With this energy efficient Signage Solution display, you will enjoy all the benefits of state-of-the-art connectivity and content management possibilities while being ensured that remote management safeguards the lowest cost of ownership.
Manage and control your network remotely via SmartControl
SmartControl software suite lets you remotely control and manage your network of displays via RJ45 and RS232C. Easy identify your displays and fine-tune all display settings including resolution, brightness, contrast, video wall configurations and cloning of your settings over your complete network. -
Free and easy-to-use content management with SmartCMS
Free and easy-to-use content management system that works exclusively with Philips Sigage Solutions displays to manage your digital signage content. With SmartCMS you can create and schedule your own content over 24 hours every day. Simply create your network, design your content, schedule your playlist and you are ready to play! -
Connect and control your content via the cloud with HTML5
Connect and control your content via the cloud with the integrated HTML5 browser. Design your signage content online and connect it with a display or with your complete network. Simply plug in a RJ45 internet cable for network connection, connect the display with the dedicated url-address and you are ready to play your cloud based content. -
Keep your content up and running with FailOver
Keeping your content up and running is critical for demanding commercial applications. While it is unlikely you will face a content disaster, FailOver provides 24/7 protection with a revolutionary technology that plays back-up content on screen in the event of a media player failure. FailOver automatically kicks in when the primary input fails. Simply select a primary input connection and a FailOver connection and you are ready for instant protection. -
Schedule what you want, when you want with SmartPlayer
Save your Digital Signage content (video, audio, pictures) on your USB and plug into your display & enjoy your own created playlists 24 hours a day, 7 days a week. -
SmartPower for energy saving
The backlight intensity can be controlled and pre-set by the system to reduce the power consumption by up to 50%, which saves substantially on energy costs. -
Designed for 24/7 operation
Because business never sleeps, the signage displays are designed for 24/7 use. Taking advantage of superior components to ensure a higher level of quality, you can count on this range of models for complete around-the-clock reliability. -
Connect your display and start sharing with DLNA
Simply share & stream content from your mobile device or media player to your display with all DLNA compliant media devices. Connect each display with an ethernet cable and manage your content real time within your local network. Simply connect your display and start sharing. -
Full HD LED technology for brilliant images
White LED's are solid state devices which light up to full, consistent brightness faster saving startup time. LED's are free from mercury content which allows for eco-friendly recycling and disposal process. LED's allow for better dimming control of LCD backlight, resulting in super high contrast ratio. It also gives superior color reproduction thanks to consistent brightness across the screen. -
IPS wide view technology for image and color accuracy
Philips IPS displays uses an advanced technology which gives you extra wide viewing angles of 178/178 degree, making it possible to view the display from almost any angle - even in portrait mode. IPS displays gives you remarkably crisp images with vivid colors, especially suitable for professional video wall and menu board applications which demand color accuracy and consistent brightness at all times.
- Philips BDL3260EL E-Line - 32" Class (31.55" viewable) LED-backlit LCD display - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 32"
- Diagonal Size
- 31.55"
- Commercial Use
- Yes - digital signage
- Resolution
- 1920 x 1080
- Input Video Formats
- 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
- Max Number of Screens
- 100
- Video Interface
- Component, composite, HDMI
- HDMI Ports Qty
- 2 ports
- Connectivity
- LAN
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- HDCP Compatible
- Technology
- IPS
- LCD Backlight Technology
- Edge-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Commercial Features
- Digital signage, HTML5 support
- Settings Cloning Capability
- Speaker System
- 2 speakers
- USB
- Included Accessories
- Remote control, batteries
- Voltage
- AC 100/230 V (50/60 Hz)
- 48.57 Watt
- Power Consumption Stand by
- 0.3 Watt
- 75.02 cm x 6.9 cm x 44.46 cm
- 11.4 kg
- Environmental Standards
- ENERGY STAR Qualified
- 3-year warranty
- Product Type
- 48.57 Watt
- Diagonal Class
- 32"
- Diagonal Size
- 31.55"
- Commercial Use
- Series
- E-Line
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI Ports Qty
- 2 ports
- PC Interface
- HDCP Compatible
- Modes
- Portrait mode, landscape mode
- 75.02 cm
- 6.9 cm
- 44.46 cm
- 11.4 kg
Display
- LCD Display Technology
- IPS
- Resolution
- 1920 x 1080
- 16:9
- Edge-lit LED
- Colour Depth
- 16.7 million colours
- Image Contrast Ratio
- 1300:1
- Dynamic Contrast Ratio
- 500000:1
- Brightness
- 400 cd/m²
- Widescreen Modes
- 16:9
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Pixel Pitch
- 0.36 x 0.36mm
- Pull-Down Compensation
- 3:2, 2:2
- Response Time
- 25 ms
- Display Menu Language
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Polish, Russian, Spanish, Turkish, Arabic, Japanese
- Backlight Life
- 60,000 hour(s)
- Comb Filter
- 3D digital
- Dynamic Contrast, 3D MA deinterlacing, Smart Insert, Smart Control, Motion Compensation, SmartCMS
Video Wall
- 100
Stands & Mounts
- Stand
- Optional
- Flat Panel Mount Interface
- 100 x 100 mm, 400 x 200 mm
Video Features
- Supported Computer Resolutions
- 1366 x 768, 1920 x 1200 (WUXGA), 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1360 x 768, 1920 x 1080, 1440 x 900, 1280 x 800
Media Player
- Supported Video Formats
- MPEG-4, WMV, MKV, VOB, TS, M2TS, M4V, MPG, MPEG, MTS
- Supported Audio Formats
- MP3, WMA, WAV, AAC, AIFF, LPCM, M4A
- Supported Pictures Formats
- BMP, JPG, GIF
- USB Port
- USB Ports Qty
- 1
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x main channel speaker - 10 Watt
Network & Internet Multimedia
- Functionality
- WEB browsing
- Connectivity
- LAN
- DLNA
- Connector Type
- DisplayPort input , 2 x HDMI input , DVI-D input , VGA input , USB , Component video input , Composite video input , DisplayPort output , DVI-I , VGA output , Audio line-in , Audio line-in , Audio line-out , Speakers output , LAN , Serial , Remote control
- Batteries
- Cables Included
- VGA cable , Serial cable
- FCC Class B certified, UL, VCCI, C-Tick, BSMI, GOST, cUL, CB, CCC, RoHS, PSE Mark, J-MOSS
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 6.0
- Power Device
- Power supply
- Input Voltage
- 0.3 Watt
- Smart power
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 20 - 80%
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
