Philips 43BDL4051T 43" 1920x1080 12ms VGA DVI HDMI DisplayPort IPS LED Large Format Display
Quicklinx: FF9MWS00 Mfr#: 43BDL4051T/00
  • 1080p
Get even closer to your audience than ever before. Fast, precise and extremely durable, its high performance is matched by excellent reliability and functionality.
  • Plug-and-Play multi-touch
    More flexibility and optimum simultaneous touch performance coupled with excellent operability opportunities to give you the ultimate in user interaction. The multi-touch displays are enabled with automatic touch recognition. The USB connector is HID compliant, providing true Plug-and-Play operation.
  • Anti-glare glass
    With this integrated touch display, the anti-glare glass with low optical parallax allows for immersive touch experience. With little to no glare and low reflection on the display, images are crystal clear with pure color and great clarity.
  • FailOver
    Keeping your content up and running is critical for demanding commercial applications. While it is unlikely you will face a content disaster, FailOver provides content protection with a revolutionary technology that plays back-up content on screen in the event of a media player failure. FailOver automatically kicks in when the primary input fails. Simply select a primary input connection and a FailOver connection and you're ready for instant protection.
  • Internal memory
    Save and play content with internal memory. Upload your media into the display and playback content immediately. Working in conjunction with the internal browser, it also serves as a memory cache when streaming online content. If the network ever fails, the internal memory keeps content running by playing a cached version of the content, ensuring that your media stays up even if the network goes down.
  • PCI slot
    With an integrated PCI slot, you can connect an extra Wi-Fi/Bluetooth or 4G LTE module, allowing for even greater communication with the display.
Philips Signage Solutions 43BDL4051T 43" Class (42.5" viewable) LED-backlit LCD display - Full HD - for digital signage
LED-backlit LCD flat panel display with touchscreen
Diagonal Class
43"
Diagonal Size
42.5"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p
Input Video Formats
1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
Video Interface
HDMI
HDMI Ports Qty
2 ports
Wi-Fi
PC Interface
DVI, DisplayPort
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
CMND management
Picture Enhancements
Dynamic contrast enhancement, Pixel Shift
Speaker System
2 speakers
Storage Drive Capacity
16 GB
Storage Capacity
16 GB
Supported Memory Cards
microSD
USB
Remote control, batteries
Voltage
Energy Class
Class G
59 Watt
Power Consumption (On mode)
57 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
82 kWh
100.26 cm x 9.14 cm x 59.08 cm
19.4 kg
Environmental Standards
ENERGY STAR Qualified
3-year warranty
Energy Class
Class G
59 Watt
57 W
57 kWh/1000h
82 kWh
Diagonal Class
43"
Diagonal Size
42.5"
Commercial Use
Combined With
Touchscreen
Operating System
Android OS
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
DVI, DisplayPort
Modes
Portrait mode, landscape mode
Protection
Tempered glass protection
Dimensions
Without stand
100.26 cm
9.14 cm
59.08 cm
19.4 kg
Display
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
LED backlight
Coating
Anti-glare
Image Contrast Ratio
1100:1
Dynamic Contrast Ratio
500000:1
Brightness
450 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pull-Down Compensation
3:2, 2:2
Touchpoints Qty
10
Response Time
12 ms
Display Menu Language
Danish, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese
Backlight Life
50,000 hour(s)
Commercial Features
CMND management
Certified for 24/7 Continuous Operation, 3D MA deinterlacing, infrared multitouch technology, Motion Compensation, One Wire
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
400 x 400 mm
Video Features
Input Video Formats
Supported Computer Resolutions
1366 x 768, 1920 x 1200 (WUXGA), 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080, 1440 x 900, 1280 x 800
Media Player
Supported Video Formats
MPEG-4, WMV, MKV, VOB, TS, M2TS, M4V, MPG, MPEG, MTS, MK3D, TTS
Supported Audio Formats
MP3, WMA, WAV, AAC, AIFF, LPCM, M4A, AIF, ASF, M3U, MP4
Supported Pictures Formats
BMP, JPG, GIF, JPEG
microSD
USB Port
Configuration
ARM Cortex-A9 Quad-Core ( 1.8 GHz ) - 2 GB DDR3 - 16 GB - Mali 400
16 GB
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - 10 Watt
Network & Internet Multimedia
Wi-Fi
Connector Type
DisplayPort input , 2 x HDMI input , DVI-D input , USB , DisplayPort output , DVI-I output , Audio line-in , Audio line-in , Audio line-out , Speakers output , Remote control , Infrared (IrDA) , Serial , USB
Batteries
Serial cable , USB cable
FCC Class B certified, UL, VCCI, C-Tick, BSMI, GOST, cUL, CB, CCC, RoHS, PSE Mark
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
7.0
Power supply
Input Voltage
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
Smart power
Limited warranty - 3 years
20 - 80%
