Your basket is empty
Philips BDL5520QL 55" 1920x1080 8ms VGA DVI HDMI LED LFD
Quicklinx: BNJJWS00 Mfr#: BDL5520QL/00
  • 1080p (Full HD)
Deliver startlingly clear images in a more eco-friendly way with the edge LED display. High on performance and reliability, yet low on power consumption, it is ideal for projects where no compromise is accepted.
Philips Signage Solutions BDL5520QL Q-Line - 55" LED display
LED-backlit LCD flat panel display
Diagonal Class
55"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Input Video Formats
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Video Interface
Component, composite, HDMI
HDMI Ports Qty
1 ports
LAN
PC Interface
DVI, VGA (HD-15)
IPS
LCD Backlight Technology
LED backlight - edge-lit
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
USB
Remote Control
Standard remote
Voltage
AC 120/230 V
102 Watt
126.47 cm x 4.28 cm x 73.55 cm
Environmental Standards
ENERGY STAR Qualified
3 years warranty
102 Watt
Diagonal Class
55"
Commercial Use
Series
Q-Line
TV Tuner
No tuner
Video Interface
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
Dimensions
Without stand
126.47 cm
4.28 cm
73.55 cm
Display
LCD Display Technology
IPS
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
Colour Depth
16.7 million colours
Image Contrast Ratio
1400:1
Dynamic Contrast Ratio
7000:1
Brightness
350 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.21 x 0.63mm
Pull-Down Compensation
3:2, 2:2
Response Time
8 ms
Display Menu Language
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Polish, Russian, Spanish, Turkish
Backlight Life
50,000 hour(s)
Comb Filter
3D digital
Dynamic Contrast
Stands & Mounts
Flat Panel Mount Interface
400 x 400 mm
Video Features
Input Video Formats
Supported Computer Resolutions
1366 x 768, 1920 x 1200 (WUXGA), 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080, 1440 x 900, 1280 x 800
Media Player
Supported Video Formats
MPEG-4, Xvid, DivX, WMV, ASF, QuickTime, AVI, MKV, MOV, VOB, FLV, TS, M2TS, 3GPP, F4V, DAT, M4V, TRP, WebM
Supported Audio Formats
MP3, WMA, WAV, AC3, AAC, Ogg Vorbis, AIFF, AMR, M4A
Supported Pictures Formats
BMP, JPG, GIF
USB Port
USB Ports Qty
1
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
14 Watt
Speakers
2 x main channel speaker - built-in - 7 Watt
Network & Internet Multimedia
LAN
LAN Protocol
Ethernet
DLNA
Connector Type
HDMI , VGA input , DVI-D input , Component video input , 2 x audio line-in , Composite video input , Audio line-in , Network , Serial output , SPDIF output
FCC Class B certified, UL, BSMI, GOST, cUL, CCC, RoHS
ENERGY STAR Certified
ENERGY STAR Version
6.0
Power supply
Nominal Voltage
AC 120/230 V
Power Consumption Stand by
0.5 Watt
Smart power
Limited warranty - 3 years
Dimensions & Weight Details
Panel without stand - 126.47 cm x 4.28 cm x 73.55 cm
Width (Shipping)
138.1 cm
Depth (Shipping)
15.7 cm
Height (Shipping)
87.4 cm
Weight (Shipping)
25.1 kg
5 °C
90 °C
0 - 40%
BNJJ C2G 2m USB 2.0 A/B Cable - Black In Stock £3.02
BNJJ C2G 5m USB 2.0 A/B Cable - Black In Stock £4.29
BNJJ C2G 2-Port USB 2.0 Manual Switch In Stock £16.36
BNJJ C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £11.41
BNJJ C2G 4-Port USB 2.0 Aluminum Hub In Stock £25.45
BNJJ C2G 12m USB 2.0 A/A Active Extension Cable In Stock £14.97
