Philips 65" Large Format Display LED Full HD
Quicklinx: D37GWS00 Mfr#: 65BDL3000Q/00
TV Tuner Presence: No
Video Interface: Component, Composite, HDMI
  • 1080p (Full HD)
£1,175.29 ex VAT
£1,410.34 inc VAT
Deliver startlingly clear images in a more eco-friendly way with the Q-Line display. High on performance and reliability, yet low on power consumption, it is ideal for projects where no compromise is accepted.
  • CMND
    A robust display management platform, CMND puts the power back into your hands. Update and manage content with CMND & Create or control your settings with CMND & Control. It's all possible with CMND.
  • CMND & Control
    With CMND & Control, easily manage multiple displays in a central location. With real time display monitoring, setting and software updates from a remote location, and the ability to customize and configure multiple displays at once, such as video wall or menu board displays, controlling your suite of displays has never been easier.
  • CMND & Create
    Design and create compelling content with CMND & Create, a powerful authoring tool. With a drag and drop interface, preloaded templates, and integrated widgets, you'll be able to amaze your customers with compelling content. Available in portrait and landscape mode.
  • SmartPlayer
    Turn your USB into a true cost effective digital signage device. Simply save your content (video, audio, pictures) on your USB and plug into your display. Create your playlist and schedule your content via the on screen menu, and enjoy your own created playlists anytime, anywhere.
  • FailOver
    Keeping your content up and running is critical for demanding commercial applications. While it is unlikely you will face a content disaster, FailOver provides 24/7 protection with a revolutionary technology that plays back-up content on screen in the event of a media player failure. FailOver automatically kicks in when the primary input fails. Simply select a primary input connection and a FailOver connection and your ready for instant protection.
  • FailOver for meeting rooms
    Using FailOver, simplify your presentations and videoconferencing. When a meeting or conference room is not in use, background content can run from whatever input source you choose. When the meeting starts and you need to share a presentation or your screen, simply connect your computer and the display automatically switches inputs and shows what's on your screen, with no need to manually switch inputs.
  • Full HD LED technology
    Picture quality matters. Regular displays deliver quality, but you expect more. Imagine crisp detail paired with high brightness, incredible contrast and realistic colors for a true to life picture.
Philips Signage Solutions Q-Line 65BDL3000Q 65" LED display
LED-backlit LCD flat panel display
Diagonal Class
65"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Input Video Formats
1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
Video Wall Components Qty
150
Video Interface
Component, composite, HDMI
HDMI Ports Qty
2 ports
LAN
PC Interface
DVI, VGA (HD-15)
VA
LCD Backlight Technology
LED backlight - direct-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
HTML5 support
Picture Enhancements
Dynamic contrast enhancement, Pixel Shift
Speaker System
2 speakers
USB
Remote Control
Standard remote
Voltage
Energy Class
Class B
Power Consumption (On mode)
186 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
272 kWh
145.87 cm x 5.22 cm x 83.47 cm
24.8 kg
Environmental Standards
ENERGY STAR Qualified
3-year warranty
Energy Class
Class B
186 W
272 kWh
Diagonal Class
65"
Commercial Use
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI Ports Qty
2 ports
PC Interface
DVI, VGA (HD-15)
150
Dimensions
Without stand
145.87 cm
5.22 cm
83.47 cm
24.8 kg
Display
LCD Display Technology
VA
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
Image Contrast Ratio
3000:1
Dynamic Contrast Ratio
500000:1
Brightness
350 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pull-Down Compensation
3:2, 2:2
Response Time
8 ms
Display Menu Language
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Polish, Russian, Spanish, Turkish, Arabic, Japanese
Backlight Life
50,000 hour(s)
Commercial Features
HTML5 support
3D MA deinterlacing, Smart Insert, Open Pluggable Specification slot, Certified for 16/7 Continuous Operation
Stands & Mounts
VESA Mounting Interface
100 x 100 mm, 100 x 200 mm, 400 x 400 mm
Video Features
Input Video Formats
Supported Computer Resolutions
1366 x 768, 1920 x 1200 (WUXGA), 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080, 1280 x 800
Media Player
Supported Video Formats
MPEG-4, WMV, MKV, VOB, TS, M2TS, M4V, MPG, MTS, MK3D, TTS
Supported Audio Formats
MP3, WMA, WAV, AAC, AIFF, LPCM, M4A, ASF, M3U
Supported Pictures Formats
BMP, JPG, GIF, JPEG
USB Port
USB Ports Qty
1
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Network & Internet Multimedia
LAN
Connector Type
2 x HDMI input , VGA input , DVI-D input , Component video input , Audio line-in , Composite video input , Audio line-in , Network , USB , Audio line-out , Serial , Remote control , Speakers output , DVI-D output
Batteries
UL, C-Tick, GOST, cUL, CB, FCC Part 15 B, RoHS
ENERGY STAR Certified
ENERGY STAR Version
7.0
Power supply
Nominal Voltage
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
Smart power
Limited warranty - 3 years
20 - 80%
Video Interface: Composite
Video Interface: HDMI
Brand: Philips
Price Range Ex VAT: 1000 - 1500
