Philips B-Line 272B7QUPBEB 27" 2560x1440 5ms HDMI DisplayPort USB-C IPS LED Monitor
Quicklinx: DRL5WS00 Mfr#: 272B7QUPBEB/00
Diagonal Size: 27in
Max Resolution: 2560 x 1440
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, USB-C
Hurry, only 1 left in stock!
£288.47 ex VAT
£346.16 inc VAT
This Philips QHD monitor with USB-C docking replaces cable clutter. View QHD images, secure connect to intranet and re-charge your notebook all at the same time with a single USB-C cable.
  • LowBlue Mode
    Studies have shown that just as ultra-violet rays can cause eye damage, shortwave-length blue light rays from LED displays can cause eye damage and affect vision over time. Developed for wellbeing, the Philips LowBlue Mode setting uses a smart software technology to reduce harmful shortwave blue light.
  • Ultra-narrow Border
    The new Philips displays feature ultra-narrow borders which allow for minimal distractions and maximum viewing size. Especially suited for multi-display or tiling setups like gaming, graphic design and professional applications, the ultra-narrow border display gives you the feeling of using one large display.
  • Ultra Wide-Color Technology
    Ultra Wide-Color Technology delivers a wider spectrum of colours for a more brilliant picture. The Ultra Wide-Color wider"colour gamut" produces more natural-looking greens, vivid reds and deeper blues. Bring media entertainment, images and even productivity more alive with vivid colours from Ultra Wide-Color Technology.
  • IPS technology
    IPS displays use advanced technology that gives you extra-wide viewing angles of 178/178 degrees, making it possible to view the display from almost any angle- even in 90-degree Pivot mode! Unlike standard TN panels, IPS displays gives you remarkably crisp images with vivid colours, making it ideal not only for Photos, films and web browsing, but also for professional applications that demand colour accuracy and consistent brightness at all times.
  • Built-in USB-C docking station
    This Philips display features a built-in USB 3.1 type-C docking station with power delivery. Its slim, reversible USB-C connector allows for easy, one-cable docking. Simplify by connecting all of your peripherals like keyboard, mouse and your RJ-45 Ethernet cable to the monitor's docking station. Simply connect your notebook and this monitor with a single USB-C cable to watch high-resolution video and transfer super-speed data, while powering up and re-charging your notebook at the same time.
  • USB-C connection
    This Philips display features a USB type-C connector with power delivery. With intelligent and flexible power management, you can power charge your compatible laptop directly. Its slim, reversible USB-C allows for easy, one-cable connection. You can watch high-resolution video and transfer data at super speed, while powering up and re-charging your notebook at the same time.
Philips B Line 272B7QUPBEB - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
61 kWh
Power Consumption (On mode)
42 W
USB-C hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
1440p (Quad HD) 2560 x 1440 at 60 Hz
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 50000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DisplayPort, USB-C
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating, low haze
Black texture
61.4 cm x 25.7 cm x 54.8 cm
7.38 kg
Environmental Standards
TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified
FCC Class B certified, ICES-003, SEMKO, CB, CCC, TUV Ergo, PSB, DDC/CI, Lead-Free, CECP, CEL, EPA, cETLus, CU-EAC, Ukraine
Display Type
Energy Class
Class B
61 kWh
42 W
Diagonal Size
27"
Built-in Devices
USB-C hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.233 mm
Pixel Per Inch
109
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
30 - 99 Hz
Horizontal Refresh Rate
50 - 76 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
PowerSensor, SmartImage, Low Blue Light Mode, Flicker Free technology, Mercury free, EasyRead, 132% sRGB colour gamut, 114% NTSC colour gamut
Black texture
61.4 cm x 25.7 cm x 54.8 cm - with stand
7.38 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
DisplayPort , HDMI , DisplayPort output , USB-C 3.1 Gen 2 upstream , 3 x USB 3.1 downstream (fast charging)
Mechanical
Tilt Angle
-5/+30
Swivel Angle
350
Rotation Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
HDMI cable , DisplayPort cable , USB-C to USB-A cable , USB-C cable
MTBF
70,000 hour(s)
24 Watt
Power Consumption Stand by
0.5 Watt
On / Off Switch
Dimensions & Weight Details
With stand - width: 61.4 cm - depth: 25.7 cm - height: 54.8 cm - weight: 7.38 kg , Without stand - width: 61.4 cm - depth: 5.6 cm - height: 37.2 cm - weight: 4.95 kg
Shipping Width
69 cm
Shipping Depth
45.8 cm
Shipping Height
25.2 cm
Shipping Weight
10.16 kg
TCO Certified
ENERGY STAR Certified
ENERGY STAR Version
7.0
20 - 80%
Diagonal Size: 27in
Response Time: 5ms
Interfaces: HDMI
Interfaces: USB-C
Brand: Philips
Price Range Ex VAT: 150 - 300
