Impress your audience with the most impact full video wall. With ultra narrow bezel and stunning picture quality, you are sure to create the most memorable visual experience.
- Philips Signage Solutions BDL5588XL 55" Class (54.6" viewable) LED display
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 55"
- Diagonal Size
- 54.6 in
- Commercial Use
- Yes - digital signage
- Resolution
- 1920 x 1080
- Display Format
- 1080p (Full HD)
- Input Video Formats
- 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
- Video Wall Components Qty
- 100
- Video Interface
- Component, composite, HDMI
- HDMI Ports Qty
- 2 ports
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- Technology
- IPS
- LCD Backlight Technology
- LED backlight - direct-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Picture Enhancements
- Advanced Colour Calibration
- Speaker System
- 2 speakers
- Remote Control
- Standard remote
- 110 Watt
- Dimensions (WxDxH) - without stand
- 121.34 cm x 10.335 cm x 68.42 cm
- 29.2 kg
- Environmental Standards
- ENERGY STAR Qualified
- 3 years warranty
- Product Type
- 110 Watt
- Diagonal Class
- 55"
- Diagonal Size
- 54.6 in
- Commercial Use
- TV Tuner
- No tuner
- Sensors
- Ambient light sensor (ALS)
- Video Interface
- HDMI Ports Qty
- 2 ports
- PC Interface
- Modes
- Portrait mode, landscape mode
- Design
- Ultra Narrow Bezel Concept
- 100
- Dimensions
- Without stand
- 121.34 cm
- 10.335 cm
- 68.42 cm
- 29.2 kg
Display
- LCD Display Technology
- IPS
- Resolution
- 1920 x 1080
- Display Format
- 1080p (Full HD)
- 16:9
- Colour Depth
- Up to 1.07 million colours
- Image Contrast Ratio
- 1400:1
- Dynamic Contrast Ratio
- 500000:1
- Brightness
- 500 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Pixel Pitch
- 0.63 x 0.63mm
- Pull-Down Compensation
- 3:2, 2:2
- Response Time
- 12 ms
- Display Menu Language
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Polish, Russian, Spanish, Turkish, Arabic, Japanese
- Backlight Life
- 50,000 hour(s)
- Comb Filter
- 3D digital
- Dynamic Contrast, 3D MA deinterlacing, Smart Control
Stands & Mounts
- Stand
- Optional
- Flat Panel Mount Interface
- 400 x 400 mm
Video Features
- Supported Computer Resolutions
- 1366 x 768, 1920 x 1200 (WUXGA), 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080, 1440 x 900, 1280 x 800
Remote Control
- Standard remote
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x speaker - built-in - 10 Watt
- Connector Type
- Component video input , Composite video input , DVI-D input , 2 x HDMI , DisplayPort input , DisplayPort output , DVI-I , Audio line-in , Audio line-in , Remote control input , Remote control input , Network , Serial input , Serial output , Speakers output , VGA input , Audio line-out
- Cables Included
- VGA cable , Serial cable
- FCC Class B certified, UL, GOST, cUL, CB
- ENERGY STAR Certified
- ENERGY STAR Version
- 6.0
- Power Device
- Power supply
- Power Consumption Stand by
- 0.5 Watt
- Smart power
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 20 - 80%
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
C2G 0.5m Select High Speed HDMI with Ethernet | In Stock | £5.79 |
C2G 5m Select High Speed HDMI with Ethernet | In Stock | £15.65 |
C2G 10m Select High Speed HDMI with Ethernet | In Stock | £30.41 |
C2G 15m Select High Speed HDMI with Ethernet | In Stock | £41.19 |
C2G Pro HDMI to VGA Converter | In Stock | £46.73 |
