Philips 86BDL3012T 86" 3840x2160 8ms VGA DVI HDMI DisplayPort LED Display
Quicklinx: FFC5WS00 Mfr#: 86BDL3012T/00
Inspire collaboration. Deliver information. This responsive Philips Multi-Touch Professional UHD display is ideal for multi-finger, multi-user applications - from wayfinding to presentations. Up to 20 touch points can be active at once.
  • CMND & Control
    Run your display network over a local (LAN) connection. CMND & Control allows you to perform vital functions like controlling inputs and monitoring display status. Whether you're in charge of one screen or 100.
  • QuadViewer
    Turn a single Philips professional display into a bezel-free 2x2 videowall. By connecting four independent sources, you can effortlessly play multiple channels at once. Simply tell the display which zone should play which content. Ideal for situations like broadcast control rooms, where feeds from multiple cameras need to be clearly visible.
  • FailOver
    From waiting room to meeting room, never show a blank screen. FailOver lets your Philips professional display switch automatically between primary and secondary inputs ensuring content keeps playing even if the primary source goes down. Simply set a list of alternate inputs to be sure your business is always on.
Philips Signage Solutions 86BDL3012T 86" Class (85.6" viewable) LED-backlit LCD display - 4K - for digital signage / interactive communication
LED-backlit LCD flat panel display with touchscreen
Diagonal Class
86"
Diagonal Size
85.6"
Commercial Use
Yes - interactive digital signage
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Input Video Formats
480/60p, 720/60p, 1080/50i, 576/50p, 1080/60p, 480/60i, 576/50i, 2K, 4K
Max Number of Screens
225
Video Interface
Component, HDMI
HDMI Ports Qty
3 ports
LAN
PC Interface
DVI, VGA (HD-15), DisplayPort
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Picture Enhancements
3D Digital Comb Filter
Speaker System
2 speakers
USB
Remote control, batteries
Voltage
471 Watt
Power Consumption Stand by
0.5 Watt
195.7 cm x 9.84 cm x 112.8 cm
3-year warranty
471 Watt
Diagonal Class
86"
Diagonal Size
85.6"
Commercial Use
Combined With
Touchscreen
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
Component, HDMI
HDMI Ports Qty
3 ports
PC Interface
Modes
Landscape mode
Dimensions
Without stand
195.7 cm
9.84 cm
112.8 cm
Display
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
LED backlight
Image Contrast Ratio
1200:1
Dynamic Contrast Ratio
500000:1
Brightness
410 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pull-Down Compensation
3:2, 2:2
Touchpoints Qty
20
Response Time
8 ms
Display Menu Language
Multilingual
Backlight Life
50,000 hour(s)
3D MA deinterlacing, picture in picture (no tuner), OPS Slot
Video Wall
225
Stands & Mounts
Flat Panel Mount Interface
600 x 400 mm
VESA Compatibility
Video Features
Input Video Formats
Supported Computer Resolutions
1366 x 768, 1440 x 1050, 1920 x 1200 (WUXGA), 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 832 x 624, 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1152 x 864, 1280 x 960, 1280 x 720, 640 x 350, 720 x 400, 848 x 480, 1152 x 870, 1152 x 900, 1360 x 768, 1680 x 1050 (WSXGA+), 1920 x 1080, 1440 x 900, 1280 x 800, 1400 x 1050, 1600 x 900, 3840 x 2160, 4096 x 2160, 960 x 720
Media Player
Supported Video Formats
MPEG-4, MKV, VOB, TS, M2TS, M4V, MPG, MPEG, MTS, MK3D, ISM, MPD, MT2
Supported Audio Formats
MP3, WMA, WAV, AAC, AIFF, M4A, AIF, ASF, M3U, MP4
Supported Pictures Formats
BMP, GIF, PNG, JPEG
USB Port
USB Ports Qty
1
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x speaker - 10 Watt
Network & Internet Multimedia
LAN
Connector Type
3 x HDMI input , DisplayPort input , DVI-D input , VGA input , Component video input , RS-232C input , DisplayPort output , RS-232C output , Remote control , Audio line-out , Audio line-in , SPDIF output , Audio line-out , Speakers output , USB , Infrared input , Infrared output
Batteries
HDMI cable , Serial cable , Remote control cable - 1.8 m , USB cable
FCC Class B certified, UL, VCCI, BSMI, cUL, CB, CCC, PSB, RoHS, EAC
Power supply
Input Voltage
0.5 Watt
Limited warranty - 3 years
20 - 80%
