Philips 55BDL3102H 55" 1920x1080 6ms VGA DVI HDMI DisplayPort LED Large Format Display
Quicklinx: FFBFWS00 Mfr#: 55BDL3102H/00
TV Tuner Presence: No
Video Interface: Component, Composite, HDMI
  • 1080p (Full HD)
10 in stock
£2,004.27 ex VAT
£2,405.12 inc VAT
Turn your display into an all-in-one digital signage solution and create a display network which is connected, intelligent and secure. A cable-free solution gives you the ability to install, use or maintain your hardware whenever you need.
  • Save and play content with internal memory
    Save and play content with internal memory. Upload your media into the display and playback content immediately. Working in conjunction with the internal browser, it also serves as a memory cache when streaming online content. If the network ever fails, the internal memory keeps content running by playing a cached version of the content, ensuring that your media stays up even if the network goes down.
  • Designed for 24/7 operation for high accuracy
    Because business never sleeps, the signage displays are designed for 24/7 use for high accuracy and critical environments. Taking advantage of superior components to ensure a higher level of quality, you can count on this range of models for complete around-the-clock reliability.
  • High ambient light applications
    Enjoy an excellent visual experience even in areas illuminated by direct sunlight. The high brightness offers a wide array of implementation possibilities especially in locations that have high ambient light levels, delivering crystal-clear images for all locations where ambient brightness is an issue.
Philips Signage Solutions H-Line 55BDL3102H 55" LED display
LED-backlit LCD flat panel display
Diagonal Class
55"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Frame Rate & Enhancement Technology
60 Hz Refresh Rate
Video Interface
Component, composite, HDMI
HDMI Ports Qty
2 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
S-VA
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Picture Enhancements
Motion Compensation, dynamic contrast enhancement, Pixel Shift
Speaker System
2 speakers
USB
Remote Control
Standard remote
Voltage
368 Watt
Power Consumption Stand by
0.5 Watt
124.22 cm x 13.79 cm x 71.3 cm
35.8 kg
3-year warranty
368 Watt
Diagonal Class
55"
Commercial Use
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI Ports Qty
2 ports
PC Interface
Modes
Landscape mode
124.22 cm
13.79 cm
71.3 cm
35.8 kg
Display
LCD Display Technology
S-VA
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
60 Hz Refresh Rate
LED backlight
Image Contrast Ratio
5000:1
Dynamic Contrast Ratio
500000:1
Brightness
2500 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pull-Down Compensation
3:2, 2:2
Response Time
6 ms
Display Menu Language
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Polish, Russian, Spanish, Turkish, Arabic, Japanese
Backlight Life
50,000 hour(s)
3D MA deinterlacing, Smart Insert, Intel OPS compatible, picture in picture (no tuner)
Stands & Mounts
Stand
Optional
Stand Design
Tabletop
VESA Mounting Interface
400 x 400 mm
Media Player
Supported Video Formats
MPEG-4, WMV, MKV, VOB, TS, M2TS, M4V, MPG, MPEG, MTS, MK3D, TTS
Supported Audio Formats
MP3, WMA, WAV, AAC, AIFF, LPCM, M4A, AIF, ASF, M3U, MP4
Supported Pictures Formats
BMP, JPG, GIF, JPEG
USB Port
USB Ports Qty
1
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x speaker - built-in - 10 Watt
Connector Type
2 x HDMI input , VGA input , DVI-D input , Component video input , DisplayPort input , Audio line-in , DisplayPort output , Audio line-in , Audio line-out , Composite video input , RS-232C , Network , Remote control , USB
Batteries, edge alignment plates
Serial cable
FCC Class A certified, UL, BSMI, cUL, CB, CCC, RoHS
Power supply
Nominal Voltage
0.5 Watt
Smart power
Limited warranty - 3 years
5 °C
20 - 80%
Video Interface: Composite
Video Interface: HDMI
Brand: Philips
Price Range Ex VAT: 1500+
