Philips 75BDL3003H 75" 3840x2160 8ms VGA DVI HDMI DisplayPort IPS LED Large Format Display
Quicklinx: FFBXWS00 Mfr#: 75BDL3003H/00
Video Interface: Component, HDMI, Composite
TV Tuner Presence: No
£6,311.12 ex VAT
£7,573.34 inc VAT
Experience your content like never before thanks to four times the resolution of a conventional display. This ultra large 75" display offers 3840 x 2160 pixels so refined, so lifelike, it's a window to an amazing world.
  • High brightness - 3000 nit
    Enjoy an excellent visual experience even in areas illuminated by direct sunlight thanks to the 3000 nit panel. The high brightness offers a wide array of great implementation possibilities especially in locations that have high ambient light levels, delivering crystal clear images for all locations where ambient brightness is an issue.
  • 4K Ultra HD resolution
    See your signage solutions like never before thanks to four times the resolution of a conventional Full HD display. 3840 x 2160 pixels provide and image so refined, so lifelike, it's a window to a different world.
  • QuadViewer
    Be more flexible with your screen real estate. With the ability to play content from up to four separate inputs, all on one screen. QuadViewer is ideal for control rooms, corporate environments, and meeting rooms.
  • CMND
    A robust display management platform, CMND puts the power back into your hands. Update and manage content with CMND & Create or control your settings with CMND & Control. It's all possible with CMND.
  • FailOver
    Keeping your content up and running is critical for demanding commercial applications. While it is unlikely you will face a content disaster, FailOver provides content protection with a revolutionary technology that plays back-up content on screen in the event of a media player failure. FailOver automatically kicks in when the primary input fails. Simply select a primary input connection and a FailOver connection and you're ready for instant protection.
  • SmartPower
    The backlight intensity can be controlled and pre-set by the system to reduce the power consumption, which saves substantially on energy costs.
Philips 75BDL3003H H-Line - 75" Class (74.5" viewable) LED-backlit LCD display - 4K - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
75"
Diagonal Size
74.5"
Commercial Use
Yes - digital signage
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Frame Rate & Enhancement Technology
60 Hz Refresh Rate
Video Interface
Component, composite, HDMI
HDMI Ports Qty
3 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
IPS
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
CMND management
Picture Enhancements
Motion Compensation, dynamic contrast enhancement, Pixel Shift
Speaker System
2 speakers
USB
Remote control, batteries, carrying handle
Voltage
Energy Class
Class C
200 Watt
Power Consumption (On mode)
382 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
558 kWh
168.12 cm x 14.24 cm x 95.66 cm
54.1 kg
3-year warranty
Energy Class
Class C
200 Watt
382 W
558 kWh
Diagonal Class
75"
Diagonal Size
74.5"
Commercial Use
Series
H-Line
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI Ports Qty
3 ports
PC Interface
Modes
Landscape mode
168.12 cm
14.24 cm
95.66 cm
54.1 kg
Display
LCD Display Technology
IPS
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
60 Hz Refresh Rate
LED backlight
Image Contrast Ratio
1200:1
Dynamic Contrast Ratio
500000:1
Brightness
3000 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pull-Down Compensation
3:2, 2:2
Response Time
8 ms
Display Menu Language
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Polish, Russian, Spanish, Turkish, Arabic, Japanese
Backlight Life
50,000 hour(s)
Commercial Features
CMND management
Operation Hours / Days
24 / 7
3D MA deinterlacing, Smart Insert, Intel OPS compatible, picture in picture (no tuner)
Stands & Mounts
Flat Panel Mount Interface
600 x 400 mm
Media Player
Supported Video Formats
MPEG-4, WMV, MKV, VOB, TS, M2TS, M4V, MPG, MPEG, MTS, MK3D, TTS
Supported Audio Formats
MP3, WMA, WAV, AAC, AIFF, LPCM, M4A, AIF, ASF, M3U, MP4
Supported Pictures Formats
BMP, JPG, GIF, JPEG
USB Port
USB Ports Qty
1
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x speaker - 10 Watt
Connector Type
3 x HDMI input , VGA input , DVI-D input , Component video input , DisplayPort input , Audio line-in , DisplayPort output , Audio line-in , Audio line-out , Composite video input , Speakers output , SPDIF output , Serial , LAN , Remote control , USB
Batteries, carrying handle
FCC Class A certified, UL, C-Tick, GOST, cUL, CCC, RoHS
Power supply
Input Voltage
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
Smart power
Limited warranty - 3 years
5 °C
20 - 80%
Video Interface: HDMI
Video Interface: Composite
Brand: Philips
Price Range Ex VAT: £1500+
