Philips 32HFL5014 32" Professional MediaSuite LED Commercial TV
Quicklinx: FF9FWS00 Mfr#: 32HFL5014/12
Video Interface: HDMI
TV Tuner Presence: Yes
  • 1080p (Full HD)
  • DVB-T
£453.66 ex VAT
£544.39 inc VAT
With this powerful TV, vibrant picture quality is only the beginning. Easy content management gives you the edge when it comes to engaging guests.
  • Low power consumption
    Philips TVs are designed to minimize power consumption. This will not only reduce environmental impact but also lower operating costs.
  • Personalize every experience
    Make visitors feel welcome. CMND & check-in lets you use individual information-such as name and language spoken-to create a personalized experience. Whether you're adding special touches for hotel guests, streamlining the billing process, or offering multiple channel packages.
Philips 32HFL5014 Professional MediaSuite - 32" LED TV - Full HD
LED-backlit LCD TV - Smart TV
Diagonal Class
32"
Commercial Use
Yes - hotel / hospitality
Platform
Android
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
HDMI
HDMI Ports Qty
2 ports
Wi-Fi, LAN
PC Interface
Mobile High-Definition Link (MHL)
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
Digital TV Tuner
DVB-C, DVB-T, DVB-T2
Analogue TV Tuner
PAL
Internet Streaming Services
HbbTV, Chromecast
Commercial Features
Prison mode, VSecure, mychoice, Serial Xpress Protocol, Double isolation Class II, Playready Smoothstreaming, SecureMedia, Joystick Control Lock, menu lock, volume limitation
Settings Cloning Capability
Speaker System
2 speakers
Sound Effects
DTS Studio Sound, Dolby Atmos
Storage Drive Capacity
16 GB
Storage Capacity
16 GB
USB
2 ports
Philips 22AV1905A remote control
Voltage
AC 230V (50/60 Hz)
Energy Class
Class F
Power Consumption (On mode)
29 W
Power Consumption Stand by
0.35 Watt
Energy Consumption per Year
43 kWh
73.2 cm x 7.7 cm x 43.2 cm
4.5 kg
Energy Class
Class F
29 W
29 kWh/1000h
43 kWh
Diagonal Class
32"
Commercial Use
Series
Platform
Android
TV Tuner Presence
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
Modes
Eco mode, hotel mode
Design
Flame retardant cabinet
Dimensions
Without stand
73.2 cm
7.7 cm
43.2 cm
4.5 kg
Enclosure Colour
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Brightness
250 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Commercial Features
One touch Play
Stands & Mounts
Stand
Included
Stand Design
Tabletop
VESA Compatibility
TV Tuner
Analogue TV Tuner
PAL
Conditional Access
Common Interface Plus (CI+) slot
Digital TV Tuner
Digital TV Tuner
HDTV Tuner
Digital TV Service
MHEG
MPEG Profiles and Levels
MPEG4/MPEG2/HEVC
Video Features
Teletext
Electronic Programme Guide
Digital EPG, Now & Next
Media Player
Supported Video Formats
MPEG-1, MPEG-2, MPEG-4, WMV, AVI, MKV, AVC, H.264, VC-1, HEVC, VP9
Supported Audio Formats
MP3, WMA, WAV, AAC
Supported Pictures Formats
BMP, JPG, GIF, PNG
USB Port
USB Ports Qty
2
Configuration
16 GB
16 GB
Operating System
Android OS 7.0
Remote Control
Remote control
Remote Control Model
Philips 22AV1905A
Battery Form Factor
AAA type
Battery Included Qty
2
Audio System
Digital Audio Format
Dolby Digital output, DTS-HD digital output, Dolby AC-4 output
Surround Mode
Sound Effects
Speaker System
2 speakers
Output Power / Total
16 Watt
Down-firing Speaker, Audio Return Channel (ARC)
Speakers
2 x speaker - 8 Watt
Network & Internet Multimedia
Functionality
Internet video playback
Wi-Fi, LAN
LAN Protocol
Ethernet
Wi-Fi Protocol
802.11ac
Connect & Share
Wi-Fi Direct, Secure Sharing
HbbTV, Chromecast
Application Store
Google Play
Connector Type
Digital audio output (optical) - rear , Network - rear , Remote control - rear , HDMI - rear , USB 2.0 - rear , Speakers output - rear , USB 3.0 - side , HDMI - side , Headphones - side
Power supply
Nominal Voltage
AC 230V (50/60 Hz)
0.35 Watt
WOL (Wake on LAN)
Dimensions & Weight Details
Panel without stand - 73.2 cm x 7.7 cm x 43.2 cm x 4.5 kg , Panel with stand - 73.2 cm x 17.9 cm x 49.4 cm x 4.6 kg
Brand: Philips
