Philips 55BDL4050D 55" 1920x1080 12ms VGA DVI HDMI DiplayPort LED Large Format Display
Quicklinx: FFBGWS00 Mfr#: 55BDL4050D/00
TV Tuner Presence: No
Video Interface: HDMI
  • 1080p (Full HD)
  • USB
Hurry, only 1 left in stock!
£882.35 ex VAT
£1,058.82 inc VAT
Amaze your guests with a smarter, faster, signage display. With integrated Wi-Fi and designed for running Android apps, it's the next evolution in signage solutions.
  • PCI Slot
    With an integrated PCI slot, you can connect an extra Wi-Fi/Bluetooth or 4G LTE module, allowing for even greater communication with the display. Machine to machine communication is also enhanced, with numerous configurations available for customers to use, such as the ability to expand product features or signal-handling capability.
  • Internal memory
    Save and play content with internal memory. Upload your media into the display and playback content immediately. Working in conjunction with the internal browser, it also serves as a memory cache when streaming online content. If the network ever fails, the internal memory keeps content running by playing a cached version of the content, ensuring that your media stays up even if the network goes down.
  • Proof of Play
    Content is king, and with the automatic screenshot feature, you can make sure that your content is up and running at all times. Screenshots are taken throughout the day, which are then stored in the FTP server. From there, the screenshots can be viewed no matter when, or where you are.
  • FailOver
    Keeping your content up and running is critical for demanding commercial applications. While it is unlikely you will face a content disaster, FailOver provides content protection with a revolutionary technology that plays back-up content on screen in the event of a media player failure. FailOver automatically kicks in when the primary input fails. Simply select a primary input connection and a FailOver connection and your ready for instant protection.
  • SmartPower
    The backlight intensity can be controlled and pre-set by the system to reduce the power consumption, which saves substantially on energy costs.
  • CMND
    A robust display management platform, CMND puts the power back into your hands. Update and manage content with CMND & Create or control your settings with CMND & Control. It's all possible with CMND.
  • CMND & Control
    With CMND & Control, easily manage multiple displays in a central location. With real time display monitoring, setting and software updates from a remote location, and the ability to customize and configure multiple displays at once, such as video wall or menu board displays, controlling your suite of displays has never been easier.
  • CMND & Create
    Design and create compelling content with CMND & Create, a powerful authoring tool. With a drag and drop interface, preloaded templates, and integrated widgets, you'll be able to amaze your customers with compelling content. Available in portrait and landscape mode.
  • SmartBrowser
    Connect and control your content via the cloud with the integrated HTML5 browser. Using the Chromium based browser, design your content online and connect a single display, or your complete network. Show content in both landscape and portrait mode, with Full HD resolution. Streaming content can also be shown in a PIP (picture-in-picture) window. Simply connect the display to the Internet using Wi-Fi or with an RJ-45 cable, and enjoy your own created playlists.
Philips Signage Solutions D-Line 55BDL4050D 55" Class (55.5" viewable) LED display - Full HD
LED-backlit LCD flat panel display
Diagonal Class
55"
Diagonal Size
55.5"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Input Video Formats
1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
Max Number Of Screens
100
Video Interface
HDMI
HDMI Ports Qty
2 ports
LAN
PC Interface
DVI, DisplayPort, USB
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
Clinical D-image
Picture Enhancements
Dynamic contrast enhancement, Pixel Shift, Low Bright
Speaker System
2 speakers
Storage Drive Capacity
16 GB
Storage Capacity
16 GB
Supported Memory Cards
microSD
USB
Remote control, batteries, carrying handle
Voltage
Energy Class
Class A+
Power Consumption (On mode)
77 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
112 kWh
123.2 cm x 4.57 cm x 71.1 cm
3-year warranty
Energy Class
Class A+
77 W
112 kWh
Diagonal Class
55"
Diagonal Size
55.5"
Commercial Use
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
Modes
Portrait mode, landscape mode
100
Dimensions
Without stand
123.2 cm
4.57 cm
71.1 cm
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Image Contrast Ratio
1100:1
Dynamic Contrast Ratio
500000:1
Brightness
450 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pull-Down Compensation
3:2, 2:2
Response Time
12 ms
Display Menu Language
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Polish, Russian, Spanish, Turkish, Arabic, Japanese
Backlight Life
50000 hour(s)
Commercial Features
Clinical D-image
3D MA deinterlacing, Motion Compensation
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
400 x 400 mm
Video Features
Input Video Formats
Supported Computer Resolutions
1366 x 768, 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1360 x 768, 1920 x 1080, 1440 x 900, 1280 x 800
Media Player
Supported Video Formats
MPEG-4, WMV, MKV, VOB, TS, M2TS, M4V, MPG, MPEG, MTS, MK3D, TTS
Supported Audio Formats
MP3, WMA, WAV, AAC, AIFF, LPCM, M4A, AIF, ASF, M3U, MP4
Supported Pictures Formats
BMP, JPG, GIF, JPEG
microSD
USB Port
Configuration
16 GB
16 GB
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - 10 Watt
Network & Internet Multimedia
LAN
Connector Type
DisplayPort input , 2 x HDMI input , DVI-D input , USB , DisplayPort output , DVI-I output , Audio line-in , Audio line-in , Audio line-out , Speakers output , Network , Serial input , Remote control input , USB , USB , Serial output , Remote control output
Batteries, carrying handle
FCC Class B certified, UL, VCCI, C-Tick, BSMI, GOST, cUL, CB, CCC, RoHS, PSE Mark, J-MOSS, CEC
Power supply
Nominal Voltage
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
Smart power
Limited warranty - 3 years
20 - 80%
Brand: Philips
Price Range Ex VAT: 750 - 1000
