Discover a high level of interaction with this multi touch LED display. Get even closer to your audience than ever before. Fast, precise and extremely durable, its high performance is matched by excellent reliability and functionality.
Full HD LED technology
Picture quality matters. Regular displays deliver quality, but you expect more. Imagine crisp detail paired with high brightness, incredible contrast and realistic colors for a true to life picture. -
Plug & play multi touch
A high level of interactivity is now available thanks to integrated touch technology. More flexibility and optimum simultaneous touch performance coupled with excellent operability opportunities to give you the ultimate in user interaction. The multi touch displays are enabled with automatic touch recognition. The USB connector is HID compliant, providing true plug-and-play operation. -
Optical multi-touch
The sensors on the edge of the screen give you perfect clarity whilst at the same time offering multi touch interaction, opening up all kinds of possibilities for interactive applications. -
Simultaneous touch points
Enjoy a more interactive experience with touch points at the same time. Ideal for when you have more than one user to interact with your application simultaneously, the 6 touch points offer an extremely cost-effective solution. -
SmartPower
The backlight intensity can be controlled and pre-set by the system to reduce the power consumption, which saves substantially on energy costs. -
Designed for 24/7 operation
Because business never sleeps, these signage displays are designed for 24/7 use. Taking advantage of superior components to ensure a higher level of quality, you can count on this range of models for complete around-the-clock reliability.
- Philips BDL5556ET 55" Class (54.6" viewable) LED-backlit LCD display - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 55"
- Diagonal Size
- 54.6"
- Commercial Use
- Yes - digital signage
- Resolution
- 1920 x 1080
- Input Video Formats
- 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
- Video Interface
- Component, composite, HDMI
- HDMI Ports Qty
- 1 ports
- Connectivity
- LAN
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- LCD Backlight Technology
- Edge-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- Included Accessories
- Remote control
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class B
- 140 Watt
- Power Consumption (On mode)
- 131 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 192 kWh
- Dimensions (WxDxH) - without stand
- 125.73 cm x 7.9 cm x 72.81 cm
- 43 kg
- 3-year warranty
- Product Type
- Energy Class
- Class B
- 140 Watt
- 131 W
- 192 kWh
- Diagonal Class
- 55"
- Diagonal Size
- 54.6"
- Commercial Use
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI Ports Qty
- 1 ports
- PC Interface
- Protection
- Tempered glass protection
- Dimensions
- Without stand
- 125.73 cm
- 7.9 cm
- 72.81 cm
- 43 kg
Display
- Resolution
- 1920 x 1080
- 16:9
- Edge-lit LED
- Coating
- Anti-glare
- Colour Depth
- Up to 1.06 billion colours
- Image Contrast Ratio
- 1300:1
- Dynamic Contrast Ratio
- 500000:1
- Brightness
- 450 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Pixel Pitch
- 0.63 x 0.63mm
- Pull-Down Compensation
- 3:2, 2:2
- Touchpoints Qty
- 6
- Response Time
- 12 ms
- Display Menu Language
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Polish, Russian, Spanish, Turkish, Arabic, Japanese
- Backlight Life
- 50,000 hour(s)
- Comb Filter
- 3D digital
- Dynamic Contrast, 3D MA deinterlacing, Multitouch, Open Pluggable Specification slot, Smart Control
Stands & Mounts
- Flat Panel Mount Interface
- 100 x 100 mm, 200 x 200 mm, 400 x 200 mm, 400 x 400 mm, 100 x 200 mm
Video Features
- Supported Computer Resolutions
- 1366 x 768, 1920 x 1200 (WUXGA), 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080, 1440 x 900, 1280 x 800
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x main channel speaker - 10 Watt
Network & Internet Multimedia
- Connectivity
- LAN
- LAN Protocol
- Ethernet
- Connector Type
- HDMI input , VGA input , DVI-D input , Component video input , VGA output , Composite video input , DVI-I , Audio line-out , Audio line-out , LAN , DisplayPort input , Serial , USB , Audio line-in , Speakers output
- Cables Included
- VGA cable , Serial cable , USB cable
- Plug and Play, FCC Class B certified, UL, C-Tick, cUL, SASO, CB, CCC, RoHS, EMF, KUCAS, EPA, EAC
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- On / Off Switch
- Smart power
- Limited warranty - 3 years
- 5 °C
- 40 °C
- 20 - 80%
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
