Philips 50HFL6014U 50" Professional MediaSuite LED Commercial TV
Quicklinx: FFB8WS00 Mfr#: 50HFL6014U/12
  • DVB-T
Android-powered Philips Professional TVs are fast, versatile and easy to navigate. The TVs are optimized for native Android apps and you can install web apps directly to the display, too. Automatic updates ensure apps stay up to date.
Enable hassle-free wireless casting of movies, presentations and more from smart devices (mobiles, laptops, tablets) to your Android-powered Philips Professional TV. Chromecast is cost-effective, requires no extra hardware and is secure for professional use. Users simply tap the Chromecast icon on their smart device to start streaming content from thousands of cast-enabled apps - their smart device becomes the remote.
From hotel chain to sports bar, monitor how your Android-powered Philips Professional TV is used. Find out how often specific channels are watched. Test the effectiveness of your advertising. Get the information you need to manage costs effectively, with easy access to screen-time data.
  • Android updates, always the latest functionality
  • Chromecast built in, cast content to the big screen
  • Analytics on board, get stats on what's being watched
  • CMND and control, operate, update, maintain
    Run your display network over a local (LAN or RF) connection. CMND & Control allows you to perform vital functions like controlling inputs, updating software and monitoring display status - whether you're in charge of one TV or more.
Philips 50HFL6014U Professional MediaSuite - 50" LED-backlit LCD TV - 4K - for hotel / hospitality
LED-backlit LCD TV - Smart TV
Diagonal Class
50"
Commercial Use
Yes - hotel / hospitality
Silver
Platform
Android
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Input Video Formats
1080/60p, 2160/30p, 2160/60p
Video Interface
HDMI
HDMI Ports Qty
3 ports
Wi-Fi, LAN
PC Interface
VGA (HD-15), Mobile High-Definition Link (MHL)
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
Digital TV Tuner
DVB-C, DVB-T, DVB-T2
Analogue TV Tuner
PAL
Internet Streaming Services
HbbTV
Commercial Features
VSecure, mychoice, Serial Xpress Protocol, Double isolation Class II, CMND management, SecureMedia
Settings Cloning Capability
Speaker System
2 speakers
Sound Effects
DTS Studio Sound
Storage Drive Capacity
16 GB
Storage Capacity
16 GB
USB
3 ports
Philips 22AV1905A remote control
Voltage
AC 230V (50/60 Hz)
Energy Class
Class G
Power Consumption (On mode)
67 W
Power Consumption Stand by
0.3 Watt
Energy Consumption per Year
103 kWh
112.8 cm x 7.8 cm x 65.3 cm
12.8 kg
Energy Class
Class G
67 W
67 kWh/1000h
103 kWh
Diagonal Class
50"
Commercial Use
Series
Platform
Android
Operating System
Android OS
TV Tuner Presence
Video Interface
HDMI
HDMI Ports Qty
3 ports
PC Interface
Modes
Eco mode, hotel mode
Design
Flame retardant cabinet
Dimensions
Without stand
112.8 cm
7.8 cm
65.3 cm
12.8 kg
Enclosure Colour
Silver
Display
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
LED backlight
Brightness
350 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Commercial Features
One touch Play, Chromecast Ultra built-in
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Stand Features
Swivel
Flat Panel Mount Interface
200 x 200 mm
VESA Compatibility
TV Tuner
Analogue TV Tuner
PAL
Conditional Access
Common Interface Plus (CI+) slot
Digital TV Tuner
Digital TV Tuner
HDTV Tuner
Digital TV Service
MHEG
Video Features
Input Video Formats
Supported Computer Resolutions
1920 x 1080, 3840 x 2160
Teletext
Electronic Programme Guide
Digital EPG, Now & Next
Media Player
Supported Video Formats
MPEG-1, MPEG-2, MPEG-4, WMV, AVI, MKV, AVC, H.264, VC-1, HEVC, VP9
Supported Audio Formats
MP3, WMA, WAV, AAC, WMA Pro
Supported Pictures Formats
BMP, JPG, GIF, PNG
USB Port
USB Ports Qty
3
Configuration
16 GB
16 GB
Remote Control
Remote control
Remote Control Model
Philips 22AV1905A
Battery Form Factor
AAA type
Battery Included Qty
2
Audio System
Digital Audio Format
Dolby Digital output, DTS-HD digital output, Dolby Atmos, Dolby AC-4 output
Surround Mode
Sound Effects
DTS Studio Sound
Speaker System
2 speakers
Output Power / Total
20 Watt
Down-firing Speaker, Audio Return Channel (ARC)
Speakers
2 x speaker - 10 Watt
Network & Internet Multimedia
Functionality
Internet video playback
Wi-Fi, LAN
LAN Protocol
Ethernet
Wi-Fi Protocol
802.11ac
Connect & Share
Wi-Fi Direct, Secure Sharing
HbbTV
Supported Consumer Electronics Control (CEC)
EasyLink
Application Store
Google Play
Connector Type
Speakers output - rear , Remote control - rear , Digital audio output (optical) - bottom , LAN - bottom , VGA input - bottom , Audio line-in - bottom , USB 2.0 - bottom , HDMI - bottom , USB 2.0 - side , USB 3.0 - side , Headphones - side , 2 x HDMI - side
HDCP 2.2
Power supply
Input Voltage
AC 230V (50/60 Hz)
0.3 Watt
WOL (Wake on LAN)
Dimensions & Weight Details
Panel without stand - 112.8 cm x 7.8 cm x 65.3 cm x 12.8 kg , Panel with stand - 112.8 cm x 22.5 cm x 71.5 cm x 13.6 kg
