The Philips B line monitor with USB-C docking replaces cable clutter. View Full HD image and recharge your laptop all at the same time with a single USB-C cable. SmartErgo base, Flicker-free and LowBlue mode make work easy on the eyes.
PowerSensor
PowerSensor is a built-in'people sensor' that transmits and receives harmless infrared signals to determine if the user is present and then automatically reduces monitor brightness when then user steps away from the desk, cutting energy costs by up to 80 percent and prolonging monitor life -
SmartErgoBase
The SmartErgoBase is a monitor base that delivers ergonomic display comfort and provides cable management. The user-friendly height, swivel, tilt and rotation angle adjustments of the base allow the monitor to be positioned for maximum comfort to help ease the physical strains of a long workday. In addition, cable management reduces cable clutter and keeps the workspace neat and professional. -
HDMI Ready
An HDMI-ready device has all the required hardware to accept High-Definition Multimedia Interface (HDMI) input. An HDMI cable enables high-quality digital video and audio to be transmitted over a single cable from a PC or any number of AV sources (including set-top boxes, DVD players, A/V receivers and video cameras). -
Flicker-Free technology
Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips Flicker-Free technology applies a new solution to regulate brightness and reduce flicker for more comfortable viewing. -
LowBlue Mode
Studies have shown that just as ultra-violet rays can cause eye damage, shortwave-length blue light rays from LED displays can cause eye damage and affect vision over time. Developed for wellbeing, the Philips LowBlue Mode setting uses a smart software technology to reduce harmful shortwave blue light. -
USB-C connection
This Philips display features a USB type-C connector with power delivery. With intelligent and flexible power management, you can power charge your compatible laptop directly. Its slim, reversible USB-C allows for easy, one-cable connection. You can watch high-resolution video and transfer data at super speed, while powering up and re-charging your notebook at the same time.
- Philips B Line 243B9 - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class D
- Energy Consumption per Year
- 36 kWh
- Power Consumption (On mode)
- 14.8 W
- Adaptive-Sync Technology
- VESA Adaptive-Sync
- USB 3.2 hub, USB PD 65 Watt
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 75 Hz
- Pixel Pitch
- 0.275 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 50000000:1 (dynamic)
- Response Time
- 4 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 104% sRGB, 90% NTSC (CIE 1976)
- Input Connectors
- HDMI, VGA, DisplayPort, USB-C
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Haze 25%, anti-glare 3H hardness
- Voltage
- AC 120/230 V (50/60 Hz)
- Black texture
- 54.1 cm x 21.6 cm x 52.2 cm
- 5.19 kg
- Environmental Standards
- TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified
- Plug and Play, FCC Class B certified, TUV GS, VCCI, ICES-003, SASO, SEMKO, CCC, TUV Ergo, DDC/CI, RoHS, WEEE, KUCAS, EPA, cETLus, RCM, CU-EAC, DisplayPort 1.2, HDCP 1.4
- Display Type
- Energy Class
- Class D
- 36 kWh
- Diagonal Size
- 24"
- Viewable Size
- 23.8"
- Built-in Devices
- USB 3.2 hub
- USB Power Delivery
- 65 Watt
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.275 mm
- Pixel Per Inch
- 93
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- Vertical Refresh Rate
- 48 - 75 Hz
- Horizontal Refresh Rate
- 30 - 85 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- WLED
- OSD Languages
- Multilingual
- Sync on Green, sRGB colour management, SmartImage, Low Blue Light Mode, Flicker Free technology, EasyRead
- Black texture
- 54.1 cm x 21.6 cm x 52.2 cm - with stand
- 5.19 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
- VGA , USB-C 3.2 Gen 1 (power up to 65W) , DisplayPort (HDCP) , HDMI (HDCP) , 3 x USB-C 3.2 Gen 2 downstream , USB-C 3.2 Gen 2 downstream (fast charging) , Audio line-in , Headphones
Mechanical
- Tilt Angle
- -5/+30
- Swivel Angle
- 350
- Rotation Angle
- 180
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x DisplayPort cable , 1 x USB-C to USB-A cable , 1 x HDMI cable
- MTBF
- 70,000 hour(s)
- Security Slot Type
- Kensington security slot
- Input Voltage
- 14.8 W
- Power Consumption SDR (On mode)
- 14.8 kWh/1000h
- Power Consumption (Typical)
- 17.1 Watt
- Power Consumption Stand by
- 0.3 Watt
- 0 Watt
- On / Off Switch
- Included Software
- Philips SmartControl
- Dimensions & Weight Details
- With stand - width: 54.1 cm - depth: 21.6 cm - height: 52.2 cm - weight: 5.19 kg , Without stand - width: 54.1 cm - depth: 6.3 cm - height: 33.2 cm - weight: 3.57 kg
- Shipping Width
- 60 cm
- Shipping Depth
- 19.8 cm
- Shipping Height
- 47.5 cm
- Shipping Weight
- 6.89 kg
- TCO Certified
- ENERGY STAR Certified
- ENERGY STAR Version
- 7.0
- 0 °C
- 40 °C
- 20 - 80%
