With this energy-efficient Signage Solution display, you will enjoy all the benefits of state-of- the-art connectivity and content management possibilities while being assured that remote management safeguards low cost of ownership.
Full HD LED technology
LEDs are solid state devices which light up to full, consistent brightness faster saving startup time. LEDs are free from mercury content which allows for eco-friendly recycling and disposal process. LEDs allow for better dimming control of LCD backlight, resulting in super high contrast ratio. It also gives superior color reproduction thanks to consistent brightness across the screen. -
IPS Display technology
Philips IPS displays uses an advanced technology which gives you extra wide viewing angles of 178/178 degree, making it possible to view the display from almost any angle - even in portrait mode. IPS displays gives you remarkably crisp images with vivid colors, especially suitable for professional video wall and menuboard applications which demand color accuracy and consistent brightness at all times. -
SmartControl
SmartControl software suite lets you remotely control and manage your network of displays via RJ45 and RS232C. Easy identify your displays and fine-tune all display settings including resolution, brightness, contrast, video wall configurations and cloning of your settings over your complete network. -
SmartCMS
Free and easy-to-use content management system that works exclusively with Philips Sigage Solutions displays to manage your digital signage content. With SmartCMS you can create and schedule your own content every day. Simply create your network, design your content, schedule your playlist and you are ready to play! -
Failover
Keeping your content up and running is critical for demanding commercial applications. While it is unlikely you will face a content disaster, Failover provides protection with a revolutionary technology that plays back-up content on screen in the event of a media player failure. Failover automatically kicks in when the primary input fails. Simply select a primairy input connection and a Failover connection and your ready for instant protection. -
SmartPlayer
Save your Digital Signage content (video, audio, pictures) on your USB and plug into your display & enjoy your own created playlists. -
Share & Stream with DLNA
Simply share & stream content from your mobile device or media player to your display with all DLNA compliant media devices. Connect each display with an ethernet cable and manage your content real time within your local network. Simply connect your display and start sharing.
- Philips BDL5560EL E-Line - 55" Class (54.6" viewable) LED-backlit LCD display - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 55"
- Diagonal Size
- 54.6"
- Commercial Use
- Yes - digital signage
- Resolution
- 1920 x 1080
- Input Video Formats
- 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
- Max Number of Screens
- 100
- Video Interface
- Component, composite, HDMI
- HDMI Ports Qty
- 2 ports
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- HDCP Compatible
- LCD Backlight Technology
- Edge-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Commercial Features
- Digital signage
- Speaker System
- 2 speakers
- USB
- Included Accessories
- Remote control
- Voltage
- AC 100/230 V (50/60 Hz)
- 122.52 Watt
- Power Consumption Stand by
- 0.4 Watt
- Dimensions (WxDxH) - without stand
- 124.44 cm x 6.9 cm x 71.52 cm
- 30.6 kg
- Environmental Standards
- ENERGY STAR Qualified
- 3-year warranty
- Product Type
- 122.52 Watt
- Diagonal Class
- 55"
- Diagonal Size
- 54.6"
- Commercial Use
- Series
- E-Line
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI Ports Qty
- 2 ports
- PC Interface
- HDCP Compatible
- Modes
- Portrait mode, landscape mode
- Dimensions
- Without stand
- 124.44 cm
- 6.9 cm
- 71.52 cm
- 30.6 kg
Display
- Resolution
- 1920 x 1080
- 16:9
- Edge-lit LED
- Colour Depth
- Up to 1.07 billion colours
- Image Contrast Ratio
- 1300:1
- Dynamic Contrast Ratio
- 500000:1
- Brightness
- 450 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Pixel Pitch
- 0.21 x 0.63mm
- Pull-Down Compensation
- 3:2, 2:2
- Response Time
- 12 ms
- Backlight Life
- 60,000 hour(s)
- Comb Filter
- 3D digital
- Digital signage
- Dynamic Contrast, 3D MA deinterlacing, Smart Insert, SmartCMS
Video Wall
- 100
Stands & Mounts
- Flat Panel Mount Interface
- 100 x 100 mm, 200 x 200 mm, 400 x 200 mm, 400 x 400 mm, 100 x 200 mm
Video Features
- Supported Computer Resolutions
- 1366 x 768, 1920 x 1200 (WUXGA), 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1360 x 768, 1920 x 1080, 1440 x 900, 1280 x 800
Media Player
- Supported Video Formats
- MPEG-4, WMV, MKV, VOB, TS, M2TS, M4V, MTS
- Supported Audio Formats
- MP3, WMA, WAV, AAC, AIFF, LPCM, M4A
- Supported Pictures Formats
- BMP, JPG, GIF
- USB Port
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x main channel speaker - 10 Watt
- Connector Type
- DisplayPort input , 2 x HDMI input , DVI-D input , VGA input , USB , Component video input , Composite video input , DisplayPort output , DVI-I , VGA output , Audio line-in , Audio line-in , Audio line-out , Speakers output , LAN , Serial , Remote control
- Cables Included
- VGA cable
- FCC Class B certified, UL, VCCI, C-Tick, BSMI, GOST, cUL, CB, CCC, RoHS, PSE Mark, J-MOSS
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 6.0
- Power Device
- Power supply
- Input Voltage
- 0.4 Watt
- Smart power
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 20 - 60%
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
