See a new level of detail and clarity with the Philips 28" UltraClear 4K display! Ultra HD, four times clearer than Full HD, colors become richer, details become clearer. Experience Ultra High Definition at an ultra-mainstream price.
Low bezel-to-table height for maximum reading comfort
Thanks to its advanced SmartErgoBase, the Philips monitor can be lowered down almost to desk level for a comfortable viewing angle. Low bezel-to-table height is the perfect solution if you use bifocals, trifocals or progressive lens glasses for your computing work. Additionally, it allows users of different heights to use the monitor at their preferred angle and height settings, helping them to reduce fatigue and strain. -
MHL technology for enjoying mobile content on a big screen
Mobile High-Definition Link (MHL) is a mobile audio/video interface for directly connecting mobile phones and other portable devices to high-definition displays. An optional MHL cable allows you to simply connect your MHL-capable mobile device to this large Philips MHL display and watch your HD videos come to life with full digital sound. Now not only can you enjoy your mobile games, photos, movies or other apps on its big screen, you can simultaneously charge your mobile device so you never run out of power halfway. -
SmartResponse 1 ms refresh for fast gaming
SmartResponse is an exclusive Philips overdrive technology that when turned on, automatically adjusts response times to specific application requirements like gaming and films, which require faster response times in order to produce judder, time-lag and ghost image free images -
SmartErgoBase for better ergonomics
The SmartErgoBase is a monitor base that delivers ergonomic display comfort and provides cable management. The user-friendly height, swivel, tilt and rotation angle adjustments of the base allow the monitor to be positioned for maximum comfort to help ease the physical strains of a long workday. In addition, cable management reduces cable clutter and keeps the workspace neat and professional. -
UltraClear 4K UHD (3840 x 2160) resolution for precision
These latest Philips displays utilise high-performance panels to deliver UltraClear, 4K UHD (3840 x 2160) resolution images. Whether you are a professional requiring extremely detailed images for CAD solutions, using 3D graphics applications or are a financial wizard working on huge spreadsheets, Philips displays will make your images and graphics come alive. -
HDMI for quick digital connection
Enjoy crisp colourful images and audio with simple one-cable connection. A HDMI-ready device has all the required hardware to accept High-Definition Multimedia Interface (HDMI) input. A HDMI cable enables high-quality smooth digital video (up to 4K/UHD resolution at 60 Hz) and audio all transmitted over a single cable from a PC or any number of AV sources (including set-top boxes, DVD players, A/V receivers and video cameras).
- Philips Brilliance P-line 288P6LJEB - LED monitor - 4K - 28"
- LED-backlit LCD monitor - 28"
- Energy Class
- Class C
- Energy Consumption per Year
- 92 kWh
- Power Consumption (On mode)
- 63 W
- USB Hub
- Aspect Ratio
- 16:9
- Native Resolution
- 4K 3840 x 2160 at 60 Hz
- Pixel Pitch
- 0.16 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1 / 50000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 1.07 billion colours
- Input Connectors
- HDMI, DVI-D, VGA, DisplayPort
- Speakers
- Integrated
- Height, pivot (rotation), swivel, tilt
- Black
- 65.9 cm x 27.3 cm x 57.3 cm
- 8.04 kg
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, FCC Class B certified, TUV GS, BSMI, GOST, SASO, SEMKO, TUV Ergo, DDC/CI, RoHS, WEEE, BFR, cETLus
- 3-year warranty
- Display Type
- Energy Class
- Class C
- 92 kWh
- 63 W
- Diagonal Size
- 28"
- Built-in Devices
- USB Hub
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.16 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 23 - 80 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- WLED
- OSD Languages
- Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
- Sync on Green, sRGB colour management, HDCP, Eco-Mode, SmartResponse, MultiView, SmartImage, Mobile High-Definition Link (MHL), Smart Ergo base, SmartControl Premium, SmartConnect
- Black
- 65.9 cm x 27.3 cm x 57.3 cm - with stand
- 8.04 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 3 Watt
- VGA , DVI-D , DisplayPort , HDMI , Headphones , Audio line-in , 2 x USB 2.0 , USB 3.0
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 130
- Rotation Angle
- 90
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), LED indicator
- MTBF
- 30,000 hour(s)
- Power Supply
- Internal
- Voltage Required
- AC 120/230 V (50/60 Hz)
- Power Consumption Stand by
- 0.5 Watt
- On / Off Switch
- OS Required
- Apple MacOS X, Microsoft Windows 7, Windows 8
- Dimensions & Weight Details
- With stand - width: 65.9 cm - depth: 27.3 cm - height: 57.3 cm - weight: 8.04 kg , Without stand - width: 65.9 cm - depth: 4.9 cm - height: 39.5 cm - weight: 5.24 kg
- ENERGY STAR Certified
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 20 - 80%
Bundle includes:
Microsoft Office 365 Business Premium ‘in a box’ 1 year subscription/license worth £99.17 | in stock |
£404.77
C2G HDMI to DisplayPort Adapter Converter | In Stock | £37.11 |
C2G 2m DisplayPort Male to HD Male Adapter Cable - Black | In Stock | £22.45 |
C2G 2m DisplayPort Male to Single Link DVI-D Male Adapter Cable | In Stock | £24.49 |
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £8.17 |
C2G 10m DisplayPort Cable with Latches M/M – Black | In Stock | £23.14 |
C2G 20cm DisplayPort Male to Single Link DVI-D Female Adapter Cable - Black | In Stock | £16.06 |
C2G 20cm DisplayPort Male to HDMI Female Adapter Converter Black | In Stock | £20.57 |
C2G 20cm DisplayPort Male to VGA Female Adapter Converter Black | In Stock | £15.75 |
