Philips 55" 1920x1080 5ms VGA DVI HDMI USB LED LFD
Quicklinx: BNH1WS00 Mfr#: BDL5530QL/00
  • 1080p (Full HD)
Deliver startlingly clear images in a more eco-friendly way. High on performance and reliability, yet low on power consumption, it is ideal for projects where no compromise is accepted.
  • SmartPower for energy saving
    The backlight intensity can be controlled and pre-set by the system to reduce the power consumption by up to 50%, which saves substantially on energy costs.
  • Connect and control your content via the cloud with HTML5
    Connect and control your content via the cloud with the integrated HTML5 browser. Design your signage content online and connect it with a display or with your entire network. Simply plug in a RJ45 Internet cable for network connection and connect the display with the dedicated URL address, and you are ready to play your cloud-based content.
  • Schedule what you want, when you want with SmartPlayer
    Turn your USB into a true cost-effective digital signage device. Simply save your content (video, audio, pictures) on your USB and plug into your display. Create your playlist and schedule your content via the on-screen menu, and enjoy your own playlists anytime, anywhere.
  • Free and easy-to-use content management with SmartCMS
    Free and easy-to-use content management system that works exclusively with Philips Signage Solutions displays to manage your digital signage content. With SmartCMS you can create and schedule your own content over 24 hours every day. Simply create your network, design your content and schedule your playlist, and you are ready to play!
  • Manage and control your network remotely via SmartControl
    SmartControl lets you remotely control and manage your network of displays via RJ45 and RS232C. Easily fine-tune all display settings including resolution, brightness, contrast and cloning of your settings over your complete network.
  • Full HD LED for brilliant images with incredible contrast
    Picture Quality matters. Standard displays deliver quality, but you expect more. Imagine crisp detail paired with high brightness, incredible contrast and realistic colours for a true-to-life picture.
  • Show clinical images consistently with D-image
    D-image helps you to review and diagnose clinical images with consistent and accurate display performance. To achieve reliable clinical interpretations, our professional displays are factory calibrated to give optimised greyscale standard display performance. D-image helps you to excel in every aspect of patient care.
  • Save and play content with internal memory
    Save and play content with internal memory. Upload your media into the display and playback content immediately. Working in conjunction with the internal browser, it also serves as a memory cache when streaming online content. If the network ever fails, the internal memory keeps content running by playing a cached version of the content, ensuring that your media stays up even if the network goes down.
Philips Signage Solutions Q-Line BDL5530QL Q-Line - 55" Class (54.6" viewable) LED display
LED-backlit LCD flat panel display
Diagonal Class
55"
Diagonal Size
54.6"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Input Video Formats
1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
Video Wall Components Qty
225
Video Interface
Component, composite, HDMI
HDMI Ports Qty
1 ports
LAN
PC Interface
DVI, VGA (HD-15)
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
HTML5 support, Clinical D-image
Picture Enhancements
Pixel Shift
Speaker System
2 speakers
DVR
Flash - 8 GB
Storage Drive Capacity
8 GB
USB
Remote Control
Standard remote
Voltage
AC 120/230 V
141 Watt
Power Consumption Stand by
0.5 Watt
123.86 cm x 5.99 cm x 71.11 cm
16 kg
Environmental Standards
ENERGY STAR Qualified
3-year warranty
141 Watt
Diagonal Class
55"
Diagonal Size
54.6"
Commercial Use
Series
Q-Line
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
Pixel Shift
225
Dimensions
Without stand
123.86 cm
5.99 cm
71.11 cm
16 kg
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Colour Depth
16.7 million colours
Image Contrast Ratio
1200:1
Dynamic Contrast Ratio
500000:1
Brightness
350 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.63 x 0.63mm
Response Time
6.5 ms
Display Menu Language
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Polish, Russian, Spanish, Turkish
Backlight Life
50,000 hour(s)
Commercial Features
Smart Control, SmartCMS, One Wire, Smart Collection
Stands & Mounts
VESA Mounting Interface
400 x 200 mm, 400 x 400 mm
DVR
DVR
Flash - 8 GB
Video Features
Input Video Formats
Supported Computer Resolutions
1366 x 768, 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1360 x 768, 1920 x 1080, 1440 x 900, 1280 x 800
Media Player
Supported Video Formats
MPEG-4, Xvid, DivX, WMV, ASF, QuickTime, AVI, MKV, MOV, VOB, FLV, TS, M2TS, F4V, DAT, M4V, TRP, WebM, MPG, MPEG, MTS
Supported Audio Formats
MP3, WMA, WAV, AC3, AAC, Ogg Vorbis, AIFF, AMR, M4A
Supported Pictures Formats
BMP, JPG, GIF
USB Port
USB Ports Qty
1
8 GB
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Network & Internet Multimedia
LAN
Connector Type
HDMI , VGA input , DVI-D input , Component video input , Audio line-in , Composite video input , Audio line-in , Network , Serial output , USB , Audio line-out , Serial input , Remote control input , Remote control output
Batteries
Serial cable , VGA cable
UL, C-Tick, BSMI, GOST, cUL, CCC, CECP, EPA
ENERGY STAR Certified
ENERGY STAR Version
6.0
Power supply
Nominal Voltage
AC 120/230 V
0.5 Watt
Smart power
Limited warranty - 3 years
5 °C
20 - 80%
BNH1 C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
BNH1 C2G 0.5m Select High Speed HDMI with Ethernet In Stock £6.35
BNH1 C2G 5m Select High Speed HDMI with Ethernet In Stock £21.22
BNH1 C2G 10m Select High Speed HDMI with Ethernet In Stock £40.74
BNH1 C2G 15m Select High Speed HDMI with Ethernet In Stock £55.17
BNH1 C2G HDMI to VGA Adapter Converter Dongle - Video converter - Black In Stock £14.57
