Philips 28" LCD Monitor LED Backlight 1920 x 108016:9 Black Bezel
Quicklinx: 98XXWS00 Mfr#: 284E5QHAD/00
This big, attractive Philips display with slim bezel and MVA screen gives you awesome, vibrant color images. Mobile HD link allows you to mirror your smartphone, immersing you in powerful multimedia.
  • MVA LED display
    Philips MVA LED display uses an advanced multi-domain vertical alignment technology which gives you super-high static contrast ratios for extra vivid and bright images. While standard office applications are handled with ease, it is especially suitable for photos, web browsing, movies, gaming, and demanding graphical applications. Its optimized pixel management technology gives you 176/176 degree extra wide viewing angle, resulting in crisp images even in 90 degree pivot mode.
  • MHL technology
    Mobile High Definition Link (MHL) is a mobile audio/video interface for directly connecting mobile phones and other portable devices to high-definition displays. An optional MHL cable allows you to simply connect your MHL capable mobile device to this large Philips MHL display, and watch your HD videos come to life with full digital sound. Not only you can enjoy your mobile games, photos, movies, or other apps on its big screen, you can simultaneously charge your mobile device so you never run out of power half way.
  • SmartImage Lite
    SmartImage Lite is an exclusive, leading edge Philips technology that analyzes the content displayed on your screen. Based on a scenario you select, SmartImage Lite dynamically enhances the contrast, color saturation and sharpness of images and videos for ultimate display performance - all in real time with the press on a single button.
  • Superb 14 watts stereo sound
    A pair of high quality stereo speakers built into a display device. It can be visible front firing, or invisible down firing, top firing, rear firing, etc depending on model and design.
  • HDMI ready
    A HDMI-ready device has all the required hardware to accept High-Definition Multimedia Interface (HDMI) input, high quality digital video and audio signals all transmitted over a single cable from a PC or any number of AV sources including set-top boxes, DVD players and A/V receivers and video cameras.
  • 16:9 Full HD
    The Full HD screen has the widescreen resolution of 1920 x 1080p. This is the highest resolution of HD sources for the best possible picture quality. It is fully future proof as it supports 1080p signals from all sources, including the most recent like Blu-ray and advanced HD game consoles. The signal processing is extensively upgraded to support this much higher signal quality and resolution. It produces brilliant flicker-free progressive scan pictures with superb brightness and colors.
Philips E-line 284E5QHAD - LED monitor - Full HD (1080p) - 28"
LED-backlit LCD monitor - 28"
Energy Class
Class B
Energy Consumption per Year
57 kWh
Power Consumption (On mode)
39 W
Panel Type
MVA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.323 mm
Brightness
300 cd/m²
Contrast Ratio
20000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Input Connectors
2xHDMI, VGA
Display Position Adjustments
Tilt
Voltage
Glossy cherry
5.54 kg
Environmental Standards
ENERGY STAR Qualified
3-year warranty
Display Type
Energy Class
Class B
57 kWh
Diagonal Size
28"
Panel Type
MVA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.323 mm
Brightness
300 cd/m²
Contrast Ratio
Response Time
5 ms (grey-to-grey)
Horizontal Viewing Angle
176
Vertical Viewing Angle
176
Backlight Technology
WLED
SmartContrast, Mobile High-Definition Link (MHL)
Glossy cherry
- with stand
5.54 kg
Audio
Speakers
VGA , 2 x HDMI , Headphones
Mechanical
Tilt
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), wall mountable
1 x VGA cable , 1 x audio cable
Power Supply
External
Input Voltage
39 W
Power Consumption (Typical)
23.18 Watt
Power Consumption Stand by
0.5 Watt
On / Off Switch
No
Included Software
Philips SmartControl Lite
Dimensions & Weight Details
With stand - weight: 5.54 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
