Philips 328E9FJAB E Line 32" 2560 x 1440 5ms VGA DVI LED Monitor
Quicklinx: DYGBWS00 Mfr#: 328E9FJAB/00
Diagonal Size: 32in
Max Resolution: 2560 x 1440
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, VGA (HD-15)
£199.99 ex VAT
£239.98 inc VAT
Philips' VA LED display uses an advanced multi-domain vertical alignment technology that gives you super-high static contrast ratios for extra-vivid and bright images.
While standard office applications are handled with ease, it is especially suitable for photos, web browsing, films, gaming and demanding graphical applications.
Its optimised pixel management technology gives you a 178/178-degree extra-wide viewing angle, resulting in crisp images.
  • Built-in stereo speakers for multimedia
    A pair of high-quality stereo speakers built into a display device. They may be visible front firing, or invisible down firing, top firing, rear firing etc. depending on model and design.
  • HDMI ensures universal digital connectivity
    An HDMI-ready device has all the required hardware to accept High-Definition Multimedia Interface (HDMI) input. An HDMI cable enables high-quality digital video and audio to be transmitted over a single cable from a PC or any number of AV sources (including set-top boxes, DVD players, A/V receivers and video cameras).
  • Crystal clear images with Quad HD 2560 x 1440 pixels
    These latest Philips screens deliver CrystalClear, Quad HD 2560x1440 or 2560x1080 pixel images. Utilising high-performance panels with a high-density pixel count, enabled by high-bandwidth sources like DisplayPort, HDMI, Dual link DVI, these new displays will make your images and graphics come alive. Whether you are a demanding professional requiring extremely detailed information for CAD-CAM solutions, using 3D graphic applications or a financial wizard working on huge spreadsheets, Philips displays will give you CrystalClear images.
  • DisplayPort connection for maximum visuals
    DisplayPort is a digital link from PC to monitor without any conversion. With higher capabilities than DVI standard, it is fully capable to support up to 15 metre cables and 10.8 Gbps/sec data transfer. With this high performance and zero latency, you get the fastest imaging and refresh rates — making DisplayPort the best choice for not only general office or home use, but also for the more demanding gaming and films, video editing and more. It also keeps interoperability in mind via the use of various adapters.
  • Less eye fatigue with Flicker-Free technology
    Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips Flicker-Free technology applies a new solution to regulate brightness and reduce flicker for more comfortable viewing.
  • Curved display design for a more immersive experience
    Desktop monitors offer a personal user experience, which suits a curved design very well. The curved screen provides a pleasant yet subtle immersion effect, which focuses on you at the centre of your desk.
  • Effortlessly smooth gameplay with AMD FreeSync™ technology
    Gaming shouldn't be a choice between choppy gameplay or broken frames. With the new Philips monitor it doesn't have to be. Get fluid, artefact-free performance at virtually any frame rate with AMD FreeSync™ technology, smooth, quick refresh and ultra-fast response time.
  • Ultra Wide-Color wider range of colours for a vivid picture
    Ultra Wide-Color Technology delivers a wider spectrum of colours for a more brilliant picture. The Ultra Wide-Color wider "colour gamut" produces more natural-looking greens, vivid reds and deeper blues. Bring media entertainment, images and even productivity more alive with vivid colours from Ultra Wide-Color Technology.
  • LowBlue Mode for easy-on-the-eyes productivity
    Studies have shown that just as ultra-violet rays can cause eye damage, shortwave-length blue light rays from LED displays can cause eye damage and affect vision over time. Developed for wellbeing, the Philips LowBlue Mode setting uses a smart software technology to reduce harmful shortwave blue light.
  • Narrow-border display for a seamless appearance
    The new Philips displays feature ultra-narrow borders which allow for minimal distractions and maximum viewing size. Especially suited for multi-display or tiling setups like gaming, graphic design and professional applications, the ultra-narrow border display gives you the feeling of using one large display.
  • VA display delivers awesome images with wide viewing angles
    Philips' VA LED display uses an advanced multi-domain vertical alignment technology that gives you super-high static contrast ratios for extra-vivid and bright images. While standard office applications are handled with ease, it is especially suitable for photos, web browsing, films, gaming and demanding graphical applications. Its optimised pixel management technology gives you a 178/178-degree extra-wide viewing angle, resulting in crisp images.
Philips E-line 328E9FJAB - LED monitor - curved - 32"
LED-backlit LCD monitor - 32"
Energy Class
Class C
Energy Consumption per Year
85 kWh
Power Consumption (On mode)
58 W
Curved Screen
Adaptive-Sync Technology
AMD FreeSync
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
1440p (Quad HD) 2560 x 1440 at 60 Hz
Pixel Pitch
0.272 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 20000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, low haze
Gloss black bezel with silver trim
71.3 cm x 23.6 cm x 52.5 cm
6.78 kg
FCC Class B certified, UL, TUV GS, BSMI, GOST, cUL, SASO, SEMKO, TUV Ergo, PSB, DDC/CI, RoHS, WEEE
Display Type
Energy Class
Class C
85 kWh
58 W
Diagonal Size
32"
Viewable Size
31.5"
Curved Screen
Yes (1800R)
AMD FreeSync
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.272 mm
Pixel Per Inch
93
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
48 - 75 Hz
Horizontal Refresh Rate
70 - 115 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
OSD Languages
Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish, Turkish
Sync on Green, HDCP, 102% NTSC colour gamut, SmartImage Game, Low Blue Light Mode, Flicker Free technology, sRGB Mode
71.3 cm x 23.6 cm x 52.5 cm - with stand
6.78 kg
Audio
Speakers - stereo
Output Power / Channel
3 Watt
VGA , DisplayPort , HDMI (HDCP) , Audio line-in , Headphones
Mechanical
Tilt
Tilt Angle
- 5/+20
VESA Mounting Interface
100 x 100 mm
HDMI cable
MTBF
50,000 hour(s)
Security Slot Type
Kensington security slot
60.35 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Included Software
Philips SmartControl Lite
Dimensions & Weight Details
With stand - width: 71.3 cm - depth: 23.6 cm - height: 52.5 cm - weight: 6.78 kg , Without stand - width: 71.3 cm - depth: 5.2 cm - height: 42.5 cm - weight: 6.4 kg
Shipping Width
82.7 cm
Shipping Depth
23.3 cm
Shipping Height
62.6 cm
Shipping Weight
10.45 kg
20 - 80%
Philips 328E9FJAB E Line 32 Bundle deal on Philips 328E9FJAB E Line 32" 2560 x 1440 5ms VGA DVI LED Monitor
£299.75
Diagonal Size: 32in
Response Time: 5ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Philips
Price Range Ex VAT: 150 - 300
