This Philips QHD monitor with USB-C docking replaces cable clutter. View QHD images, secure connect to intranet and re-charge your notebook all at the same time with a single USB-C cable.
LowBlue Mode
Studies have shown that just as ultra-violet rays can cause eye damage, shortwave-length blue light rays from LED displays can cause eye damage and affect vision over time. Developed for wellbeing, the Philips LowBlue Mode setting uses a smart software technology to reduce harmful shortwave blue light. -
Ultra-narrow Border
The new Philips displays feature ultra-narrow borders which allow for minimal distractions and maximum viewing size. Especially suited for multi-display or tiling setups like gaming, graphic design and professional applications, the ultra-narrow border display gives you the feeling of using one large display. -
Ultra Wide-Color Technology
Ultra Wide-Color Technology delivers a wider spectrum of colours for a more brilliant picture. The Ultra Wide-Color wider"colour gamut" produces more natural-looking greens, vivid reds and deeper blues. Bring media entertainment, images and even productivity more alive with vivid colours from Ultra Wide-Color Technology. -
IPS technology
IPS displays use advanced technology that gives you extra-wide viewing angles of 178/178 degrees, making it possible to view the display from almost any angle- even in 90-degree Pivot mode! Unlike standard TN panels, IPS displays gives you remarkably crisp images with vivid colours, making it ideal not only for Photos, films and web browsing, but also for professional applications that demand colour accuracy and consistent brightness at all times. -
Built-in USB-C docking station
This Philips display features a built-in USB 3.1 type-C docking station with power delivery. Its slim, reversible USB-C connector allows for easy, one-cable docking. Simplify by connecting all of your peripherals like keyboard, mouse and your RJ-45 Ethernet cable to the monitor's docking station. Simply connect your notebook and this monitor with a single USB-C cable to watch high-resolution video and transfer super-speed data, while powering up and re-charging your notebook at the same time. -
USB-C connection
This Philips display features a USB type-C connector with power delivery. With intelligent and flexible power management, you can power charge your compatible laptop directly. Its slim, reversible USB-C allows for easy, one-cable connection. You can watch high-resolution video and transfer data at super speed, while powering up and re-charging your notebook at the same time.
- Philips B Line 272B7QUPBEB - LED monitor - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class B
- Energy Consumption per Year
- 61 kWh
- Power Consumption (On mode)
- 42 W
- USB-C hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- 1440p (Quad HD) 2560 x 1440 at 60 Hz
- Pixel Pitch
- 0.233 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1 / 50000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DisplayPort, USB-C
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating, low haze
- Black texture
- 61.4 cm x 25.7 cm x 54.8 cm
- 7.38 kg
- Environmental Standards
- TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified
- FCC Class B certified, ICES-003, SEMKO, CB, CCC, TUV Ergo, PSB, DDC/CI, Lead-Free, CECP, CEL, EPA, cETLus, CU-EAC, Ukraine
- Display Type
- Energy Class
- Class B
- 61 kWh
- Diagonal Size
- 27"
- Built-in Devices
- USB-C hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.233 mm
- Pixel Per Inch
- 109
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 30 - 99 Hz
- Horizontal Refresh Rate
- 50 - 76 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- WLED
- OSD Languages
- Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
- PowerSensor, SmartImage, Low Blue Light Mode, Flicker Free technology, Mercury free, EasyRead, 132% sRGB colour gamut, 114% NTSC colour gamut
- Black texture
- 61.4 cm x 25.7 cm x 54.8 cm - with stand
- 7.38 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
- DisplayPort , HDMI , DisplayPort output , USB-C 3.1 Gen 2 upstream , 3 x USB 3.1 downstream (fast charging)
Mechanical
- Tilt Angle
- -5/+30
- Swivel Angle
- 350
- Rotation Angle
- 90
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- HDMI cable , DisplayPort cable , USB-C to USB-A cable , USB-C cable
- MTBF
- 70,000 hour(s)
- Voltage Required
- AC 120/230 V (50/60 Hz)
- 42 W
- 24 Watt
- Power Consumption Stand by
- 0.5 Watt
- On / Off Switch
- Dimensions & Weight Details
- With stand - width: 61.4 cm - depth: 25.7 cm - height: 54.8 cm - weight: 7.38 kg , Without stand - width: 61.4 cm - depth: 5.6 cm - height: 37.2 cm - weight: 4.95 kg
- Shipping Width
- 69 cm
- Shipping Depth
- 45.8 cm
- Shipping Height
- 25.2 cm
- Shipping Weight
- 10.16 kg
- TCO Certified
- ENERGY STAR Certified
- ENERGY STAR Version
- 7.0
- 0 °C
- 40 °C
- 20 - 80%
