solution to keep your cables neat and professional looking.
  • Freeze operation
    Activate the freeze option during your presentation, to switch the content on your computer without having your audience to see it. Simply deactivate the freeze option when ready to play the live video source again.
  • Designed for 24/7 operation
    Because business never sleeps, the signage displays are designed for 24/7 use. Taking advantage of superior components to ensure a higher level of quality, you can count on this range of models for complete around - the clock reliability.
Philips Signage Solutions E-Line BDL6520EL 65" Class (64.5" viewable) LED display
LED-backlit LCD flat panel display
Diagonal Class
65"
Diagonal Size
64.5 in
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Input Video Formats
480p, 1080i, 1080p, 480i, 576i, 576p
Video Interface
Component, composite, HDMI, S-Video
HDMI Ports Qty
1 ports
PC Interface
VGA (HD-15)
LCD Backlight Technology
LED backlight - edge-lit
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Remote Control
Standard remote
Voltage
250 Watt
155 cm x 9.3 cm x 92.7 cm
52 kg
3 years warranty
250 Watt
Diagonal Class
65"
Diagonal Size
64.5 in
Commercial Use
TV Tuner
No tuner
Video Interface
HDMI Ports Qty
1 ports
PC Interface
VGA (HD-15)
155 cm
9.3 cm
92.7 cm
52 kg
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
Colour Depth
Up to 1.07 billion colours
Image Contrast Ratio
4000:1
Brightness
360 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.74 x 0.74mm
Pull-Down Compensation
3:2, 2:2
Response Time
8 ms
Display Menu Language
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Polish, Russian, Spanish, Turkish
Backlight Life
50,000 hour(s)
Comb Filter
3D digital
Dynamic Contrast, Smart Insert
Stands & Mounts
Flat Panel Mount Interface
600 x 400 mm
Video Features
Input Video Formats
Supported Computer Resolutions
1920 x 1200 (WUXGA), 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080, 1440 x 900, 1280 x 800
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Connector Type
2 x speakers output , HDMI , VGA input , DVI-D input , Component video input , 2 x audio line-in , Composite video input , S-Video input , Serial input , Network , Serial output
VGA cable
FCC Class B certified, UL, GOST, cUL, CCC, RoHS
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
Smart power
Limited warranty - 3 years
BNJH C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
BNJH C2G 0.5m Select High Speed HDMI with Ethernet In Stock £6.46
BNJH C2G 5m Select High Speed HDMI with Ethernet In Stock £21.69
BNJH C2G 10m Select High Speed HDMI with Ethernet In Stock £41.46
BNJH C2G Pro HDMI to VGA Converter In Stock £51.78
