Vivid colors, crisp details in an elegant design! Experience brilliant, crisp images like never before with this Full HD, display. With elegant, slim design and SmartImage lite, it looks stunning in every way!
HDMI-ready for Full HD entertainment
An HDMI-ready device has all the required hardware to accept High-Definition Multimedia Interface (HDMI) input. An HDMI cable enables high-quality digital video and audio to be transmitted over a single cable from a PC or any number of AV sources (including set-top boxes, DVD players, A/V receivers and video cameras). -
MHL technology for enjoying mobile content on a big screen
Mobile High-Definition Link (MHL) is a mobile audio/video interface for directly connecting mobile phones and other portable devices to high-definition displays. An optional MHL cable allows you to simply connect your MHL-capable mobile device to this large Philips MHL display and watch your HD videos come to life with full digital sound. Now not only can you enjoy your mobile games, photos, movies or other apps on its big screen, you can simultaneously charge your mobile device so you never run out of power halfway. -
SmartContrast for deep black level details
SmartContrast is a Philips technology that analyses the contents you are displaying, automatically adjusting colours and controlling backlight intensity to dynamically enhance contrast for the best digital images and videos or when playing games where dark hues are displayed. When Economy mode is selected, contrast is adjusted and backlighting fine-tuned for just-right display of everyday office applications and lower power consumption. -
Modern Touch controls complement the design
Touch controls are intelligent, touch-sensitive icons that replace protruding buttons to allow users to adjust the monitor to their requirements. Responding to the lightest touch, Touch control gives the monitor a modern feel. -
16:9 Full HD display for crisp, detailed images
Picture quality matters. Regular displays deliver quality, but you expect more. This display features enhanced Full HD 1920 x 1080 resolution. With Full HD for crisp detail paired with high brightness, incredible contrast and realistic colours, expect a true-to-life picture.
- Philips E-line 277E6LDAD - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class B
- Energy Consumption per Year
- 53 kWh
- Power Consumption (On mode)
- 36 W
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.311 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1 / 20000000:1 (dynamic)
- Response Time
- 5 ms (typical), 1 ms (grey-to-grey with overdrive)
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA, HDMI (MHL)
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Glossy cherry black
- 64 cm x 23.5 cm x 47.8 cm
- 5.42 kg
- Environmental Standards
- ENERGY STAR Qualified
- FCC Class B certified, TUV, VCCI, SASO, SEMKO, DDC/CI, RoHS, Lead-Free, ISO 9241-307, KCC, WEEE, KUCAS, EPA, cETLus, RCM, CU-EAC
- Display Type
- Energy Class
- Class B
- 53 kWh
- Diagonal Size
- 27"
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.311 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 56 - 75 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- WLED
- OSD Languages
- Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
- Sync on Green, sRGB colour management, SmartImage Lite, SmartContrast, Touch Control, Mercury free
- 64 cm x 23.5 cm x 47.8 cm - with stand
- 5.42 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 3 Watt
- VGA , DVI-D (HDCP) , MHL / HDMI (HDCP) , Audio line-in , Headphones
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- MTBF
- 50,000 hour(s)
- Input Voltage
- 36 W
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.3 Watt
- On / Off Switch
- No
- OS Required
- Apple MacOS X, Microsoft Windows 7 / 8 / 8.1 / 10
- Dimensions & Weight Details
- With stand - width: 64 cm - depth: 23.5 cm - height: 47.8 cm - weight: 5.42 kg , Without stand - width: 64 cm - depth: 4.8 cm - height: 39.4 cm - weight: 5.17 kg
Sustainability Information
- ENERGY STAR Certified
- 0 °C
- 40 °C
- 20 - 80%
C2G 2m HDMI to DVI-D Digital Video Cable | In Stock | £11.38 |
