Philips 288P6LJEB 28" 3840x2160 5ms HDMI DVI-D VGA Black Monitor
Quicklinx: 9LC0WS00 Mfr#: 288P6LJEB/00
Diagonal Size: 28in
Max Resolution: 3840 x 2160
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DisplayPort, DVI, HDMI, VGA (HD-15)
14 in stock
£291.66 ex VAT
£349.99 inc VAT
See a new level of detail and clarity with the Philips 28" UltraClear 4K display! Ultra HD, four times clearer than Full HD, colors become richer, details become clearer. Experience Ultra High Definition at an ultra-mainstream price.
  • Low bezel-to-table height for maximum reading comfort
    Thanks to its advanced SmartErgoBase, the Philips monitor can be lowered down almost to desk level for a comfortable viewing angle. Low bezel-to-table height is the perfect solution if you use bifocals, trifocals or progressive lens glasses for your computing work. Additionally, it allows users of different heights to use the monitor at their preferred angle and height settings, helping them to reduce fatigue and strain.
  • MHL technology for enjoying mobile content on a big screen
    Mobile High-Definition Link (MHL) is a mobile audio/video interface for directly connecting mobile phones and other portable devices to high-definition displays. An optional MHL cable allows you to simply connect your MHL-capable mobile device to this large Philips MHL display and watch your HD videos come to life with full digital sound. Now not only can you enjoy your mobile games, photos, movies or other apps on its big screen, you can simultaneously charge your mobile device so you never run out of power halfway.
  • SmartResponse 1 ms refresh for fast gaming
    SmartResponse is an exclusive Philips overdrive technology that when turned on, automatically adjusts response times to specific application requirements like gaming and films, which require faster response times in order to produce judder, time-lag and ghost image free images
  • SmartErgoBase for better ergonomics
    The SmartErgoBase is a monitor base that delivers ergonomic display comfort and provides cable management. The user-friendly height, swivel, tilt and rotation angle adjustments of the base allow the monitor to be positioned for maximum comfort to help ease the physical strains of a long workday. In addition, cable management reduces cable clutter and keeps the workspace neat and professional.
  • UltraClear 4K UHD (3840 x 2160) resolution for precision
    These latest Philips displays utilise high-performance panels to deliver UltraClear, 4K UHD (3840 x 2160) resolution images. Whether you are a professional requiring extremely detailed images for CAD solutions, using 3D graphics applications or are a financial wizard working on huge spreadsheets, Philips displays will make your images and graphics come alive.
  • HDMI for quick digital connection
    Enjoy crisp colourful images and audio with simple one-cable connection. A HDMI-ready device has all the required hardware to accept High-Definition Multimedia Interface (HDMI) input. A HDMI cable enables high-quality smooth digital video (up to 4K/UHD resolution at 60 Hz) and audio all transmitted over a single cable from a PC or any number of AV sources (including set-top boxes, DVD players, A/V receivers and video cameras).
Philips Brilliance P-line 288P6LJEB - LED monitor - 4K - 28"
LED-backlit LCD monitor - 28"
Energy Class
Class C
Energy Consumption per Year
92 kWh
Power Consumption (On mode)
63 W
USB Hub
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 60 Hz
Pixel Pitch
0.16 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 50000000:1 (dynamic)
Response Time
5 ms
Colour Support
1.07 billion colours
Input Connectors
HDMI, DVI-D, VGA, DisplayPort
Speakers
Integrated
Display Position Adjustments
65.9 cm x 27.3 cm x 57.3 cm
8.04 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV GS, BSMI, GOST, SASO, SEMKO, TUV Ergo, DDC/CI, RoHS, WEEE, BFR, cETLus
3-year warranty
Display Type
Energy Class
Class C
92 kWh
63 W
Diagonal Size
28"
Built-in Devices
USB Hub
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.16 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
23 - 80 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Sync on Green, sRGB colour management, HDCP, Eco-Mode, SmartResponse, MultiView, SmartImage, Mobile High-Definition Link (MHL), Smart Ergo base, SmartControl Premium, SmartConnect
65.9 cm x 27.3 cm x 57.3 cm - with stand
8.04 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
3 Watt
VGA , DVI-D , DisplayPort , HDMI , Headphones , Audio line-in , 2 x USB 2.0 , USB 3.0
Mechanical
Tilt Angle
-5/+20
Swivel Angle
130
Rotation Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), LED indicator
MTBF
30,000 hour(s)
Power Supply
Internal
Power Consumption Stand by
0.5 Watt
On / Off Switch
Apple MacOS X, Microsoft Windows 7, Windows 8
Dimensions & Weight Details
With stand - width: 65.9 cm - depth: 27.3 cm - height: 57.3 cm - weight: 8.04 kg , Without stand - width: 65.9 cm - depth: 4.9 cm - height: 39.5 cm - weight: 5.24 kg
ENERGY STAR Certified
Limited warranty - 3 years
20 - 80%
Philips 288P6LJEB 28 Bundle deal on Philips 288P6LJEB 28" 3840x2160 5ms HDMI DVI-D VGA Black Monitor
£390.83
9LC0 C2G 2m DisplayPort Male to HD Male Adapter Cable - Black In Stock £22.48
9LC0 C2G 2m DisplayPort Male to Single Link DVI-D Male Adapter Cable In Stock £24.55
9LC0 C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £8.17
9LC0 C2G 10m DisplayPort Cable with Latches M/M – Black In Stock £23.20
9LC0 C2G 20cm DisplayPort Male to Single Link DVI-D Female Adapter Cable - Black In Stock £16.11
9LC0 C2G 20cm DisplayPort Male to HDMI Female Adapter Converter Black In Stock £20.62
9LC0 C2G 20cm DisplayPort Male to VGA Female Adapter Converter Black In Stock £15.80
Diagonal Size: 28in
Response Time: 5ms
Interfaces: DVI
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Philips
Price Range Ex VAT: 150 - 300
