Philips 55HFL2879T 55" Class Professional Studio LED TV for Hotel/Hospitality
Quicklinx: F33XWS00 Mfr#: 55HFL2879T/12
TV Tuner Presence: Yes
Video Interface: Composite, HDMI, SCART
  • DVB-T
Hurry, only 1 left in stock!
£581.32 ex VAT
£697.58 inc VAT
Show your guests how much you care with this affordable Professional TV. You will enjoy dedicated hospitality features like a branded welcome page, installation via USB and menu and control locking.
  • 4k Ultra HD Resolution
    See TV like never before thanks to four times the resolution of a conventional Full HD TV. 3840 x 2160 pixels provide an image so refined, so lifelike, it’s a window to a new world.
  • Welcome page
    A welcome page is displayed each time the TV set is switched on. The welcome page can be branded and customized easily at the time of installation via a simple welcome image in .png format.
  • USB cloning
    Provides the ability to easily copy all programming and channel programming settings from one TV into other TV sets in less than a minute. The feature ensures uniformity between TV sets and significantly reduces installation time and costs.
  • USB (photos, music, video)
    Share the fun. Connect your USB memorystick, digital camera, mp3 player or other multimedia device to the USB port on your TV to enjoy photos, videos and music with the easy to use onscreen content browser.
  • One combined channel list
    One integrated channel list for digital and analog channels. This allows the guest to zapp seemless between Analog and Digital channels.
  • Advanced volume control
    With advanced volume control you can install the start-up volume of the TV and predifine the volume range with which the TV set is allowed to operate, preventing excessive volume adjustments and avoiding disturbance of next door guests.
  • Local control locking
    By disabling or enabling the local control locking, the administrator can prevent unauthorized use of the TV via the control buttons, saving the hotelier overheads.
  • Installation menu locking
    Prevents unauthorized access to installation and configuration settings, to ensure maximum guest convenience and avoid unnecessary reinstalling costs.
  • Low power consumption
    Philips TVs are desgined to minimize power consumption. This will not only reduce environmental impact but also lower operating costs.
Philips 55HFL2879T Professional Studio - 55" LED TV - 4K
LED-backlit LCD TV
Diagonal Class
55"
Commercial Use
Yes - hotel / hospitality
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Video Interface
HDMI Ports Qty
2 ports
PC Interface
VGA (HD-15)
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
1x analogue, 1x digital
Digital TV Tuner
DVB-C, DVB-T, DVB-T2
Analogue TV Tuner
PAL, SECAM
Commercial Features
Screen welcome message, prison mode, Multi remote control
Settings Cloning Capability
Speaker System
2 speakers
Sound Effects
Incredible Surround
USB
Remote Control
Standard remote
Voltage
AC 230V (50/60 Hz)
Energy Class
Class A++
Power Consumption (On mode)
60 W
Power Consumption Stand by
0.3 Watt
Energy Consumption per Year
87 kWh
124.8 cm x 6.2 cm x 73 cm
13.8 kg
LED-backlit LCD TV
Energy Class
Class A++
60 W
87 kWh
Diagonal Class
55"
Commercial Use
Series
Professional Studio
TV Tuner
TV Tuner Presence
Video Interface
HDMI Ports Qty
2 ports
PC Interface
VGA (HD-15)
Modes
Eco mode
Dimensions
Without stand
124.8 cm
6.2 cm
73 cm
13.8 kg
Enclosure Colour
Display
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
LED backlight
Image Contrast Ratio
4000:1
Brightness
350 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Commercial Features
One touch Play, security lock slot (cable lock sold separately), USB Cloning
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Flat Panel Mount Interface
400 x 200 mm
TV Tuner
Analogue TV Tuner
PAL, SECAM
Conditional Access
Common Interface Plus (CI+) slot
Digital TV Tuner
Digital TV Tuner
HDTV Tuner
Digital TV Service
MHEG
Video Features
Analogue Video Input Signals
PAL, SECAM
Teletext
Electronic Programme Guide
Digital EPG, Now & Next
Media Player
Supported Video Formats
MPEG-1, MPEG-2, MPEG-4, AVI, MKV, TS, AVC, H.264, HEVC
Supported Audio Formats
MP3, WMA, WAV, AAC
Supported Pictures Formats
BMP, JPG, PNG
USB Port
USB Ports Qty
1
Remote Control
Standard remote
Remote Control Model
Philips 22AV1407A
Remote Control Pass Through
Audio System
Surround Mode
Sound Effects
Incredible Surround
Equaliser
Speaker System
2 speakers
Output Power / Total
16 Watt
Balance control, Down-firing Speaker, Auto Volume Leveller (AVL), Dynamic Bass Sound
Speakers
2 x speaker - built-in - 8 Watt
Network & Internet Multimedia
Supported Consumer Electronics Control (CEC)
EasyLink
Connector Type
Composite video/audio input - side , USB 2.0 - side , 2 x HDMI - rear , SCART (RGB / Composite) - rear , VGA input - rear , Digital audio output (optical) - rear , Headphones - side
2 AAA batteries
Power supply
Nominal Voltage
AC 230V (50/60 Hz)
0.3 Watt
On/off timer, system standby
Dimensions & Weight Details
Panel without stand - 124.8 cm x 6.2 cm x 73 cm x 13.8 kg , Panel with stand - 124.8 cm x 22 cm x 76.7 cm x 14.7 kg
5 °C
45 °C
Video Interface: HDMI
Video Interface: SCART
Brand: Philips
Price Range Ex VAT: 500 - 750
