Philips 75BDL3010T 75" 3840x2160 8ms VGA DVI HDMI DisplayPort IPS LED Display
Quicklinx: FFBYWS00 Mfr#: 75BDL3010T/00
TV Tuner Presence: No
Video Interface: Component, Composite, HDMI
Hurry, only 3 left in stock!
£2,588.24 ex VAT
£3,105.88 inc VAT
Get even closer to your audience. Fast, precise and extremely durable, this display's high performance is matched by excellent reliability and functionality.
  • Experience amazing interactivity
    An incredible level of interactivity is available thanks to integrated touch technology. More flexibility and optimal simultaneous touch performance coupled with excellent operability opportunities to give you much better user interaction.
  • Keep your content up and running
    Keeping your content up and running is critical for demanding commercial applications. While it is unlikely you will face a content disaster, FailOver provides content protection with an incredible technology that plays back-up content on screen in the event of a media player failure.
  • Take control of your displays
    A robust display management platform, CMND puts the power back into your hands. Update and manage content with CMND & create or control your settings. It's all possible with CMND.
Philips Signage Solutions 75BDL3010T 75" LED display - 4K
LED-backlit LCD flat panel display with touchscreen
Diagonal Class
75"
Commercial Use
Yes - interactive digital signage
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Input Video Formats
1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
Video Interface
Component, composite, HDMI
HDMI Ports Qty
2 ports
LAN
PC Interface
DVI, VGA (HD-15), DisplayPort
IPS
LCD Backlight Technology
LED backlight - edge-lit
Image Aspect Ratio
16:9
TV Tuner
No tuner
Picture Enhancements
Dynamic contrast enhancement, Pixel Shift
Speaker System
2 speakers
USB
Remote Control
Standard remote
Voltage
Energy Class
Class A
Power Consumption (On mode)
196 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
286 kWh
170.97 cm x 9.25 cm x 98.86 cm
3-year warranty
Energy Class
Class A
196 W
286 kWh
Diagonal Class
75"
Commercial Use
Combined With
Touchscreen
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI Ports Qty
2 ports
PC Interface
Modes
Landscape mode
Protection
Protection glass
Dimensions
Without stand
170.97 cm
9.25 cm
98.86 cm
Display
LCD Display Technology
IPS
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
LED backlight - edge-lit - edge-lit
Coating
Anti-glare
Image Contrast Ratio
1400:1
Dynamic Contrast Ratio
500000:1
Brightness
410 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pull-Down Compensation
3:2, 2:2
Touchpoints Qty
10
Response Time
8 ms
Display Menu Language
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Polish, Russian, Spanish, Turkish, Arabic, Japanese
Backlight Life
50,000 hour(s)
Infrared touch technology, Certified for 24/7 Continuous Operation, 3D MA deinterlacing, Smart Insert, Open Pluggable Specification slot, Motion Compensation
Stands & Mounts
Flat Panel Mount Interface
600 x 400 mm
Video Features
Input Video Formats
Supported Computer Resolutions
1366 x 768, 1920 x 1200 (WUXGA), 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080, 1440 x 900, 1280 x 800
Media Player
USB Port
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Network & Internet Multimedia
LAN
Connect & Share
USB Human Interface Device (HID)
Connector Type
2 x HDMI input , DisplayPort input , DVI-D input , Component video input , Audio line-in , Composite video input , DisplayPort output , DVI-I output , VGA output , Audio line-out , Audio line-in , Remote control , Speakers output , Remote control , USB
Batteries, carrying handle
VGA cable , Serial cable
Plug and Play, FCC Class B certified, UL, C-Tick, cUL, CCC, CEC, EMF, KUCAS, EPA
Power supply
Nominal Voltage
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
Smart power
Limited warranty - 3 years
5 °C
20 - 80%
Video Interface: Composite
Video Interface: HDMI
Brand: Philips
Price Range Ex VAT: 1500+
