Philips 55BDL1007X 55" LED Video Wall Display
Quicklinx: FFBBWS00 Mfr#: 55BDL1007X/00
TV Tuner Presence: No
Video Interface: HDMI, Composite, Component
  • 1080p
£2,667.49 ex VAT
£3,200.98 inc VAT
Impress your audience with the most impactful video wall. With 1.8 mm ultra narrow bezel and stunning picture quality, you are sure to create the most memorable visual experience.
  • Full HD LED technology
    White LED's are solid state devices which light up to full, consistent brightness faster saving startup time. LED's are free from mercury content which allows for eco-friendly recycling and disposal process. LED's allow for better dimming control of LCD backlight, resulting in super high contrast ratio. It also gives superior color reproduction thanks to consistent brightness across the screen.
  • IPS Display Technology
    Philips IPS displays uses an advanced technology which gives you extra wide viewing angles of 178/178 degree, making it possible to view the display from almost any angle - even in portrait mode. IPS displays gives you remarkably crisp images with vivid colors, especially suitable for professional video wall and menu board applications which demand color accuracy and consistent brightness at all times.
  • High brightness
    Enjoy a clearer image in areas with greater ambient brightness thanks to the 700 nit panel. Your audience can enjoy better image quality in locations that are away from direct sunlight yet still brighter than average, optimizing the viewing experience.
  • Ultra Narrow Bezel
    The next generation of video wall displays is designed with industry narrowest bezels and advanced alignment solutions. Fully exploit your impactful signage content with ultra narrow bezel displays, and make sure your message does not get lost by thick bezels. With the ultra narrow bezels you can create seamless video wall configurations of virtually any size.
  • Advanced Color Calibration
    The Advanced Color Calibration kit controls the luminance of the backlight, standardizes the gamma curve and calibrates the grayscale of your display network. Whether you have an impressive video wall, a catchy mosaic layout, a menu board installation or a control room each display can be adjusted to the same color values. With this optional kit you ensure consistent color performance over all displays in your network.
  • FailOver
    Keeping your content up and running is critical for demanding commercial applications. While it is unlikely you will face a content disaster, FailOver provides content protection with a revolutionary technology that plays back-up content on screen in the event of a media player failure. FailOver automatically kicks in when the primary input fails. Simply select a primary input connection and a FailOver connection and your ready for instant protection.
  • SmartPower
    The backlight intensity can be controlled and pre-set by the system to reduce the power consumption by up to 50%, which saves substantially on energy costs.
  • OPS Insert
    Turn your display into an all-in-one digital signage solution and create a display network which is connected, intelligent and secure. Open Pluggable Specification (OPS) is an industry standard slot into which you can add an OPS standardized media player. This cable free solution gives you the ability to install, use or maintain your hardware whenever you need.
  • Designed for 24/7 operation
    Because business never sleeps, signage displays are designed for 24/7 use. Taking advantage of superior components to ensure a higher level of quality, you can count on this range of models for complete around-the-clock reliability.
  • CMND & Control
    With CMND & Control, easily manage multiple displays in a central location. With real time display monitoring, setting and software updates from a remote location, and the ability to customize and configure multiple displays at once, such as video wall or menu board displays, controlling your suite of displays has never been easier.
Philips Signage Solutions 55BDL1007X X-Line - 55" Class (54.6" viewable) LED-backlit LCD display - Full HD - for digital signage
LED-backlit LCD flat panel display
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/337836
Diagonal Class
55"
Diagonal Size
54.6"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p
Input Video Formats
1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i, 2160/30p
Max Number of Screens
100
Video Interface
Component, composite, HDMI
HDMI Ports Qty
2 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
IPS
LCD Backlight Technology
Direct-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Picture Enhancements
Motion Compensation, dynamic contrast enhancement, Pixel Shift, Advanced Colour Calibration
Speaker System
2 speakers
Batteries, carrying handle, edge alignment pins, edge alignment plates
Energy Class
Class G
168 Watt
Power Consumption (On mode)
135 W
Power Consumption Stand by
0.65 Watt
Energy Consumption per Year
191 kWh
121.14 cm x 9.85 cm x 68.22 cm
24.35 kg
3-year warranty
Energy Class
Class G
168 Watt
135 W
135 kWh/1000h
191 kWh
Diagonal Class
55"
Diagonal Size
54.6"
Commercial Use
Series
X-Line
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Ambient light sensor (ALS)
Video Interface
HDMI Ports Qty
2 ports
PC Interface
Design
Ultra Narrow Bezel Concept
Dimensions
Without stand
121.14 cm
9.85 cm
68.22 cm
24.35 kg
Display
LCD Display Technology
IPS
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
Direct-lit LED
Image Contrast Ratio
1200:1
Dynamic Contrast Ratio
500000:1
Brightness
700 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pull-Down Compensation
3:2, 2:2
Response Time
8 ms
Display Menu Language
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Polish, Russian, Spanish, Turkish, Arabic, Japanese
Backlight Life
50,000 hour(s)
Operation Hours / Days
24 / 7
3D MA deinterlacing, Smart Insert, Intel OPS compatible
Video Wall
100
Stands & Mounts
Flat Panel Mount Interface
400 x 400 mm
Video Features
Input Video Formats
Supported Computer Resolutions
1366 x 768, 1920 x 1200 (WUXGA), 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080, 1440 x 900, 1280 x 800
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x speaker - 10 Watt
Connector Type
Component video input , Composite video input , 2 x HDMI , VGA input , DisplayPort input , DisplayPort output , DVI-I output , Audio line-in , Audio line-in , Audio line-out , Speakers output , Infrared (IrDA) , Remote control , Remote control
Serial cable
FCC Class B certified, UL, GOST, cUL, CB
0.65 Watt
Power Consumption (Off Mode)
0.65 Watt
Energy save, smart power
Limited warranty - 3 years
20 - 80%
Video Interface: Composite
Video Interface: Component
Brand: Philips
Price Range Ex VAT: £1500+
