Philips B-Line 346B1C 34" 3440x1440 5ms HDMI DisplayPort USB-C Curved LED Monitor
Quicklinx: FR9FWS00 Mfr#: 346B1C/00
Diagonal Size: 34in
Max Resolution: 3440 x 1440
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DisplayPort, USB-C, HDMI
£362.10 ex VAT
£434.52 inc VAT
See more. Do more.
The Philips B line 34" curved UltraWide display gives wrap-around view of your work. All-in-one USB-C and ergonomic stand design make for optimal working conditions. Eye comfort features with TUV certified to reduce eye fatigue.
CrystalClear images with UltraWide QHD 3440 x 1440 pixels
These Philips screens deliver Crystal Clear, UltraWide Quad HD 3440 x 1440 pixel images. Utilising high-performance panels with high-density pixel count and 178/178 wide viewing angles, these new displays will make your images and graphics come alive. The UltraWide 21:9 format enables more productivity with more room for side-by-side comparisons and more viewable spreadsheet columns. Whether you are a demanding professional requiring extremely detailed information for CAD-CAM solutions or a financial wizard working on huge spreadsheets, Philips displays deliver Crystal Clear images.
Built-in KVM switch to easily switch between sources
With the MultiClient Integrated KVM switch, you can control two separate PCs with one monitor-keyboard-mouse setup. A convenient button allows you to quickly switch between sources. Handy with setups that require dual PC computing power or sharing one large monitor to show two different PCs.
Built-in USB-C docking station
This Philips display features a built-in USB type-C docking station with power delivery. Its slim, reversible USB-C connector allows for easy, one-cable docking. Keep it simple by connecting all your peripherals, like your keyboard, mouse and your RJ-45 Ethernet cable to the monitor's docking station. Simply connect your notebook to this monitor with a single USB-C cable to watch high-resolution video and transfer super-speed data while powering up and recharging your notebook at the same time.
Effortlessly smooth action with Adaptive-Sync technology
Gaming shouldn't be a choice between choppy gameplay or broken frames. Get fluid, artefact-free performance at virtually any frame rate with Adaptive-Sync technology, smooth quick refresh and ultra-fast response time.
TUV Eye Comfort certified to reduce eye fatigue
Philips displays meet TUV Rheinland Eye Comfort standard to prevent eye strain caused by prolonged computer use. With TUV Eye Comfort certification, Philips displays ensure flicker-free, low-blue mode, no disturbing reflections, a wide viewing angle, less reduction of image quality from different angles and ergonomic stand designs for an ideal viewing experience. Keep your eyes healthy and boost work productivity.
Less eye fatigue with Flicker-Free technology
Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips Flicker-Free technology applies a new solution to regulate brightness and reduce flicker for more comfortable viewing.
LowBlue Mode for easy-on-the-eyes productivity
Studies have shown that just as ultra-violet rays can cause eye damage, shortwave-length blue light rays from LED displays can cause eye damage and affect vision over time. Developed for wellbeing, the Philips LowBlue Mode setting uses a smart software technology to reduce harmful shortwave blue light.
PowerSensor saves up to 70% energy costs
PowerSensor is a built-in 'people sensor' that transmits and receives harmless infrared signals to determine if the user is present and automatically reduces monitor brightness when the user steps away from the desk, cutting energy costs by up to 70 percent and prolonging monitor life.
LightSensor for the perfect brightness with minimal power
LightSensor uses a smart sensor to adjust the picture brightness depending on the light conditions in the room for the perfect picture with minimal power usage.
VA display delivers awesome images with wide viewing angles
The Philips VA LED display uses an advanced multi-domain vertical alignment technology that gives you super-high static contrast ratios for extra-vivid and bright images. While standard office applications are handled with ease, it is especially suitable for photos, web browsing, films, gaming and demanding graphical applications. Its optimised pixel management technology gives you a 178/178 degree extra-wide viewing angle, resulting in crisp images.
Tilt, swivel and height-adjust for an ideal viewing position
The Compact Ergo Base is a people-friendly Philips monitor base that tilts, swivels and height-adjusts so each user can position the monitor for maximum viewing comfort and efficiency.
EasyRead mode for a paper-like reading experience
  • Flicker-Free technology
  • LowBlue Mode
  • VA display
    Philips' VA LED display uses an advanced multi-domain vertical alignment technology that gives you super-high static contrast ratios for extra-vivid and bright images. While standard office applications are handled with ease, it is especially suitable for photos, web browsing, films, gaming and demanding graphical applications. Its optimised pixel management technology gives you a 178/178-degree extra-wide viewing angle, resulting in crisp images.
  • Built-in USB-C docking station
  • UltraWide CrystalClear images
  • MultiView technology
    With the ultra-high resolution Philips MultiView display, you can now experience a world of connectivity. MultiView enables active dual connect and view so that you can work with multiple devices like a PC and notebook simultaneously, for complex multitasking.
  • Adaptive-Sync technology
  • Compact Ergo Base
  • LightSensor
  • MultiClient Integrated KVM
  • VESA mount
    VESA pattern guarantees compatibility with hundreds of innovative mounting solutions.
  • PowerSensor
    PowerSensor is a built-in'people sensor' that transmits and receives harmless infrared signals to determine if the user is present and automatically reduces monitor brightness when the user steps away from the desk, cutting energy costs by up to 70 percent and prolonging monitor life.
Philips B Line 346B1C - LED monitor - curved - 34"
LED-backlit LCD monitor - 34"
Energy Class
Class F
Energy Consumption per Year
79 kWh
Power Consumption (On mode)
31 W
Curved Screen
KVM Switch, Gigabit Ethernet network adapter, USB 3.2 Gen 1 hub, USB PD 90 Watt
Panel Type
VA
Aspect Ratio
21:9
Native Resolution
UWQHD 3440 x 1440 at 100 Hz
Pixel Pitch
0.232 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1 / 80000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
100% NTSC, 119% NTSC, 90% Adobe RGB
Input Connectors
HDMI, DisplayPort, USB-C
Built-in Ethernet
Display Position Adjustments
Height, swivel, tilt
Screen Coating
Anti-glare, 2H Hard Coating, Haze 25%
Voltage
Black texture
80.7 cm x 25 cm x 60.1 cm
11.49 kg
Environmental Standards
TCO Certified Displays 8, ENERGY STAR Qualified
Plug and Play, FCC Class B certified, SEMKO, DDC/CI, RoHS, ISO 9241-307, TUV Bauart, EPA, cETLus, CU-EAC, DisplayPort 1.2, HDCP 2.2
Display Type
Energy Class
Class F
79 kWh
Diagonal Size
34"
Viewable Size
34"
Curved Screen
Yes (1500R)
Built-in Devices
USB Power Delivery
90 Watt
Panel Type
VA
Aspect Ratio
21:9
Native Resolution
Pixel Pitch
0.232 mm
Pixel Per Inch
110
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
48 - 100 Hz
Horizontal Refresh Rate
30 - 160 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
OSD Languages
Multilingual
Picture by picture, Sync on Green, Lead-free, SmartImage, Low Blue Light Mode, Flicker Free technology, BFR/PVC-free, Mercury free, Adaptive-Sync technology, EasyRead, sRGB Mode, Picture-in-Picture, Delta E<2 calibration
Black texture
80.7 cm x 25 cm x 60.1 cm - with stand
11.49 kg
Audio
Speakers - stereo
Output Power / Channel
5 Watt
DisplayPort (HDCP) , HDMI (HDCP) , USB-C (power up to 90W) , USB upstream , USB 3.2 downstream (fast charging) , 3 x USB 3.2 downstream , Headphones , Network (RJ-45)
Mechanical
Tilt Angle
-5/+30
Swivel Angle
360
Height Adjustment
180 mm
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable , 1 x DisplayPort cable , 1 x USB-C to USB-A cable
MTBF
70,000 hour(s)
Security Slot Type
Kensington security slot
Input Voltage
31 W
31 kWh/1000h
Power Consumption (Typical)
46.8 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
On / Off Switch
Included Software
Philips SmartControl
Dimensions & Weight Details
With stand - width: 80.7 cm - depth: 25 cm - height: 60.1 cm - weight: 11.49 kg , Without stand - width: 80.7 cm - depth: 11 cm - height: 36.7 cm - weight: 7.79 kg
Shipping Width
93 cm
Shipping Depth
28.2 cm
Shipping Height
52.5 cm
Shipping Weight
15.32 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
ENERGY STAR Version
7.0
20 - 80%
Diagonal Size: 34in
Response Time: 5ms
Interfaces: USB-C
Interfaces: HDMI
Brand: Philips
