Philips BDL5588XH 55" Video Wall Display
Quicklinx: FFCCWS00 Mfr#: BDL5588XH/02
Video Interface: Composite, Component, HDMI
TV Tuner Presence: No
  • 1080p (Full HD)
£1,971.01 ex VAT
£2,365.21 inc VAT
Impress your audience with the most impact full video wall. With ultra narrow bezel and stunning picture quality, you are sure to create the most memorable visual experience.
  • Full HD LED technology
    White LED's are solid state devices which light up to full, consistent brightness faster saving startup time. LED's are free from mercury content which allows for eco-friendly recycling and disposal process. LED's allow for better dimming control of LCD backlight, resulting in super high contrast ratio. It also gives superior color reproduction thanks to consistent brightness across the screen.
  • IPS display technology
    Philips IPS displays uses an advanced technology which gives you extra wide viewing angles of 178/178 degree, making it possible to view the display from almost any angle - even in portrait mode. IPS displays gives you remarkably crisp images with vivid colors, especially suitable for professional video wall and menuboard applications which demand color accuracy and consistent brightness at all times.
  • High brightness
    Enjoy a clearer image in areas with greater ambient brightness thanks to the 700 nit panel. Your audience can enjoy better image quality in locations that are away from direct sunlight yet still brighter than average, optimizing the viewing experience.
  • Ultra narrow bezel
    The next generation of video wall displays is designed with industry narrowest bezels and advanced alignment solutions. Fully exploit your impactful signage content with ultra narrow bezel displays, and make sure your message does not get lost by thick bezels. With the ultra narrow bezels you can create seamless video wall configurations of virtually any size.
  • Advanced color calibration
    The advanced color calibration kit controls the luminance of the backlight, standardizes the gamma curve and calibrates the scale of your display network. Whether you have an impressive video wall, a catchy mosaic layout, a menu board installation or a control room each display can be adjusted to the same color values. With this optional kit you ensure consistent color performance over all displays in your network.
  • SmartPower
    The backlight intensity can be controlled and preset by the system to reduce the power consumption by up to 50%, which saves substantially on energy costs.
  • OPS insert
    Turn your display into an all-in-one digital signage solution and create a display network which is connected, intelligent and secure. Open Pluggable Specification (OPS) is an industry standard slot into which you can add an OPS- standardized media player. This cable free solution gives you the ability to install, use or maintain your hardware whenever you need.
  • Designed for 24/7 operation
    Because business never sleeps, the signage displays are designed for 24/7 use. Taking advantage of superior co mponents to ensure a higher level of quality, you can count on this range of models for complete around-the-clock reliability.
Philips Signage Solutions BDL5588XH 55" Class (54.6" viewable) LED-backlit LCD display - Full HD
LED-backlit LCD flat panel display
Diagonal Class
55"
Diagonal Size
54.6"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Input Video Formats
1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
Max Number of Screens
100
Video Interface
Component, composite, HDMI
HDMI Ports Qty
2 ports
LAN
PC Interface
DVI, VGA (HD-15), DisplayPort
IPS
LCD Backlight Technology
LED backlight - direct-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Picture Enhancements
Dynamic contrast enhancement, Pixel Shift, Low Bright
Speaker System
2 speakers
Remote control, batteries
Energy Class
Class G
Power Consumption (On mode)
150.6 W
Power Consumption Stand by
0.5 Watt
121.34 cm x 10.335 cm x 68.42 cm
29.2 kg
Environmental Standards
ENERGY STAR Qualified
3-year warranty
Energy Class
Class G
150.6 W
150.6 kWh/1000h
Diagonal Class
55"
Diagonal Size
54.6"
Commercial Use
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Ambient light sensor (ALS)
Video Interface
HDMI Ports Qty
2 ports
PC Interface
Modes
Portrait mode, landscape mode
Design
Ultra Narrow Bezel Concept
Dimensions
Without stand
121.34 cm
10.335 cm
68.42 cm
29.2 kg
Display
LCD Display Technology
IPS
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Image Contrast Ratio
1400:1
Dynamic Contrast Ratio
500000:1
Brightness
700 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pull-Down Compensation
3:2, 2:2
Response Time
12 ms
Display Menu Language
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Polish, Russian, Spanish, Turkish, Arabic, Japanese
Backlight Life
50,000 hour(s)
TileMatrix (10 x 10), Certified for 24/7 Continuous Operation, 3D MA deinterlacing, Smart Control, Motion Compensation
Video Wall
100
Stands & Mounts
Flat Panel Mount Interface
400 x 400 mm
Video Features
Input Video Formats
Supported Computer Resolutions
1366 x 768, 1920 x 1200 (WUXGA), 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080, 1440 x 900, 1280 x 800
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x speaker - 10 Watt
Network & Internet Multimedia
LAN
Connector Type
Component video input , Composite video input , DVI-D input , 2 x HDMI input , VGA input , DisplayPort input , DisplayPort output , DVI-I output , Audio line-in , Audio line-in , Audio line-out , Speakers output , Remote control input , Remote control output , LAN , Serial input , Serial output
Batteries
VGA cable , Serial cable
FCC Class B certified, UL, GOST, cUL, CB, CEC
ENERGY STAR Certified
ENERGY STAR Version
6.0
Power supply
0.5 Watt
Smart power
Limited warranty - 3 years
20 - 80%
Video Interface: Component
Video Interface: HDMI
Brand: Philips
Price Range Ex VAT: £1500+
