Philips B-Line 272B7QUPBEB 27" 2560x1440 5ms HDMI DisplayPort USB-C IPS LED Monitor
Quicklinx: DRL5WS00 Mfr#: 272B7QUPBEB/00
Diagonal Size: 27in
Max Resolution: 2560 x 1440
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DisplayPort, USB-C, HDMI
Hurry, only 2 left in stock!
£303.16 ex VAT
£363.79 inc VAT
This Philips QHD monitor with USB-C docking replaces cable clutter. View QHD images, secure connect to intranet and re-charge your notebook all at the same time with a single USB-C cable.
  • USB-C connection
    This Philips display features a USB type-C connector with power delivery. With intelligent and flexible power management, you can power charge your compatible device directly. Its slim, reversible USB-C allows for easy, one-cable connection. You can watch high-resolution video and transfer data at super speed, while powering up and recharging your compatible device at the same time.
Philips B Line 272B7QUPBEB - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class E
Energy Consumption per Year
61 kWh
Power Consumption (On mode)
22 W
USB-C hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
1440p (Quad HD) 2560 x 1440 at 60 Hz
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 50000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DisplayPort, USB-C
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating, low haze
Voltage
Black texture
61.4 cm x 25.7 cm x 54.8 cm
7.38 kg
Environmental Standards
TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified
FCC Class B certified, ICES-003, SEMKO, CB, CCC, TUV Ergo, PSB, DDC/CI, Lead-Free, CECP, CEL, EPA, cETLus, CU-EAC, Ukraine
Display Type
Energy Class
Class E
61 kWh
Diagonal Size
27"
Built-in Devices
USB-C hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.233 mm
Pixel Per Inch
109
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
30 - 99 Hz
Horizontal Refresh Rate
50 - 76 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
PowerSensor, SmartImage, Low Blue Light Mode, Flicker Free technology, Mercury free, EasyRead, 132% sRGB colour gamut, 114% NTSC colour gamut
Black texture
61.4 cm x 25.7 cm x 54.8 cm - with stand
7.38 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
DisplayPort , HDMI , DisplayPort output , USB-C 3.1 Gen 2 upstream , 3 x USB 3.1 downstream (fast charging)
Mechanical
Tilt Angle
-5/+30
Swivel Angle
350
Rotation Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
HDMI cable , DisplayPort cable , USB-C to USB-A cable , USB-C cable
MTBF
70,000 hour(s)
Input Voltage
22 W
22 kWh/1000h
Power Consumption (Typical)
24 Watt
Power Consumption Stand by
0.5 Watt
On / Off Switch
Dimensions & Weight Details
With stand - width: 61.4 cm - depth: 25.7 cm - height: 54.8 cm - weight: 7.38 kg , Without stand - width: 61.4 cm - depth: 5.6 cm - height: 37.2 cm - weight: 4.95 kg
Shipping Width
69 cm
Shipping Depth
45.8 cm
Shipping Height
25.2 cm
Shipping Weight
10.16 kg
TCO Certified
ENERGY STAR Certified
ENERGY STAR Version
7.0
20 - 80%
Diagonal Size: 27in
Response Time: 5ms
Interfaces: USB-C
Interfaces: HDMI
Brand: Philips
Stock Status: In stock
