Powered by CMND
Show more with a budget-friendly standalone professional TV. The intuitive CMND solution makes it simple to deploy and manage connected displays. Benefit from simple, fast installation and an on-screen welcome page that's easy to program.
CMND&Control
CMND and Control allows for remote configuration and installation of your TVs from a central location, without the need to visit any rooms. Update and manage all your displays, with minimal effort, all without having to disturb your guests.
Built-in pay-to-view solution
Offer pay-to-view content in any situationfrom a complete pay-to-access-all-channels model to selected premium content. MyChoice is an integrated solution that allows viewers to access pay-per-view channels via a code or a card.
UI branding
Your Philips Professional TV offers a clear, easy-to-navigate user interface (UI), which you can customize with your own branding. Easily add your logo or custom background to the menu to increase the visibility of your brand.
Instant initial USB cloning.
Provides the ability to easily copy all programming and channel programming settings from one TV into other TV sets in less than a minute. The feature ensures uniformity between TV sets and significantly reduces installation time and costs.
Mixed channel map
One integrated channel list for digital and analogue channels. This allows the guest to flick seamlessly between Analogue and Digital channels.
USB auto playback.
Share the fun. Connect your USB memorystick, digital camera, mp3 player or other multimedia device to the USB port on your TV to enjoy photos, videos and music with the easy to use onscreen content browser.
- CMND and Control: effortless maintenance of your TVs
- MyChoice compatible. Built-in pay-to-view solution
- Be seen. Brand the TV's UI with your logo
- Instant initial USB cloning. Rapidly configure Pro TVs
- Mixed channel map to combine analogue and digital channels
- USB auto playback. Music, movies, and more
- Multilingual customer support
- Low power consumption
CMND&Control
CMND and Control allows for remote configuration and installation of your TVs from a central location, without the need to visit any rooms. Update and manage all your displays, with minimal effort, all without having to disturb your guests. -
Offer pay-to-view content in any situation from a complete pay-to-access-all-channels model to selected premium content. MyChoice is an integrated solution that allows viewers to access pay-per-view channels via a code or a card. -
UI branding
Your Philips Professional TV offers a clear, easy-to-navigate user interface (UI), which you can customize with your own branding. Easily add your logo or custom background to the menu to increase the visibility of your brand. -
Provides the ability to easily copy all programming and channel programming settings from one TV into other TV sets in less than a minute. The feature ensures uniformity between TV sets and significantly reduces installation time and costs. -
Mixed channel map
One integrated channel list for digital and analog channels. This allows the guest to flick seamlessly between Analog and Digital channels. -
USB auto playback
Share the fun. Connect your USB memory stick, digital camera, mp3 player or other multimedia device to the USB port on your TV to enjoy photos, videos and music with the easy to use onscreen content browser.
- Philips 50HFL3014 50" LED TV - Full HD
- Product Type
- LED-backlit LCD TV
- Diagonal Class
- 50"
- Commercial Use
- Yes - healthcare / hospital
- Black
- Resolution
- 1920 x 1080
- Display Format
- 1080p (Full HD)
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- LCD Backlight Technology
- LED backlight - D-LED Backlight
- Image Aspect Ratio
- 16:9
- Digital TV Tuner
- DVB-C, DVB-T, DVB-T2
- Analogue TV Tuner
- PAL, SECAM
- Commercial Features
- Screen welcome message, prison mode, mychoice, Double isolation Class II, Multi remote control, CMND management
- Settings Cloning Capability
- Speaker System
- 2 speakers
- Sound Effects
- Incredible Surround
- USB
- Included Accessories
- Philips 22AV1903A/12 remote control
- Voltage
- AC 230V (50/60 Hz)
- Energy Class
- Class A++
- Power Consumption (On mode)
- 47 W
- Power Consumption Stand by
- 0.3 Watt
- Energy Consumption per Year
- 69 kWh
- Dimensions (WxDxH) - without stand
- 112.8 cm x 8.1 cm x 65.5 cm
- 11.3 kg
- Product Type
- Energy Class
- Class A++
- 47 W
- 69 kWh
- Diagonal Class
- 50"
- Commercial Use
- TV Tuner Presence
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- Modes
- Eco mode, hotel mode
- Design
- Flame retardant cabinet
- Dimensions
- Without stand
- 112.8 cm
- 8.1 cm
- 65.5 cm
- 11.3 kg
- Enclosure Colour
- Black
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p (Full HD)
- 16:9
- LED backlight
- Brightness
- 250 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- One touch Play, security lock slot (cable lock sold separately)
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Flat Panel Mount Interface
- 200 x 200 mm
- VESA Compatibility
TV Tuner
- Analogue TV Tuner
- PAL, SECAM
- Conditional Access
- Common Interface Plus (CI+) slot
Digital TV Tuner
- Digital TV Tuner
- HDTV Tuner
- Digital TV Service
- MHEG
- MPEG Profiles and Levels
- HEVC
Video Features
- Analogue Video Input Signals
- NTSC, PAL, SECAM
- Teletext
- Electronic Programme Guide
- Digital EPG, Now & Next
Media Player
- Supported Video Formats
- MPEG-1, MPEG-2, MPEG-4, WMV, AVI, MKV, TS, AVC, H.264, VC-1, HEVC, MPG
- Supported Audio Formats
- MP3, WMA, WAV, AAC
- Supported Pictures Formats
- BMP, JPG, GIF, PNG
- USB Port
- USB Ports Qty
- 1
Remote Control
- Remote control
- Remote Control Model
- Battery Form Factor
- AAA type
- Battery Included Qty
- 2
- Battery anti-theft protection
Audio System
- Digital Audio Format
- Dolby Digital output
- Surround Mode
- Sound Effects
- Speaker System
- 2 speakers
- Output Power / Total
- 16 Watt
- Down-firing Speaker, Auto Volume Leveller (AVL), Audio Return Channel (ARC), Dynamic Bass Enhancement
- Speakers
- 2 x speaker - 8 Watt
- Connector Type
- 2 x HDMI - rear , Digital audio output (optical) - rear , Audio line-in - rear , Headphones - side , USB 2.0 - side
- Security Slot Type
- Kensington security slot
- Power Device
- Power supply
- Nominal Voltage
- 0.3 Watt
- Auto On/Off
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 112.8 cm x 8.1 cm x 65.5 cm x 11.3 kg , Panel with stand - 112.8 cm x 21.45 cm x 67.9 cm x 11.6 kg
- 0 °C
- 40 °C
